UPC GO App Access Issues in UK Post-Brexit with VPN
hpy 4848 5
  • #1 19493638
    hpy
    Hello...
    I live in the UK and Brexit has messed things up a bit in various areas. So far, I've been using the apk using a vpn, but they must have changed something because it stopped working completely.
    Is there anyone who knows and can help me how to use the app in the UK?
    (because it seems to me that in other EU countries it should work without a problem)
    Regards
  • #2 19493683
  • #3 19493953
    hpy
    However, it's a Brexit issue, because there is no problem in the EU and until January it worked without a problem ...
    But it doesn't matter what reason.. It's important to do it to be able to use it
    -Zuzia
    Help: 15
    Rate: 89
    Polish IP is no longer enough, you need to have it from the UPC pool:
    To view the material on this forum you must be logged in.
  • #5 19871914
    Kli1
    Level 4  
    and has anyone figured out how to fix it? my surfshark vpn is not working either
  • #6 19871920
    hpy
    Analyze the above post .. This is probably the only way out, a helpful forum, so someone will definitely help you get over it
