A giant screen from days gone by – the interior of a 29-inch Sony Trinitron KV-29X5K CRT television
p.kaczmarek2 4002 57
  • A 29-inch Sony Trinitron KV-29X5K CRT television is opened and photographed inside, showing its layout, tube, boards, speakers, and service documentation.
  • The set uses a Super Trinitron tube with 110-degree deflection, a separate standby converter, a STR-F6654 main supply, and a 2SD2539 horizontal output transistor.
  • Rear and front connectivity includes two SCART sockets, RGB, S-Video, composite input, RCA audio, and a headphone jack, alongside 2×20 W speakers.
  • The service manual exposes exploded views, circuit schematics, pinouts, waveforms, and voltage points, making repair-oriented disassembly much easier than modern TV documentation.
  • A giant screen from days gone by – the interior of a 29-inch Sony Trinitron KV-29X5K CRT television
    Do you remember cathode-ray tube televisions? Here is a look at the Sony Trinitron set, which stands out with its huge 29-inch screen, two built-in 20-watt speakers and a weight of well over 40 kilograms. Full specifications below:
    The KV-29X5K has a power consumption of 108 W and is based on a Super Trinitron picture tube with a visible diagonal of approx. 68 cm (the beam deflection angle is 110 degrees). The television is equipped with a wide range of connectors: at the rear it has two SCART sockets (supporting RGB and S-Video), whilst at the front there is a composite (cinch) input, an S-Video input and a headphone socket. The package is rounded off by a built-in 2x20 W sound system. Its dimensions are also impressive – with a depth of over 52 cm, this set weighs as much as 43.5 kg.
    The manual attached to this thread doesn’t just cover user-related matters – it also contains information for service technicians, including instructions on how to dismantle the television. What caught my attention there was the option to secure the circuit board in a service position. It’s clear that the whole unit was designed with repairs in mind.
    The disassembly of the CRT is also described. WARNING: The interior of a CRT television is dangerous! The cathode-ray tube acts as a capacitor and a dangerous high voltage (of the order of 25–30 kV) may remain in the vicinity of the ‘suction cup’ (anode) for a very long time after the mains power has been disconnected. Furthermore, striking or breaking the neck of the picture tube risks a dangerous implosion. Please exercise caution when carrying out any experiments with this type of equipment and do so at your own risk.
    It looked very similar in my case. Incidentally, you may notice the sticker advertising the features of this set, namely the NICAM standard (digital stereo), 10-page teletext, a sleep timer, AV sockets on the front and two SCART sockets on the back.
    A giant screen from days gone by – the interior of a 29-inch Sony Trinitron KV-29X5K CRT television A giant screen from days gone by – the interior of a 29-inch Sony Trinitron KV-29X5K CRT television A giant screen from days gone by – the interior of a 29-inch Sony Trinitron KV-29X5K CRT television
    Warranty seal – has no one looked inside before?
    So ‘we’ll be the first ones here’. Just a quick glance at the type plate and we can remove the casing.
    On the neck of the cathode-ray tube there is a circuit board (known as the PK), and beneath it is the deflection coil assembly. The role of these coils is to generate a variable magnetic field which deflects (scans) the electron beams vertically and horizontally across the entire width of the phosphor-coated screen. In turn, signals from the video amplifiers, fed from the PK plate directly to the cathodes, are responsible for ‘controlling’ the intensity of the beams for the primary colours (red, green and blue). The entire scanning process takes place so quickly that the human eye cannot perceive the movement of a single pixel, and we are left with the illusion of a smooth image.
    A giant screen from days gone by – the interior of a 29-inch Sony Trinitron KV-29X5K CRT television A giant screen from days gone by – the interior of a 29-inch Sony Trinitron KV-29X5K CRT television A giant screen from days gone by – the interior of a 29-inch Sony Trinitron KV-29X5K CRT television A giant screen from days gone by – the interior of a 29-inch Sony Trinitron KV-29X5K CRT television
    Picture tube designation:
    Earlier, I showed you an old Trinitron KV-21FT1K television with a single small speaker inside. Apparently, the mono sound was a natural consequence of the low price. Here, it’s quite the opposite – full stereo, and the speakers are even encased in a way that enhances their acoustic properties. Perhaps someone with expertise in audio could explain in more detail what effect this has, as I personally only have a basic understanding of music – I can tell when they’re playing and when they’re not...
    According to the embossed marking on the plastic, this part was manufactured in July 1998...
    This is one of the newer sets, so many of the circuits have been simplified and there are dedicated integrated circuits inside for CRT operation, but there are still plenty of materials to be recovered. First and foremost, the coils – that is, copper – but the heat sinks (aluminium) are also quite large; you’d be hard-pressed to find anything like them in modern LCD televisions with LED backlighting:
    The main switch completely disconnects the television from the mains – both the live wire and the neutral wire are cut off. There is a separate standby switch; in standby mode, the television can be woken up using the remote control. In modern televisions, no one would bother with switches like these.
    On the front panel, there are buttons (gone are the days when you’d have trouble accessing basic options if you lost the remote control), RCA sockets (audio – right and left channels, video), RGB, and even a headphone jack.
    The mains power supply circuit essentially consists of two circuits. There is a tiny standby converter here, based on the TOP209P. This is an integrated PWM controller with a built-in MOSFET switch (TOPSwitch family), frequently used in standby power supplies due to the minimal number of external components required:
    The main converter is switched on by the relay visible in the photograph. It is based on the F6654 STR (Sanken STR-F6654). This is a thick-film hybrid chip integrating a controller and a high-power MOSFET, designed specifically for use in switching power supplies for large-screen televisions:
    In a CRT television, there is also a separate circuit for horizontal deflection and for generating high voltage on the flyback transformer. The photograph shows its switching transistor, the D2539 (actually the 2SD2539), separately. This is a high-voltage NPN bipolar transistor with an integrated suppressor diode:
    The SONY CXA2060S appears to be at the heart of the signal processing
    The CXA2060S is an advanced TV signal processor from Sony. It decodes colours in the PAL/NTSC/SECAM standards and generates signals for the deflection circuits, whilst its operation is digitally controlled by a microcontroller via the I2C bus.
    The TDA7495 is responsible for the audio. It is a Class AB audio amplifier IC from STMicroelectronics, capable of delivering 2×11W of power. It features an integrated, voltage-controlled volume control and a hardware mute function.
    On the additional board, you can see the TDA9875A, which acts as an advanced digital signal processor (DSP). It decodes and processes the audio signal from the aerial, providing, amongst other things, support for the NICAM digital stereo audio standard mentioned at the beginning.
    This can also be deduced from the signal labels – alongside the power supply, there are L OUT/R OUT (right and left channels) and an I2C bus (SDA/SCL) for control.
    A TDA9817 can be seen at the aerial input. This is a phase-locked loop (PLL) circuit for demodulating the video intermediate frequency (VIF) and audio intermediate frequency (SIF) signals. In practice: it separates and processes the video and audio signals from what the tuner receives.
    The tuner head itself likely contains a chip from the TUA6014 family. This is a phase-locked loop (PLL) from Siemens/Infineon designed for TV tuners. Thanks to I2C communication, it allows the main processor to precisely tune the TV to the selected band and channel.
    Overall, the PCB is single-sided and the vast majority of components are surface-mounted. On the underside, only a few SMD components can be seen, such as resistors, capacitors, transistors or individual integrated circuits.
    These include, amongst others, the 24W086 (a 1 KB EEPROM with an I2C interface, which stores user settings and values for service mode) and the CD4052 (a dual, 4-channel analogue multiplexer, presumably used to switch audio and video signals between inputs):
    Here, in turn, is a view of the board from the neck of the cathode-ray tube – I can see three BF871s on it, as well as LM358 and LM393N chips.
    There are still the deflection coils left, as usual a bit glued together; recovering the wire would be rather difficult:
    Finally, you can also have a look at the service manual. It is something completely different from today’s standards for equipment documentation. It contains everything, starting with an ‘exploded’ view with each component labelled:
    Through views of the circuit boards and separate schematics:
    For example, the circuit board shown in the image matches almost perfectly with what I’ve provided in the photos, although there is a slight difference in the version – 1-715-005-12 versus 1-715-005-11. This really does make diagnosing and repairing faults much easier.
    The documentation also describes the voltages at individual points and components – for example, for transistors, the values at the collector, emitter and base are highlighted. In some places, the expected waveforms are also shown, i.e. what you can expect to see on an oscilloscope.
    For convenience, a whole page has also been devoted to diagrams of the components themselves, complete with labelled pins.
    To sum up, this was the interior of a 29-inch Sony Trinitron television, model KV-29X5K. Unfortunately, I barely remember those big CRT tellys at all; I think we only had a similar one during my early childhood, after which it was quickly replaced by a flat-screen TV. My computer actually started out with an LCD screen (I think it was a Flatron), so CRTs have always been a curiosity to me; that’s also why I decided to feature it here. It was a heavy piece of kit to carry in, but I suppose it was worth it for these few photos. What are your memories of televisions? CRTs – how user-friendly are they, and how prone to breakdowns? Have any of you had any models from the Sony Trinitron range?
    p.kaczmarek2 wrote 14803 posts with rating 12965, helped 659 times. Been with us since 2014 year.
  • Later stripped-down Trinitron with poor tube tint
    #2 21938197
    James596
    Level 30  
    Help: 140
    Rate: 575
    A popular model – I often came across them in people’s homes, and I actually had a similar one myself for a while.
    It’s true, the sound quality was very good, but unfortunately I often saw this model with a ‘beetroot-coloured’ tint – poor-quality picture tubes.
    It’s worth noting that this Soniak is a later, somewhat ‘stripped-down’ model. The older ones from the early 90s were even heavier, but that’s hardly surprising – inside, the entire rear of the picture tube was encased in metal shielding.
  • #3 21938202
    sq3evp
    Help: 226
    Rate: 902
    A Trinitron like that must have been heavy.
    I had a Grundig 100 Hz, which was flat, but the Sony weighed more because of the design of the picture tube. Mine weighed about 15 kg (or was it about 30 kg?).
  • #4 21938225
    kazikszach
    Help: 516
    Rate: 1105
    This one has a slightly curved screen; the flat ones weighed even more.
    The quality of the CRTs went downhill after production was moved to Europe – to my recollection, to the UK and Spain.
  • #5 21938226
    gulson
    System Administrator
    Help: 150
    Rate: 6144
    It used to be everyone’s dream.
  • Nostalgic comparison of CRT and LCD sizes
    #6 21938238
    andrzejlisek
    Level 32  
    Help: 82
    Rate: 713
    I remember them perfectly well, and I actually stuck with that technology for quite a long time. Not only that! For a very long time, I believed that CRTs produced a better picture than LCDs, even though the latter were more modern and were rapidly replacing CRTs. But, as you’d expect, LCD eventually won me over too, and it turned out I’d been wrong.
    It does seem strange, though, that a 21-inch screen used to be the ‘standard’ size, a 29-inch screen was considered a ‘very large screen’, and nowadays a 42-inch screen is seen as ‘a bit small’.
  • #7 21938241
    James596
    Level 30  
    Help: 140
    Rate: 575
    Screens are getting bigger and bigger, whilst the content on TV is getting sillier and sillier.
  • #8 21938246
    Rate: 12965
    Contrary to what one might think, there is actually some truth in this. From what I’ve heard, NES games and the like were designed with CRT monitors in mind, and they look better on a CRT, although I haven’t verified this myself. CRT monitors are still sought after for retrogaming.
  • CRT displays preserve unprocessed image dynamics
    #9 21938264
    kazikszach
    Help: 516
    Rate: 1105
    Yes, because that was real television, delivering a dynamic picture.
    I’ve already mentioned here on the forum that, as a Formula 1 fan, I saw the best picture quality on a CRT TV and analogue satellite TV; there was real dynamism there, because there was no digital processing whatsoever. After switching to a 100Hz CRT TV, the dynamism disappeared, although the picture didn’t flicker. Once the Wizja TV digital platform launched, the picture quality in terms of dynamism got even worse.
    Now I have a Sony 4K, and a Canal+ tuner that’s also 4K, but the picture looks a bit artificial because of all the compression during transmission.
    From what I’ve heard, NES games and the like were designed with CRTs in mind, and look better on a CRT, though I haven’t verified this myself. CRTs are still sought after for retrogaming.
    That may well be the case, as such a TV has no digital-to-analogue converter and displays whatever the game sends it without any processing, with the dynamic range provided by the picture tube.
  • Critique of flat-screen TV sound quality
    #10 21938306
    Pan.Kropa
    Help: 252
    Rate: 1187
    I’d like CRT televisions to remain the norm. I liked those huge, heavy behemoths. With their massive backs. I remember how, in the early 90s, I think it was at Radioelektronik or AudioVideo, they were showcasing the Panasonic ‘The One Up’ TVs. I used to gaze at them dreamily in the brochures. Unfortunately, the prices were such that owning one was nothing but a pipe dream. Modern flat-screen TVs may well have good picture quality, but for the most part, the sound they produce is simply rubbish.
  • #11 21938316
    karolark
    Help: 702
    Rate: 2519
    And the tomcats had somewhere to lounge about 😸😸
  • #13 21938361
    ppwielki
    Help: 72
    Rate: 294
    Pan.Kropa wrote:
    I’d like CRT tellys to still be the norm. I liked those big, heavy behemoths.
    I’ve kept one of those for myself. I wanted to get rid of it, but I’ve changed my mind and I can’t manage it on my own. A 37-inch Thomson. It’s a slightly different viewing experience – old-school, really.
  • #14 21938365
    Pan.Kropa
    Help: 252
    Rate: 1187
    After much persuasion and nagging from my wife, who wanted something modern, I unfortunately got rid of my last CRT telly in 2015, even though it was still working perfectly well.
  • #15 21938403
    borba
    Help: 14
    Rate: 32
    >>21938088 Brilliant analysis! I remember how, back in 2001 or 2002, I lugged a similar one – only in a silver casing – up to the fourth floor, where we lived. I was so proud that I’d lugged that box up myself (I can’t remember how it was positioned) that it was a miracle I didn’t strain my back. But straight after that, the first Panasonic plasma TVs appeared at Elta in Szczecin, and anything with a CRT was suddenly ‘out of fashion’. It’s a shame, though these days I suppose only fans of the ‘vintage’ style still use them.
    I gave my second 25-inch Sony CRT TV to a mate at his allotment about 16–18 years ago. And – surprisingly – it’s still in use there to this day ;)
    Best regards!
  • CRT light gun compatibility and PAL scaling question
    #16 21938406
    carrot
    Moderator of Cars
    Help: 1317
    Rate: 3607
    On old consoles, as well as a controller or joystick, you also had a gun fitted with a photocell, which you could use to shoot at ducks flying across the screen ;) such a gun only works on a CRT television.
    Another question is: what should the image look like in the PAL 720x576 standard on a modern 4K screen?
  • #17 21938465
    Stanley_P
    Help: 62
    Rate: 294
    carrot wrote:
    Another question is: what should a PAL 720x576 image look like on a modern 4K screen?
    Or the other way round: how should an FHD 1080p image (not to mention 4K) look on an old 575-line (interlaced) screen? ;-)
  • Daewoo CRT audio issues and market limitations
    #18 21938495
    kaem
    Help: 66
    Rate: 296
    I had a Daewoo DMT-2595TXT. There was a problem with the sound: after a while, the voice coil in one of the speakers started to rub (Bukdoo – I replaced it with a Nokia and the bass quality improved straight away), no Nicam (although it was an option, but only for countries using the B/G system), and no support for stereo on the 6.25 MHz frequency (and, as luck would have it, the cable TV in my town used that very frequency). I temporarily managed to get stereo sound on a few channels by fitting a Rymi audio module, but then there was interference on the Nicam channels (the Nicam carrier at 5.85 MHz is very close to the 6.25 MHz carrier). Overall, it was a somewhat underdeveloped product for the specific Polish market.
    But those were the days. It was the last CRT television we ever had.
  • Daewoo CRT lacked Nicam and 6.25 MHz stereo support
    #19 21938530
    Pan.Kropa
    Help: 252
    Rate: 1187
    >>21938465 As if there were no HD, FHD or 4K images. We’d be marvelling at the Pal picture and everything would be fine.
    kaem wrote:
    I had a Daewoo DMT-2595TXT. There was a problem with the sound: after a while, the voice coil in one of the speakers started to rub (Bukdoo – I replaced them with Nokias and the bass quality improved straight away), no Nicam (although it was an option, but only for countries using the B/G system), no support for stereo on the 6.25 MHz frequency (and, as luck would have it, the cable TV in my town used that very frequency). I temporarily managed to get stereo sound on a few channels by fitting a Rymi audio module, but then there was interference on the Nicam channels (the Nicam carrier at 5.85 MHz is very close to the 6.25 MHz carrier). Overall, a somewhat underdeveloped product for the specific Polish market.
    But those were the days. It was the last CRT telly we ever had.
    I bought a 25-inch Philips TV in 2000. And on that, Nicam from the terrestrial aerial worked without any problems. The TV worked until 2015 without a single fault
  • #20 21938908
    thereminator
    Conditionally unlocked
    Help: 219
    Rate: 657
    Hitting or breaking the neck of a cathode-ray tube risks a dangerous implosion
    You do need to be careful when tinkering with a television, but let’s not go overboard with all this talk of implosion. Since at least the 1960s,
    picture tubes have been manufactured with anti-implosion protection.
  • #21 21938938
    andrzejlisek
    Level 32  
    Help: 82
    Rate: 713
    It depends more on where or how it’s hit. Hitting the neck itself poses no risk. I’ve lost count of how many times I’ve seen CRTs in the bin without their necks. In all such cases, the picture tube was intact.
    https://www.youtube.com/shorts/wz5MS355axw
  • #22 21939014
    Jawi_P
    Level 36  
    Help: 260
    Rate: 717
    James596 wrote:
    Screens are getting bigger and bigger, whilst TV content is getting sillier and sillier.
    Because there’s no Sondy ;)
    And I’ve still got a 14-inch one that works – I think it’s a Samsung from 2001 :) I bought it for my wife back then whilst she was in hospital, as she spent quite a bit of time there.
    The TV stands proudly in the cellar, unused, and it’d be a shame to throw it away.
  • #23 21939022
    Pan.Kropa
    Help: 252
    Rate: 1187
    Jawi_P wrote:
    The TV is just sitting there, unused, in the cellar, and it’d be a shame to throw it away.
    May it last a hundred years, or even longer. But one day your heirs will get rid of it.
  • Japanese-made Trinitrons outlasted European production
    #24 21939137
    kris8888
    Help: 537
    Rate: 1936
    kazikszach wrote:
    The quality of CRT televisions went downhill after production was moved to Europe – if my memory serves me correctly, to the UK and Spain
    That’s right. I’ve owned three Sony Trinitron tellys in my life. The first was a 29-inch model, bought in the early 1990s, when production was still entirely Japanese. It cost a fortune, and I still had to retrofit it with a 6.5 MHz parallel audio circuit because the original was only 5.5 MHz. It ran faultlessly for many years, until I took it to the recycling centre around 2010. The picture quality remained superb right to the end.
    In the meantime, I needed a second television; I also opted for a Sony Trinitron, but this time a 25-inch model, which I bought in the late 1990s. This one was manufactured in Spain, and the picture tube was also made in Spain. Unfortunately, it didn’t last long; the picture tube quickly stopped working, and on top of that, cold solder joints began to appear on the circuit board.
    The third Trinitron was quite a ‘beast’ – a 32-inch widescreen, which was stunning for its time, with a completely flat picture tube. It was an incredibly heavy piece of kit due to the thick glass of the picture tube, but it was equipped with every possible technical innovation of the period: picture-in-picture, picture memory (freeze frame), a dual tuner, Dolby Stereo, detachable external large speakers (two-way) and a powerful built-in audio amplifier. The picture and sound were simply sensational. It even came with a dedicated stand. I don’t know the exact year of manufacture, as I got the TV from a family member – probably the late 1990s – but it was entirely Japanese-made. I used it right up until I bought an LCD TV in 2012. It only ever had one fault: a single resistor in the high-voltage power supply circuit of the picture tube failed. Right up until I sold it for a symbolic one zloty, the picture was perfect.
  • CRT TVs as a closed chapter
    #25 21939141
    Stanley_P
    Help: 62
    Rate: 294
    Pan.Kropa wrote:
    If it weren’t for HD, FHD and 4K. We’d still be marvelling at PAL pictures and everything would be fine.
    If only there were no PALs, SECAMs or NTSCs. We’d still be watching in ‘artistic’ B&W. That would mean so many fewer problems with colour reproduction, convergence (in ‘crt TVs’), and so on. And so on, going further back ;-) For me, the CRT TV is a relic, a thing of the past, a closed chapter. Just like valve radios, cassettes, reel-to-reel tapes, video recorders, and even vinyl records. I know, I know, I’ll get a bit of flak from some people for that last one ;-)
  • CRT TVs as relics with fewer color issues
    #26 21939160
    karolark
    Help: 702
    Rate: 2519
    Stanley_P wrote:
    Pan.Kropa wrote:
    As if there were no HD, FHD or 4K images. We’d be marvelling at PAL pictures and everything would be fine.
    As if there were no PALs, SECAMs or NTSCs. We’d still be watching in ‘artistic’ B&W. That would mean so many fewer problems with colour reproduction, convergence (in ‘crt TVs’), and so on. And so on, going further back ;-) For me, CRT TVs are a thing of the past, a closed chapter. Just like valve radios, cassettes, reel-to-reel tapes, video recorders, and even vinyl records. I know, I know, I’ll get a bit of flak from some people for that last one ;-)
    Relics. But not always worse :-)
  • #27 21939212
    ppwielki
    Help: 72
    Rate: 294
    ...And that’s why I’ve just bought the cheapest DVB-T2 set-top box with two remotes for 55 zł, sat down in my armchair and watched the match for a bit. I think I’ll make a nice little table for it instead of a cabinet?
  • CRT hardware provided dithering and anti-aliasing
    #28 21939284
    Karaczan
    Help: 869
    Rate: 1130
    As for games, particularly those from the 8- and 16-bit era, you could say that CRT monitors provided both dithering and anti-aliasing in one, in terms of hardware.
    Pixel-art comparison: character blurred with scanlines on CRT vs sharp blocky pixels on LCD/LED.
    It’s practically impossible to emulate this effect correctly on an LCD screen using any sensible tricks.
    The same applies to the light gun; here, the trick lay in the way the CRT refreshed the image.
    You could cheat the system; all you had to do was ‘shoot’ at, for example, the lamp lighting the room ;)
    CGA graphics on PCs, back in the day, weren’t as garish – for example, with the colour magenta – as they’re perceived today, or even in the VGA era.
    Graphics cards and monitors from the CGA era generated images slightly differently to later standards, and the result was generally quite acceptable.
    But that’s ancient history now ;)
  • CRT museum link for inside views of old televisions
    #29 21939357
    James596
    Level 30  
    Help: 140
    Rate: 575
    That’s true. If you play PlayStation 1 on a modern TV today, the graphics can be quite off-putting, but I remember as a kid that it didn’t look too bad on old tellys.
    It’s much the same with older computer games on low-resolution CRT monitors.
    If anyone fancies having a look at what televisions used to be like, I highly recommend this blog – it’s a sort of virtual museum of CRT televisions, including ‘inside views’. Compared to models from the 70s and 80s, this Sony looks like a poor younger cousin on the inside.
    https://obsoletetellyemuseum.blogspot.com/
  • CRT eye strain compared with modern LCD displays
    #30 21939381
    rosomak19
    Rate: 402
    I remember when, after the old black-and-white Unitra, the 21-inch Curtis colour TV with a remote control and a video recorder made its debut in living rooms. What times those were – the VHS craze... Then came the Panasonic with a 29-inch flat CRT – it was so heavy it made my back ache XD. For the computer, there was a 17-inch CRT monitor with a flat screen – it’s a good thing technology has moved on, because, unfortunately, after just a few hours in front of a CRT, my eyes would get very tired. These days, my LCD TV doubles as a monitor, and I can stare at it for over a dozen hours without feeling tired or experiencing any eye strain.
