Raspberry Pi Pico RP2040 - must-read specs for embedded beginners: 133MHz, 264KB SRAM
FreakStudio 309 0
  • RP2040 Pico board specifications and features
    #1 21946166
    FreakStudio
    Level 4  
    Basic Parameters of the Pico Development Board
    - It adopts the RP2040 microcontroller chip independently designed by Raspberry Pi officials;
    - Equipped with a dual-core ARM Cortex M0+ processor, it features a flexible clock with an operating frequency of up to 133 MHz;
    - It integrates 264 KB of SRAM and 2 MB of on-chip Flash, and features a stamp hole design that can be directly soldered and integrated onto the baseboard independently designed by users.
    - USB 1.1 host and device support;
    - Supports low-power sleep and hibernation modes;
    - It can be recognized as a mass storage device via USB for drag-and-drop program download;
    - Up to 26 multifunctional GPIO pins:
    - 23 digital pins;
    - 3 analog ADC pins;
    - 2 SPIs, 2 I2C interfaces, 2 UARTs, 3 12-bit ADCs, and 16 controllable PWM channels;
    - Accurate on-chip clock and timer;
    - The chip has a built-in temperature sensor;
    - On-Chip Accelerated Floating-Point Library
    - 8 programmable I/O (PIO) finite-state machines for custom peripheral support
    - Flexible user-programmable high-speed IO
    - It can simulate interfaces such as SD card and VGA
    - 3-pin ARM Serial Wire Debug (SWD) port
    - A simple yet highly flexible power supply architecture
    - Can be powered via Micro-USB
    - Can be powered by an external power supply/battery
