Citroen C3 2008 BSI Valeo Wiring for Universal Central Lock and Indicators
nunosimoes32 519 0
  • #1 21327244
    nunosimoes32
    Citroen C3 Exclusive 1.4HDI 2008
    I will post here the photos of my BSI Valeo.
    And if anyone can help me, what is the recommended scheme to connect my universal control unit in the photos.
    My Valeo BSI is very strange, when I connect the 2 brown wires it would supposedly go to the left and the other to the rear in the direction indicators, one on "pin13 green wire" and the other on "pin14 cream color" both black plugs 16-way lamp (PH1) only connects the two left and right lamps at the rear.
    The lamps on the front and sides of the fender do not blink or show any signs of life.
    I'm going crazy with the turn signal lights.
    How is it possible that I can only turn on 2 rear lights?
    Is this version of BSI Valeo different?
    I've already searched several forums on the internet and I can't find any answer to solve the blinker problem...
    I'll leave my VIN here It will be easier to identify if you have access to the correct diagrams.
    The photos of the central scheme can help someone help me choose the correct scheme to connect to "pin 13 Violet" and "pin 15 gray" on the gray 16-way plug PH2.
    And can anyone help me understand why I can only get the turn signals on the rear.
    I'll buy you a beer!
    VIN: VF7FC8HZC29131352
