ESP8266 ESP-01S with DS18B20. ESPEasy does not send temperature to Domoticz.
miecho18 330 0
  • #1 21724699
    miecho18
    IT specialist
    Good morning.
    I have an ESP8266 module (ESP-01S) with a DS18B20 (1-Wire) sensor plugged in. The module programmed in ESP Easy Flasher, firmware ESPEasy_mega-20181029_normal_esp8266_1M (the DS18B20 sensor could not be configured on the newer ones). Once the module is programmed it connects to the WiFi network and I can connect to it by typing the IP address of the module in my browser, I can see the correct temperature reading from the sensor there. I wanted the ESP Mega to send the temperature reading to domoticz. Unfortunately after configuring according to this tutorial domoticz does not show the temperature. The modem is a Huawei B525-232 LTE.
    I will add that I am (as you can probably already see) a layman on the subject.
    Greetings,
    Mieszko.
    Edit: Domoticz is set up on a laptop with Windows 7. I also tried on a laptop with Windows 10 but the situation is unchanged.
