RF Unit Converter
RF Unit Converter
This tool is a unit converter for voltage and power. There is an input for impedance that allows the relationship between power and voltage. For the calculation, Vrms is used.
Impedance
Voltage
Power
RF Unit Converter Introduction
Ohm
The unit for resistance or impedance. Resistance can define the relationship between voltage and current and voltage and power. Based upon ohms law the voltage and current relatinship is:
latex!encoded:base64,ciA9IFxmcmFje3Z9e2l9
and power is
latex!encoded:base64,cG93ZXIgPSBcZnJhY3t2XnsyfX17cn0=
Vpeak - Peak Voltage
Peak voltage of an AC signal is the peak amplitude.
Vrms - RMS Voltage
The Root Mean Square Voltage or Vrms is:
latex!encoded:base64,Vl97cm1zfT1cZnJhY3tWX3twZWFrfX17XHNxcnR7Mn19
μV - Microvolt (RMS)
This value is the RMS voltage in microvolts.
latex!encoded:base64,XG11IFY9XGZyYWN7Vl97cGVha319e1xzcXJ0ezJ9fVxjZG90IDEwXnstNn0=
μV EMF
This value is microvolt with no termination or load.
latex!encoded:base64,XG11IFZfe2VtZn09XGZyYWN7MlxjZG90IFZfe3BlYWt9fXtcc3FydHsyfX1cY2RvdCAxMF57LTZ9
μV PD
This value is microvolt with with a load. When a signal has a matched load then half of the voltage is droped across the load. This value is the same value as uV, The unit is just explicitly defined as having the load.
latex!encoded:base64,XG11IFZfe3BkfT1cZnJhY3tWX3twZWFrfX17XHNxcnR7Mn19XGNkb3QgMTBeey02fQ==
dBuV - dB Microvolts RMS
This unit is the decibel of RMS microvolt.
latex!encoded:base64,ZEJcbXUgVj0yMFxsb2cgXGxlZnQgKCBcbXUgViBccmlnaHQgKQ==
dBuV EMF - dB Microvolts EMF
This unit is the decibel of EMF microvolt.
latex!encoded:base64,ZEJcbXUgVl97ZW1mfT0yMFxsb2cgXGxlZnQgKCBcbXUgVl97ZW1mfSBccmlnaHQgKQ==
dBuV PD - dB Microvolts PD
latex!encoded:base64,ZEJcbXUgVl97cGR9PTIwXGxvZyBcbGVmdCAoIFxtdSBWX3twZH0gXHJpZ2h0ICkg
W - Watts
Watts is a unit of power.
latex!encoded:base64,Vz1cZnJhY3tWX3tybXN9XnsyfX17Wl97b319
mW - Miliwatts
One thousandth of a watt.
latex!encoded:base64,bVc9XGZyYWN7V317MTBeezN9fQ==
μW - Microwatts
One millionth of a watt.
latex!encoded:base64,XG11IFc9XGZyYWN7V317MTBeezZ9fQ==
dBm
dBm is a power measurement and is the decibel of the power in mW.
latex!encoded:base64,ZEJtPTEwXGxvZyBcbGVmdCAoIG1XIFxyaWdodCApIA==
dBuW
dBuW is a power measurement and is the decibel of the power in uW.
latex!encoded:base64,ZEJtPTEwXGxvZyBcbGVmdCAoIFxtdSBXIFxyaWdodCAp
dBuW EMF
dBuW EMF is a power measurement and is the decibel of the power in uW. In a system with no termination or load.
latex!encoded:base64,ZEJtPTEwXGxvZyBcbGVmdCAoIDJcY2RvdCBcbXUgVyBccmlnaHQgKQ==
dBuW PD
dBuW PD is a power measurement and is the decibel of the power in uW. In a system with a matched load.
latex!encoded:base64,ZEJtPTEwXGxvZyBcbGVmdCAoXG11IFcgXHJpZ2h0ICk=
dBpW
dBpW is a power measurement and is the decibel of the power in pW.
latex!encoded:base64,ZEJtPTEwXGxvZyBcbGVmdCAoIFxtdSBXXGNkb3QgMWU2IFxyaWdodCAp
dBpW EMF
dBpW EMF is a power measurement and is the decibel of the power in pW. In a system with no termination or load.
latex!encoded:base64,ZEJtPTEwXGxvZyBcbGVmdCAoIDJcY2RvdCBcbXUgV1xjZG90IDFlNiBccmlnaHQgKQ==
dBpW PD
dBpW PD is a power measurement and is the decibel of the power in pW. In a system with a matched load.
latex!encoded:base64,ZEJtPTEwXGxvZyBcbGVmdCAoXG11IFdcY2RvdCAxZTYgXHJpZ2h0ICk=
