Understanding Static Keyword for C Functions: Usage in Static Void Function_Name (void)
Marek_Gorecki 13333 3
  • #1 9580318
    Marek_Gorecki
    Rate: 30
    Hello;
    I am learning the C language and I came to a program in which there is a function preceded by the word Static. Something like that:
    static Void function_name (void)
    and I just don't understand it completely. I understand the static variable inside the function, but I don't understand marking the function as static.
    tmf
    Help: 2090
    Rate: 2203
    This means that such a function will only be known in the compilation unit (source file) in which it is defined. Due to the fact that its name will be local, it is possible to optimize it better.
    markosik20
    Help: 208
    Rate: 147
    And if you try to call it from another file, the linker will throw an error.
  • #4 9580628
    Marek_Gorecki
    Rate: 30
    Many thanks to both colleagues.
