Is it true that the river stops the storm ?
^Rachel 33364 7
  • #1 11026587
    ^Rachel
    Help: 15
    Rate: 149
    Hello !
    Yesterday there was no storm at my place because everyone said it was stopped by the river , and I don't believe it , what has the river to do with the storm ? What do you think about it ?
  • #2 11026694
    telbod
    Level 32  
    Help: 163
    Rate: 240
    It is not the river itself but the reservoir. It is slow to heat up and slow to cool down. Over a body of water the convective movement of air is different to that over land. In order for such an effect to occur the river must be quite wide, it must not be some kind of "after storm".
  • #3 11028704
  • #4 11028951
    telbod
    Level 32  
    Help: 163
    Rate: 240
    A single discharge does not carry much energy at all. Even if it were possible to store all the energy of the discharge, it would only last for a very short time. The voltage and current are high, but the time is very short. It might be enough for a month, but only to power a single light bulb.
  • #5 11029343
    ankowalik
    Rate: 143
    A river no, but a lake YES. I live on a lake and have often observed the effect,
    so to speak: 1) the storm does not pass, 2) it changes its direction of travel.
    This was most evident when the famous White Scud was moving in from Mikolajki.
    I think it was the jeź. Probardzkie saved my village.
    salute
    andre
  • #6 11029585
    Alfred_92
    Help: 148
    Rate: 706
    ankowalik wrote:
    The river no, but the lake YES. I live on a lake and have often observed the effect,
    This was most evident when the famous White Scud was moving from Mikolajki.
    salute
    andre
    A river too, e.g. the Vistula 60 km from its mouth to the Baltic (it's wide). I know because I live by it and more than once I have seen a storm go perpendicularly towards the Vistula and then something like bounce off it and after some time it came back or moved along the shoreline.
  • #7 11029598
    ankowalik
    Rate: 143
    That's right: WIDE. "My" lake is about 500m.
  • #8 11033479
    Dydelmax
    Help: 654
    Rate: 965
    ankowalik wrote:
    River no, but lake YES.
    It's true.
    It just so happens that my house is surrounded by three lakes:
    Is it true that the river stops the storm ? .
    It's been a long time since there has been a thunderstorm in my locality that has arrived close enough for thunder to be heard 3-4 seconds after the flash. The lakes have a huge impact on this, with the result that most thunderstorms 'go sideways' or end with a few flashes of lightning. It may seem like a thunderstorm should slide between these lakes, but it doesn't (and once a thunderstorm has passed through the lakes, as long as it doesn't 'shoot out' it doesn't leave the area).
The discussion centers around the belief that rivers can influence storm behavior. Several participants argue that while rivers may not directly stop storms, large bodies of water, such as lakes and wide rivers, can affect storm paths and intensity. Observations indicate that storms may change direction or dissipate when encountering significant water bodies. Specific examples include the Vistula River and personal experiences near lakes, where thunderstorms tend to bypass or weaken as they approach these areas.
