Remote Control of Arduino Uno via Ethernet Shield and Router Connectivity
Piotrek50501 5946 14
Can I connect an Arduino Uno with an Ethernet shield to my router and control it from the Internet, for example by opening a web page and switching an LED on and off?
Yes — you can connect an Arduino Uno with an Ethernet shield to your router and access it from the WAN, as long as you configure the router so the device is reachable from outside [#16319058][#16319114] To do that, use port forwarding so the router forwards a selected TCP port to the Arduino’s local IP address; if needed, a DMZ can also expose the device [#16319114][#16351697] On the Arduino side, you do not use PHP or .NET; the Arduino must handle the network requests itself, and everything is programmed in C++ [#16318306][#16319114] The Arduino acts as the server, interprets incoming packets, and returns the HTML page or response itself [#16319114] That page can contain buttons or links that send a new request to the Arduino, which then changes the state of an I/O pin such as an LED [#16319114]
  • Arduino Internet control through router and Ethernet shield
    #1 16300829
    Piotrek50501
    Rate: 29
    I have an arduino uno and I'm going to buy ethernet shield and here I have a few questions. Is it possible to connect the arduino to the router to be connected to the Internet and control it via the Internet? For example, I connect the arduino to the router and leave the house. I connect to the internet, go to the page that I will control the arduino and, for example, by clicking the button I turn on the diode
  • #2 16300876
    tmf
    Help: 2090
    Rate: 2206
    Of course you can. Google a little geo and you'll find Prefabs. What's the problem? At least for fun with the Internet, I would choose a slightly more serious platform. However, for the LED on / off implementation it will be ok.
  • #4 16301252
    Piotrek50501
    Rate: 29
    OK thanks. Is it possible to create pages in asp.net to control this microcontroller?
  • #5 16301291
    tmf
    Help: 2090
    Rate: 2206
    @ Piotrek50501 Have you seen Microsoft release its framework for Arduino? This is not the category of microcontrollers at all.
  • #6 16301370
    Piotrek50501
    Rate: 29
    And is there any microcontroller that Microsoft supports?
  • #7 16302634
    JacekCz
    Help: 760
    Rate: 1464
    There are mini computers with .NET raspeberry class (this is a different edition of the framework, not necessarily everything for a "big" .NET)
    However, I have the impression that you are unclear what the server is, what the client is, and the mindset is a little fluttering.
    At least what you have revealed does not imply that you have thought about it.
  • #9 16303375
    tmf
    Help: 2090
    Rate: 2206
    @mr_slimm When it comes to the possibility of using ASP and .NET, it is probably easier to look for environments supported by this framework and then choose a hardware platform. Plus, you can google your answers in seconds.
  • #10 16318066
    Piotrek50501
    Rate: 29
    Thanks for your help, I have ethernet shield, arduino uno and other parts of building projects with this microcontroller at home. I work a lot in ASP.NET and I am a beginner when it comes to microcontrollers. I also learned PHP and pure HTML code. And I just can't find anywhere how to connect it.
    By doing this:
    1) program the Arduino
    2) connect via ethernet shield to the router
    3) I leave the house and use the arduino by clicking a button on the website, e.g. I turn on the LED at home (primitive)
    Of course, I will have to make a website and upload it to the server. I just don't know in what language to write the page. I already know .NET is out. So what to choose PHP? Java?
  • #11 16318306
    tmf
    Help: 2090
    Rate: 2206
    @ Piotrek50501 Neither of these languages is available on Arduino. Java embedded is, but for much more serious platforms. Everything has to be programmed in C ++. Prefabs are on the net.
  • Can WAN access reach Arduino through a router?
    #12 16319046
    Piotrek50501
    Rate: 29
    Somehow I'm having trouble finding :( When it comes to programming arduino, I know that in truncated C. Problem with choosing the language to write the page communicating with the microcontroller. I guess I won't find out what I want :( Maybe in diffrent way. In sequence. I want to connect the arduino to ethernet shield and router. Is it possible to gain access from the outside with this configuration? So from the WAN?
    ditomek
    Help: 24
    Rate: 230
    yes, as long as you configure your router so that the device in your home (no matter if the arduino or some other computer) will be visible from the outside.
    Port forwarding and custom Arduino HTTP server implementation
    #14 16319114
    tmf
    Help: 2090
    Rate: 2206
    To tell you the truth, it's hard for you to answer because I don't quite know what you mean. I'll start at the end. To get to the WAN, you can - to do this you need to use the normal network mechanisms - forward the selected port, so that the router will forward all references to it to a specific address in the local network. This is a feature of the router and whether the target receiver is Arduino or PC doesn't matter.
    As for the language of the page communicating with the MCU, I don't know what you mean. Arduino acts as a server here. Normally you would have an httpd server running on it, which interprets the inquiries sent from the network and possibly fires the code responsible for executing PHP, .NET code etc. You do not have an httpd server on arduino, you have to program everything yourself from scratch. So you have nothing but the bare packets that come from the client, you have to interpret them and respond to them by sending the code of the html page. On this page you can put anything that, when pressed, will generate a new query to the server (Arduino) that you need to program and as a result you will get a change in the state of some IO pin.
  • #15 16351697
    alemateusiek
    I recommend using a separate PHP and Mysql server for such tasks. If you are behind Nat you need to redirect the necessary TCP ports in the router configuration or simply set the DMZ to the address of the local server so that you can contact it outside the local network.
The discussion revolves around controlling an Arduino Uno via an Ethernet shield connected to a router, enabling remote access over the Internet. Users confirm that it is feasible to connect the Arduino to a router and control it remotely, such as turning an LED on or off through a web interface. Various projects and resources are suggested for reference. The author inquires about using ASP.NET for web development, but responses indicate that Arduino programming is primarily done in C++. For remote access, proper router configuration, including port forwarding, is necessary. It is also noted that Arduino can act as a server, but it requires custom programming to handle HTTP requests and responses.
