STM32F4 Programming: HAL_UART_RxCpltCallback Function Executed Once on XNUCLEO-F401RE Plate
rogeros 10518 8
  • HAL_UART_RxCpltCallback fires only once on UART reception
    #1 16331766
    rogeros
    I started my adventure with STM32F4 programming.
    I have purchased the XNUCLEO-F401RE plate (compatible with NUCLEO-F401RE)
    and I took the course at this link
    http://forbot.pl/blog/artykuly/programowanie/kurs-stm32-f4-7-komunikacja-przez-uart-id13472
    Well, I did the same step by step as instructed in the course, but for me the program performs the function
    HAL_UART_RxCpltCallback only once, then the main program loop still works and sending another
    mark to UART has no effect.
    Below is the code. The code also includes an SPI configuration because my project
    it is also to use this way of communication.
    In the main function, I call
    HAL_UART_Receive_IT (& huart2, & Received, 1); without which receiving a character from UART does not go to callback at all.
    In the main function and in HAL_UART_RxCpltCallback I assigned myself the auxiliary variables Temp and Temp2 which
    I watch in STM Studio.
    The effect of the code below.
    The main loop works all the time.
    HAL_GPIO_TogglePin (LED2_GPIO_Port, LED2_Pin); - turns on and off the LED
    You can see in STM Studio how the Temp variable is being incremented.
    After sending any character by UART:
    In STM Studio, I can see the Temp2 value being increased by 1
    Another LED lights up - HAL_GPIO_TogglePin (LED1_GPIO_Port, LED1_Pin);
    Once again I see how the Temp2 value increases by 1 and is currently 2.
    The Received variable receives a valid value from the UART
    the end.
    Sending more bytes to the UART changes nothing in the interrupt :(
    The LED1 diode is lit continuously, the variable Temp2 is always equal to 2.
    I am asking for help to a beginner.
    Regards and thank you in advance.
    Code: C / C++
  • #2 16331827
    rajszym
    Help: 48
    Rate: 18
    rogeros wrote:
    Code: C / C++
    Should the HAL_UART_Receive_IT function be sure to pass the pointer address to the UART_HandleTypeDef structure?
  • #4 16331949
    rogeros
    Thank you Mr. Piotr for your answer.
    As I learn the fastest with examples, do you have a piece of code that supports SPI in an interrupt?
    But anyway, I'm bothering me why the HAL_UART_RxCpltCallback function is only performed once.
  • #5 16331958
    rajszym
    Help: 48
    Rate: 18
    I will ask again.
    grko
    Help: 247
    Rate: 141
    It shouldn't be. My friend @rogeros Read carefully the warnings from the compiler or at least post the compilation log here. This will greatly facilitate the resolution of these types of problems. The type of the second parameter passed to this function also generates a warning (but this is partly the fault of API masterful design from ST ...).
  • #7 16333064
    rogeros
    Thank you very much for pointing out the mistake. There is still a lot of learning ahead of me.
    After changing the call from
    HAL_UART_Receive_IT(&huart2, &Received, 1);
    on
    HAL_UART_Receive_IT(&huart2, Received, 1);
    The UART started receiving the interrupt data nicely as I wanted.
    But I already know where my mistake came from. Well, in the course I mentioned in my
    the first post was given two examples.
    One shows the reception of one byte and the variable was declared there
    uint8_t Received;
    and appealed
    HAL_UART_Receive_IT (huart2, & Received, 1);
    in case of receiving several bytes, an array was declared
    uint8_t Received [10];
    and already appealed
    HAL_UART_Receive_IT (huart2, Received, 1);
    My no caution. :( but for the future, do you know a course that would teach me yet?
    when to use pointers, vectors, etc ?? So that I could spot such mistakes myself?
    grko wrote:
    Buddy @rogeros, carefully read the warnings from the compiler
    Thanks also for your help. I'm working on System Workbench for STM32 and after writing some code
    I clicked RUN. In Eclipse, no Warnings appeared in the "console" tab, so I thought that
    everything is okey. After switching to the Problems tab, I actually noticed the messages about which
    you mentioned. Thank you because now I will know to check in there.
    This is perhaps one more question.
    As I mentioned, I use System Workbench for STM32 and XNUCLEO-F401RE with an external programmer.
    When I press RUN I have to manually reset the system for the program to load. (when the programmer starts "flashing"
    I press reset). After uploading the program, I also have to press reset to make the newly uploaded program start.
    If I don't do this, the message "Unable to reset target" appears in the console
    In the STM32 ST-LINK Utility program, in the settings there is an option for the programmer to reset automatically
    system before programming (and it works ... the programmer resets NUCLEO before uploading) so I think it
    System Workbench for STM32 configuration issue but I can not find programmers to configure, let alone
    ST-LINK.
  • #8 16333079
    grko
    Help: 247
    Rate: 141
    @rogeros Colleague @raszy it was about the first parameter passed to HAL_UART_Receive_IT, i.e. huart2. In my opinion, huart2 should be there instead of & huart2 (as the function parameter covers the global symbol huart2). The second parameter was also passed in the way that generates warning. Also, remove volatile from the Received array declaration. It won't do any good.
  • #9 16333150
    rogeros
    Ie The HAL_UART_Receive_IT function call is in two places.
    Line 72 and 242.
    Ultimately, such a code does not trigger any "warnings".
    By actually changing the first parameter in the called function on line 72
    made the interrupt work properly. However, if I deleted
    & from the call to line 242 the compiler crashed an error.
    So I have to read when pointers and vectors are used and when not.
    EDIT: I thought synrax was displaying line numbers :(
    Code: C / C++
The discussion revolves around an issue faced by a user programming the STM32F4 microcontroller on the XNUCLEO-F401RE board, specifically regarding the HAL_UART_RxCpltCallback function, which was only executing once. The user followed a course but encountered problems with UART data reception. Responses highlighted the importance of correctly passing parameters to the HAL_UART_Receive_IT function, particularly the UART_HandleTypeDef structure. After correcting the pointer usage in the function call, the user successfully received UART data. Additional inquiries about SPI communication and learning resources for better understanding of pointers and arrays were also made.
