Garett Expert Smartwatch: Battery Life, 1.3MHz 4-Core Processor, 4GB RAM, AMOLED 400x400, 2M Camera
Ben1950 12924 4
  • #1 16735286
    Ben1950
    does anyone have such a smartwatch? Equipment very well equipped (4-core processor 1.3 MHz, 512 Mb ROM, 4 Gb RAM, AMOLED 400x400, 2M camera, 3G, WiFi, BT, SIM, heart rate monitor, pedometer, receiving and making phone and SMS calls, voice recorder, audio playback, internet, etc.). With such rich equipment, you can't expect a long battery life (400mAh), but when you turn off everything without SIM (except BT), the watch will last 18 hours. to the day (manufacturer gives up to 48 hours). This is not enough for me (3-4 days would be satisfactory). I don't know if SINWEAR synchronization software consumes so much energy? I tried to use different but none want to pair. Does anyone use other software - which one?
    \greetings
  • #2 16737971
    marek216
    Help: 1077
    Rate: 932
    400mAh is the cell capacity already stretched, 48h of the manufacturer is also an optimistic option with such hardware configuration.
    If you have BT turned on for 18 hours, jump for joy that it lasts so long. Well, unless you believe that the energy for gadgets comes from the environment.
  • Bluetooth appears to be the main battery drain
    #3 16738121
    Ben1950
    Thanks for comment. I am aware of the energy demand and it seems that BT is heavily abusing it. Recently I tested a battery without BT with a SIM card inserted and with 3 -4 short phone calls. daily battery lasts 51 hours. and I have 26% more energy. It's probably not bad. I think the battery "recovered" after a dozen or so recharges - we'll see what happens next.
    Does anyone in this smartwatch use software other than SINWEAR?
  • #4 17211284
    MarOSA_PL
    I plan to buy this smartwatch and I wonder if this battery with BT turned off after a long time user lasts about 48 hours? What about when GPS is on?
    Would you buy this equipment again? Is somehow satisfactory performance?
    Thank you in advance for the information.
  • #5 17211399
    Ben1950
    I currently use SmartWatch without a BT and a SIM card (although it's a good thing - talking like James Bond to the wrist!). Without GPS enabled, the watch lasts for 2 days, GPS reduces by a few nice hours. It is made very well, the screen is good quality (although the letters are very small), the memory could be larger, but I do not install any frills - you only need to get used to charging every 2-3 days. The quality of the webcam can be said to be good for quick photos.
    I generally fond. Greetings.
