Calculating DC Electric Motor Power for Bluetooth-Controlled Car: Formulas and Patterns
Euxinus 5079 2
  • #1 16743834
    Euxinus
    Hello gentlemen and ladies.
    I am inspired and I am trying to build a bluetooth-controlled car. I have some knowledge, but I have a question for you, because you probably know more than me. And I don't want to do it anyhow.
    The car is to be powered by a DC electric motor. I would like to know how to calculate the necessary engine power (needed torque, rotational speed, etc.) (or rather 2 each engine for one wheel), if there is any formula, I would ask for help.
    Data that I initially managed to estimate it.
    Weight about 7 kg.
    Max speed 30-50 km / h (such +/- only temporarily)
    The maximum dimensions are 30x25x15.
    I mean mainly patterns, not ready engines. Other parameters, such as the size of the wheels, I would choose later. Standard resistance to motion.
  • #3 16744041
    _jta_
    Electronics specialist
    Help: 3201
    Rate: 4205
    Remember that the power of the electric motor depends on the RPM - calculate the torque from the nominal power and nominal RPM and do not count on a bigger one.
