Google Chrome Default Search Engine Stuck on Chromesearch.today - ADW, Malwarebytes Results
Geber85 4575 6
  • Chrome search engine locked by chromesearch.today hijacker
    #1 16766727
    Geber85
    Rate: 18
    Hello, I have a problem with Google Chrome. I can't change the default search engine. It is some Web chromesearch.today:
    The check box next to "Search engine used in the address bar" is not active. It looks like this: (1) Google Chrome Default Search Engine Stuck on Chromesearch.today - ADW, Malwarebytes Results
    ADW cleaner and Malwarebytes Anti-Malware have not detected anything. Is this a "hard" virus or spyware etc. to detect? How to fix it?
  • #2 16766773
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Include the required scan logs from FRST (addition and frst.txt) in the attachment.
  • #3 16766790
    Geber85
    Rate: 18
    Logs attached.
    • Addition.txt (30.15 KB) You must be logged in to download this attachment.
    • FRST.txt (40.03 KB) You must be logged in to download this attachment.
  • #4 16766862
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Next to frst.exe, create the Fixlist.txt file with the contents:
    GroupPolicy: Chrome Group Policy detected
  • #5 16766889
    Geber85
    Rate: 18
    Thank you very much for help. So it wasn't a virus ??? I'm afraid that maybe there was some "shit" left on the computer. Can I delete these frst.exe and Fixlist.txt files now or do they have to remain on the computer?
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    It's just a swapped search engine and blocked the ability to change in Chrome, nothing serious.
    You can delete C: \ FRST, frst.exe and Fixlist.
  • #7 16766942
    Geber85
    Rate: 18
    Thanks again for your help.
The discussion revolves around a user experiencing issues with Google Chrome, where the default search engine is set to "chromesearch.today" and the option to change it is disabled. The user has run ADW Cleaner and Malwarebytes Anti-Malware without detecting any threats and is concerned about potential malware. Responses suggest that the issue is not a serious virus but rather a configuration problem with the search engine settings. The user is advised to create a Fixlist.txt file to address the Group Policy issue detected in Chrome. After following the instructions, the user is reassured that it is safe to delete the FRST files used for the fix.
