Windows 7 HP 64 bit SP1 ISO - Needs an ISO file for Windows 7 HP 64 bit SP1
marcin21t 21027 9
Gdzie pobrać polski obraz ISO Windows 7 Home Premium 64-bit z Service Pack 1?
Jedna z odpowiedzi wskazuje na polski obraz Windows 7 64-bit SP1 pod adresem basewin.pl/7mod.html [#17031229] Ten plik jest już w języku polskim, więc nie trzeba szukać dodatkowej „łatki” językowej [#17031351] Jeśli jednak chodzi o pakiety językowe Windows 7 SP1, to są one dostępne tylko dla Windows 7 Ultimate SP1 i można je zainstalować z sekcji aktualizacji opcjonalnych Windows Update, a nie z WSUS ani z Microsoft Download Center [#17031271]
  • #1 17031151
    marcin21t
    Rate: 16
    Hello. I am looking and I can not find ...
    Windows 7 Home Premium 64 bit with a loaded SP1 version in PL version.
    Does anyone have such an ISO and could throw on some hosting or provide a link where you can download it?
  • #3 17031217
    marcin21t
    Rate: 16
    Are they from SP1?
  • #4 17031220
    safbot1st
    Help: 2719
    Rate: 1585
    I'm guessing you're restoring the system on your computer HP which model you did not provide?
    Do not Recovery work?
  • #5 17031223
    Pedros050
    Help: 2471
    Rate: 3926
    @ marcin21t As you write to me, of course it is.
  • #7 17031264
    marcin21t
    Rate: 16
    Thanks, one more question, changing the language in the same version, has someone file for the crack? HP 64 bit SP1
  • #8 17031271
    Pedros050
    Help: 2471
    Rate: 3926
    The Windows 7 Service Pack 1 language packs are available on computers running Windows 7 Ultimate Service Pack 1 You can install Windows 7 language packs only from the optional update section of the Windows Update site. However, these language packs are not available in Windows Server Update Services (WSUS) or as part of the Microsoft Download Center.
  • #9 17031351
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    @ safbot1st HP = Home Premium, not Hewlett Packard.
    @ marcin21t what I gave is in Polish, so why change your language?
  • #10 17031389
    Matuzalem
    Help: 1653
    Rate: 1101
    marcin21t wrote:
    Are they from SP1?
    Even you did not want to click on the file to download. How do I know? - Please, guess.
    The same applies to the question to the link given by Mr Kolobos. And then the grudges that "nobody wants to help." And yet it is not aversion, but only a lack of formal qualifications to fight with ... illiteracy.
    Doradztwo podatkowe
    Wilczyńskiego 25/13, Olsztyn, 10-686
The discussion revolves around a request for an ISO file of Windows 7 Home Premium 64-bit with Service Pack 1 (SP1) in Polish. Users provide links to potential sources for the ISO, including a Microsoft forum and a specific website. There is a query about the compatibility of the provided links with SP1, and a follow-up question regarding changing the language of the installation. It is noted that language packs for Windows 7 can only be installed on Windows 7 Ultimate SP1 through Windows Update. The conversation also touches on the distinction between HP as a model designation and Hewlett Packard as a brand.
