[Solved] MyPhone Hammer Energy Notifications on the icons are not displayed.
13Rycerz 7035 7
  • #1 17075782
    13Rycerz
    Rate: 9
    I have a problem with a smartphone (android 7.0), namely the number of missed calls does not appear next to the phone icon (phone application). The same problem occurs with messages. I don't want to change the launcher because it's not my smartphne, I'm just trying to help a friend.
    Do you have any ideas?
    I will add that it is impossible (I think) to clean the application data because it is only turned off, force stop.
    Added after 51 [minutes]:
    Someone something?
    Because really nwm what to do with it and I've tried many things.
    nutergsm
    Help: 1034
    Rate: 1665
    Have a friend perform a hard reset or reload the firmware.
  • #3 17075969
    13Rycerz
    Rate: 9
    What about something less drastic?
    Is it just impossible?
    Added after 8 [hours] 11 [minutes]:
    Hard reset did not help and the firmware is factory.
    Any more ideas?
  • #4 17076421
    nutergsm
    Help: 1034
    Rate: 1665
    Report to the manufacturer and see what they reply.
    draggs
    Rate: 11
    Download from the store play install button unlocker. Install afterwards Download new dialer. Type in play DIALER in the store search and choose which one suits you.
    To clear the data, you must first press force stop. You wait for a while, then you click on the memory and then you can clear the data, etc.
  • #6 17079257
    13Rycerz
    Rate: 9
    This is probably the best idea.
    Thanks draggs!
    draggs
    Rate: 11
    I would still try to clear his cache by recovery.
  • #8 17079262
    13Rycerz
    Rate: 9
    I did as my colleague draggs wrote.
The discussion revolves around a MyPhone Hammer Energy smartphone running Android 7.0, where the user is unable to see missed call and message notifications on the respective icons. The user seeks assistance without changing the launcher, as the device belongs to a friend. Suggested solutions include performing a hard reset, reloading the firmware, and downloading a new dialer app from the Play Store. Additionally, clearing the app cache through recovery mode and ensuring proper data clearing procedures were also recommended. Despite attempts, the user reported that the hard reset did not resolve the issue.
