Telefunken TE32472S27TXD Update: Vestel 17MB140, MSD92LHSW2 Processor, VES315SW-2D-N13 Panel
sergioetzi 15159 6
  • #1 18253132
    sergioetzi
    Rate: 17
    Good morning everyone I'm looking for an upgrade for a Telefunken TV model TE32472S27TXD
    SCHEADA VESTEL 17MB140 PROCESSOR MSD92LHSW2.006F WITH PANEL VES315SW-2D-N13
    REMAINS THE WRITTEN ON THE PANEL BUT NOT AWAY
    DISCOVER THE TV AND A TELEFUNKEN MOD. TE32472S27TXD
    Aquario_blue
    Level 19  
    Help: 41
    Rate: 155
    Extract the files to a usb pen, with the lcd unplugged, insert the pen into the lcd.
    Press and hold the "ok" key on the remote control while turning on the lcd and the standby led starts flashing fast, wait for the lcd to restart
    • 17MB140-core-arizanotlari.rar (12.19 MB) You must be logged in to download this attachment.
  • #3 18255061
    sergioetzi
    Rate: 17
    hi thanks i tried the file does not work
    telefunken TE32472S27T
    pannello VES315SW-2D N13
    processore MSD92LHSW2-006F
  • #4 18258516
    Aquario_blue
    Level 19  
    Help: 41
    Rate: 155
    I'm sorry, I forgot that the folder has two files, you have to update twice, one file at a time, first the file "VESTEL_D1_Plus_TMG.bin" and then "VESTEL_D1_Plus_PNL.bin"
  • #5 18258531
    sergioetzi
    Rate: 17
    ciao ho risolto ho programmato 25q128 col programmatore poi ho inserito nella usb il file sono entrato nel service ho spento il tv riacceso ha funzionato perfettamente grazie per la disponibilità data
  • #6 20092517
    annavivaldi57
    Level 4  
    Risolve gli eventuali problemi con LCN ??
  • #7 21853244
    mszava949
    Udv keresek vestel 17mb140 firmwaret
Discussion about updating a Telefunken TE32472S27TXD TV with Vestel 17MB140 mainboard, MSD92LHSW2.006F processor and VES315SW-2D-N13 panel. The suggested recovery procedure was to extract the firmware files to a USB drive, disconnect the LCD, insert the USB, and power on while holding the OK key on the remote until the standby LED flashes and the TV restarts. When the first attempt failed, it was clarified that the package contains two separate update files, VESTEL_D1_Plus_TMG.bin and VESTEL_D1_Plus_PNL.bin, which must be flashed one after the other. The issue was ultimately resolved by programming the 25Q128 SPI flash with a programmer, then loading the USB file and entering service mode; after power cycling, the TV worked correctly.
