Seeking Firmware for 17MB130S VES Mainboard for TELEFUNKEN TE49292S31Y2P Black LED TV
Dpegea 17922 12
How can I find firmware for the 17MB130S VES mainboard in a TELEFUNKEN TE49292S31Y2P TV?
Firmware downloads were shared for the 17MB130S Telefunken 49" board, although they are for different models, so they should be tried as possible matches [#18960030] One reply provided three Yandex Disk links and noted that all are for 17MB130S Telefunken 49" sets with different models [#18960030] Another reply offered a 163 MB package containing full NAND and SPI images and said to try it [#18969958] A later reupload was also posted via file.fm [#19350026] If the issue is only picture-related, one contributor said it may be solvable with the panel profile and mentioned having a profile for N12 but not N11 [#20421855]
  • #1 18917760
    Dpegea
    I am looking firmware for 17MB130S VES mainboard
    Model TV : TELEFUNKEN - TE49292S31Y2P - Black TV - LED TV – LED
    Manufactured by VESTEL Model VES490QNDL-2D-N11
    28012524890135 ( 23404224 ) CM VES49QNDL-2D-N11-PL49262_95_WORJSB
    LED screen technology
    Screen size 49 inches , Screen size 124 cm, Aspect ratio 16:9 screen HD Full HD
    Res. Horizontal - 3,840 pixels x Res. Vertical - 2,160 pixels
    Thanks for your cooperation
  • #2 18958031
    neo cambell
    Level 19  
    Help: 23
    Rate: 111
    why you looking firmware ?
    you have restart problem ?
  • #4 18968611
    samsi3102
    Help: 15
    Rate: 204
    WHAT PROBLEM FRIEND
  • #6 19103070
    lekronoe
    Hello, can you re-upload the firmware?
    Thank you.
  • #7 19269625
    rhoct
    Rate: 10
    please re upload the firmware
  • #8 19349781
    lekronoe
    @arizanotu @ promo7uk
    Hello again,
    can you please reupload the firmware?
    Thank you.
    auto translate:
    Welcome back,
    can you reload the software?
    Thank you.
  • #10 20032476
    mamamiya
    merci bocoup a tous
  • #11 20421535
    mario emme
    yokoono51 wrote:
    Saluto, a tutti gli Amici, Amico ho scaricato il tuo file, Grazie x notizia mi sono Iscritto su >File.Fm< per poterlo scaricare.
    Agg. dalle parti nostre in uso su questo Mod. HITACHI 49 HK6001, Saluti
  • Panel profile may fix the image issue
    #12 20421855
    yokoono51
    Help: 176
    Rate: 321
    yokoono51 wrote:
    Saluto, a tutti gli Amici, Amico ho scaricato il tuo file, Grazie_ x notizia mi sono Iscritto su >File.Fm< per poterlo scaricare.
    Se hai problemi con l'immagine, puoi risolverli con il profilo del pannello. Se non conosci la procedura, dillo. Ho un profilo del pannello ma è per N12 non N11. vuoi provare?
  • #13 20421931
    mario emme
    Certamente, si tratta più' di Curiosità tecnica, che niente, io sono un vecchio riparatore, ma non con lo stato avanzamento dell'età, + anni di servizio Grazie a vostra disposizione .
The discussion revolves around the search for firmware for the 17MB130S VES mainboard used in the TELEFUNKEN TE49292S31Y2P Black LED TV, manufactured by VESTEL. Users inquire about the reasons for needing firmware, with some suggesting potential issues like restart problems. Several links to firmware files for different models of the 17MB130S mainboard are provided, along with requests for re-uploading firmware due to broken links. Additionally, there are mentions of panel profile solutions for image issues, indicating a technical interest in troubleshooting and repair.
TL;DR: 17MB130S owners: a 163 MB full NAND+SPI dump is shared — "163MB FILES FULL NAND AND SPI" — with a direct link for Telefunken 49-inch sets. Use it to recover boot issues and match panel profiles. [Elektroda, promo7uk, post #18969958]
Why it matters: This FAQ helps Vestel-based Telefunken owners fix boot loops and image errors fast with proven community files.
Where can I download a full NAND+SPI dump for 17MB130S?
A member shared a 163 MB recovery set containing full NAND and SPI dumps. “163MB FILES FULL NAND AND SPI.” Download: https://easyupload.io/znsqtz. Use this when the TV is bricked or stuck in a boot loop. It targets 17MB130S used in Telefunken 49-inch variants. [Elektroda, promo7uk, post #18969958]
What exact model and panel details should I match before flashing?
Match the set to Telefunken TE49292S31Y2P with Vestel panel VES490QNDL-2D-N11. Specs listed: 49 inches (124 cm), 16:9, 3840×2160. Align firmware and panel profile to these identifiers for best results. [Elektroda, Dpegea, post #18917760]
How do I fix wrong colors, mirrored image, or no image after flashing?
Apply the correct panel profile for your panel variant. “Se hai problemi con l’immagine, puoi risolverli con il profilo del pannello.” How-To: 1. Check your panel label (N11 vs N12). 2. Obtain the matching panel profile. 3. Apply that profile as advised by the contributor. [Elektroda, yokoono51, post #20421855]
Will these images work with Hitachi 49HK6001 or similar Vestel-based sets?
One user reported using the shared file with a Hitachi 49 HK6001 in their area. Cross-brand compatibility exists on Vestel boards, but match the panel profile. [Elektroda, mario emme, post #20421535]
Why are users requesting re-uploads of the firmware?
Members asked for re-uploads when earlier links weren’t accessible. Example: “can you please reupload the firmware?” This thread includes replacement mirrors to help. [Elektroda, lekronoe, post #19349781]
Does a restart loop point to firmware issues on 17MB130S?
Yes. Boot-loop restarts can indicate corrupted storage. The thread provides a 163 MB full NAND+SPI dump to recover such cases. Flash both memories to restore stability. [Elektroda, promo7uk, post #18969958]
If my panel is N12, not N11, what should I do?
Use an N12 panel profile. A contributor explicitly noted having an N12 profile, not N11. Using the wrong profile can cause image issues or misalignment. Ask for the correct profile if unsure. [Elektroda, yokoono51, post #20421855]
How do I request or apply the panel profile from the thread?
Reply to the contributor offering help and state your panel variant. They offered guidance and an N12 profile. Follow their instructions to apply it after flashing. [Elektroda, yokoono51, post #20421855]
What resolution and aspect ratio should I expect after recovery?
The OP’s set lists 3840×2160 resolution at a 16:9 aspect on a 49-inch (124 cm) panel. Verify your panel tag matches before testing images. [Elektroda, Dpegea, post #18917760]
Are these files for USB update or for programmer flashing?
The shared package is a full NAND and SPI dump, suitable for programmer-based recovery, not just a USB update zip. It targets deep faults and boot failures. [Elektroda, promo7uk, post #18969958]
