[Solved] Renault Premium 450 DXI: Understanding FUEL SUPPLY FAULT Error - Cause & Solutions
skorpionkolo 26082 6
  • #1 19316611
    skorpionkolo
    Rate: 24
    I got a FUEL SUPPLY FAULT error. Which means?
  • #2 19316785
    arti1987
    Help: 36
    Rate: 333
    This is a MALFUNCABLE OIL FAULT. It follows that you have low fuel pressure on the filter. The cause may be a clogged filter or a dragon. Valve in the head. Fuel pump . Leak in the system. Sensor itself malfunction. Ideally, about 3 bar should be on the free ones. The fault lights up if the power supply drops below 2 bar
    stanisławpiotr
    Help: 211
    Rate: 832
    Info about the Renault display icons.
    • Renault Premium 450 DXI: Understanding FUEL SUPPLY FAULT Error - Cause & Solutions P1070258.JPG (94.39 KB) You must be logged in to download this attachment.
  • Low fuel pressure from clogged filter or leak
    #4 19325699
    technologiaforda
    Help: 8
    Rate: 14
    arti1987 wrote:
    This is a MALFUNCABLE OIL FAULT. It follows that you have low fuel pressure on the filter. The cause may be a clogged filter or a dragon. Valve in the head. Fuel pump . Leak in the system. Sensor only malfunction. Ideally, about 3 bar should be on the free ones. The fault lights up if the power supply drops below 2 bar
    Replace the Fuel Filter with a new one. Check the Fuel Lines for pinching
    The described error message gives the fuel fault.
  • #5 19327438
    skorpionkolo
    Rate: 24
    I changed the fuel filters. unfortunately it did not help.
    The message appears after a while as jade is loaded.
    It can go out empty.
  • #6 19327595
    technologiaforda
    Help: 8
    Rate: 14
    it remains to go to the computer and diagnose the error ...
    I bet that it may still be broken somewhere on the ankle, the link is tarnished from salt and mud, there is no full signal transition
  • #7 19444847
    skorpionkolo
    Rate: 24
    Replacing the unit injector and adjusting the valves helped.
The FUEL SUPPLY FAULT error in the Renault Premium 450 DXI indicates low fuel pressure, potentially caused by a clogged fuel filter, fuel pump issues, leaks in the system, or sensor malfunctions. Initial troubleshooting steps include replacing the fuel filter and checking fuel lines for pinching. If the error persists, further diagnostics with a computer may be necessary to identify electrical issues or faulty components. A successful resolution was reported after replacing the unit injector and adjusting the valves.
