[Solved] Need Toshiba 40L7335D Software 7.1.92.61.01 - Can't Find Online, Seeking Share
Cobra 28974 7
  • #1 19653409
    Cobra
    Help: 6
    Rate: 64
    Good morning
    I need software 7.1.92.61.01., I can't find it anywhere, I don't think it's on Toshiba's website anymore.
    Maybe someone has it on their hard drive and will share.
  • #3 19653439
    Cobra
    Help: 6
    Rate: 64
    In this post there is only soft for flash memory, but there is no soft for USB.
  • #5 19653462
    billobirillo
    Help: 338
    Rate: 794
    software 7.1.92.61.01.1
    • 719261011.part2.rar (50 MB) You must be logged in to download this attachment.
    • 719261011.part3.rar (45.32 MB) You must be logged in to download this attachment.
    • how to upgrade.pdf (338.37 KB) You must be logged in to download this attachment.
    • 719261011.part1.rar (50 MB) You must be logged in to download this attachment.
  • #6 19653650
    Cobra
    Help: 6
    Rate: 64
    I have a problem with downloading this software, can someone check if it can be downloaded? is there any problem with me.
  • #7 19653701
    RPAS
    Help: 128
    Rate: 238
    It normally pulls, you start with part1. Check if you will have PL language in this downloaded software.
  • #8 19654011
    Cobra
    Help: 6
    Rate: 64
    The TV works :)
    To sum up, after uploading the software from @billobirillo TV works properly. I was able to upload it only on the original version of the firmware in flash memory.
    Thank you all for your help and commitment.
    Thank you billobirillo.
A user is seeking the Toshiba software version 7.1.92.61.01, which is no longer available on the Toshiba website. Several forum members provide links to related posts, but some clarify that the available software is for flash memory and not USB. A user successfully downloads the software and confirms that the TV operates correctly after installation, specifically noting that it worked only with the original firmware version in flash memory. The community expresses gratitude for the assistance provided.
