Urgently Needed: Firmware for Model LC-43CFE6131E (Serial A43CF6131EB38396115750802037)
amocanita 1701 6
  • #1 20057616
    amocanita
    I need urgently firmware for Model lc-43cfe6131e Serial A43cf6131eb38396115750802037 .Thank in advance!
  • #2 20060875
    elmo071
    Level 30  
    Help: 167
    Rate: 801
    Insert a picture of the tv nameplate.
  • #3 20093690
    querij
    Help: 42
    Rate: 227
    For equipment with A43CF6131EB383, the software is attached
    • sw_upgrade_V1.19_20160206_152452.zip (108.42 MB) You must be logged in to download this attachment.
  • #4 21878794
    kingkhaled1948
    @ElektrodaBot I need urgently firmware for Model lc-43cfe6131e Serial A43cf6131eb38396115750802037. Thank in advance!
  • Firmware already attached for serial prefix A43CF6131EB383
    #5 21878799
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    kingkhaled1948 wrote:
    @ElektrodaBot i need urgently firmware for Model lc-43cfe6131e Serial A43cf6131eb38396115750802037 .Thank in advance!
    Users posts before the question:
    Data: 08/07/2022
    The good news is that, based on the thread history, the correct software for your set was already attached in this topic.
    Direct answer
    For TV:
    - Model: LC-43CFE6131E
    - Serial: A43CF6131EB38396115750802037
    the important matching identifier is the serial prefix:
    - A43CF6131EB383
    and in the earlier post in this thread there is information:
    - “For equipment with A43CF6131EB383, the software is attached”
    So most likely that attachment is the firmware intended for your exact chassis/variant.
    Important technical note
    For these Sharp/UMC sets, the model name alone is not enough. The firmware must match at least:
    - model family,
    - serial prefix / production variant,
    - sometimes mainboard/panel combination.
    Your serial begins with exactly the same prefix that was mentioned in the earlier post, which is a strong indication that this is the proper package.
    What you should do
    1. Go to the attachment added in this topic on 08/07/2022.
    2. Download the firmware archive.
    3. Prepare a USB stick:
    - preferably 2–8 GB
    - formatted to FAT32
    4. Extract the archive.
    5. Copy the firmware file(s) to the root of the USB drive.
    6. With the TV disconnected from mains:
    - insert USB,
    - press and hold the power / standby button on the TV itself,
    - reconnect power,
    - keep holding for about 10–15 seconds until the update starts.
    Very important warning
    Do not flash firmware from another LC-43CFE6131E unit if the serial prefix differs. That can cause:
    - no image,
    - inverted image,
    - wrong colors,
    - boot loop,
    - complete software corruption.
    If the attachment is missing or you cannot access it
    Then provide:
    - a clear photo of the nameplate,
    - a photo of the mainboard,
    - the exact symptom:
    - dead set,
    - stuck on logo,
    - blinking LED,
    - backlight only,
    - no sound/no picture.
    Then it is possible to verify whether USB update is enough or whether the SPI/eMMC memory must be programmed directly.
    Practical recommendation
    Because this is urgent, first check the attachment already posted for A43CF6131EB383.
    That is the most relevant lead for your exact serial.
    If you want, I can also help you with:
    - checking whether the extracted files look correct,
    - identifying the proper USB upgrade procedure,
    - or recognizing from photos whether your board needs USB firmware or programmer write.
  • #6 21878802
    kingkhaled1948
    @ElektrodaBot I need the driver for this model LC-43CFE6131E
    And A43CF6131EB03I 36104651100919
  • Need nameplate photo to verify firmware variant
    #7 21878803
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    Data: 06/04/2026
    Treść: @ElektrodaBot i...
    Initial assessment
    For this Sharp TV, what you need is firmware/software, not a PC “driver.”
    In topic 3899433, the only attachment visible from the earlier discussion is:
    - posted on 08 July 2022
    - explicitly described as “For equipment with A43CF6131EB383, the software is attached.” (elektroda.com)
    Direct answer
    Your current serial appears to be:
    - A43CF6131EB03I 36104651100919
    That does not match the earlier firmware prefix A43CF6131EB383 from the attachment in this thread. So I do not recommend using the previously attached file for your set. (elektroda.com)
    Why this matters
    With these Sharp/UMC TVs, the model number alone is not enough to choose firmware safely. The serial prefix often identifies a different hardware variant. In practice, a mismatched package can leave you with a non-booting TV, wrong panel initialization, or no image.
    So for your set, the key point is:
    - old attached file: for EB383
    - your TV: EB03I or possibly EB031 — please verify whether the last character is the letter I or the digit 1
    What I can confirm from the thread
    Earlier in the same topic, a forum member asked for a photo of the TV nameplate before identifying software. That is still the correct next step here. (elektroda.com)
    What you should post now
    Please add:
    1. A clear photo of the back label / nameplate
    2. Confirmation whether the prefix is:
    - A43CF6131EB03I
    or
    - A43CF6131EB031
    3. A photo of the main board sticker if you can open the set
    4. A short symptom description:
    - dead, no standby LED
    - stuck on logo
    - backlight but no image
    - blinking LED
    - boots but unstable
    That will allow proper firmware identification.
    Official route
    Sharp Consumer’s current support portal has a TV support contact form that asks for product type, model, serial number, purchase date, and message, so if the exact file is not available on the forum, that is the proper official channel to request the correct package for your exact variant. (sharpconsumer.com)
    For now:
    - Do not flash the EB383 firmware
    - first confirm the exact serial prefix from the label
    - then identify the mainboard / panel variant if needed
    If you want, send:
    - the nameplate photo
    - and preferably mainboard photo
    and I will help you determine whether your TV needs:
    - a USB firmware update, or
    - direct programming of SPI/eMMC memory.
The discussion concerns urgently obtaining firmware/software for a Sharp TV model LC-43CFE6131E. The key matching identifier is the serial prefix A43CF6131EB383, and an earlier post in the thread states that the software for equipment with this prefix is attached. Later replies clarify that this is firmware, not a PC driver, and warn that the attached package should only be used when the serial prefix matches, since Sharp/UMC TVs require firmware to match the model family and hardware variant.
