Title: Need Dump Flash SPI 25Q64 for Silver TV IP-LE32/495523 - HK.T.RT2957P68 Self-Test Issue
electrohd 3078 7
  • #1 20103038
    electrohd
    Rate: 8
    Dump Flash SPI 25Q64 for TV Silver HK.T.RT2957P68
    Any colleague who can provide Dump for TV Silver
    Model: IP-LE32/495523
    Main board: HK.T.RT2957P68
    Panel: ST3151A05-8
    This TV is locked in self-test mode. It opens with white, red, green, blue screen and repeats.
    I've tried procedures in an attempt to solve, but without success.
    elmo071
    Level 30  
    Help: 167
    Rate: 803
    Please, I have such a load:
    SILVER IP-LED32-495523
    Motherboard: HK.T.RT2957P68
    Memory: GD25Q64
    Matrix: ST3151A05-8 VER2.1
    • Wsad.rar (7.17 MB) You must be logged in to download this attachment.
  • #3 20110965
    electrohd
    Rate: 8
    This Dump did not result Led stdby but it does not turn on.
    With another Dump called. but with the same defect:
    Panel defect?
    Best Regards
    Added after 41 [minutes]:
    I thank my colleague elmo071 for his availability. These Silver TVs were made to use and throw away!!!
    Best Regards
    querij
    Help: 42
    Rate: 228
    Experimente este ficheiro
    • GD25Q64_U7.rar (7.34 MB) You must be logged in to download this attachment.
  • #5 20121069
    electrohd
    Rate: 8
    Hi friend, I've found the problem.
    Microprocessor, LVDS outputs.
    Thanks
    Olá amigo, já localizei o defeito.
    Microprocessador, saídas LVDS.
    Obrigado.
  • #6 20121293
    querij
    Help: 42
    Rate: 228
    De nada, sempre que necessitar
  • #7 20693318
    electrohd
    Rate: 8
    I want to thank everyone who helped. This topic can be closed.
  • #8 21915555
    maneloo
    text
    Model: SAMUS LE32C2
    Memory: GD25Q64B
    Matrix: ST3151A05-E-XC-2
    Standby LED
    I post my original firmware if anyone can help me.
    Wsad.rar and GD25Q64_U7 don't help. Standby LED only.
    • GD25Q64B_20260604_180239.BIN (8 MB) You must be logged in to download this attachment.
Discussion about a Silver TV with main board HK.T.RT2957P68 and SPI flash 25Q64/GD25Q64, model IP-LE32/495523, stuck in self-test mode with repeating white/red/green/blue screens. A firmware dump was requested and shared, but the fault persisted: standby LED behavior changed yet the TV still would not start normally. The issue was eventually traced to the microprocessor and LVDS outputs rather than the flash dump or panel, and the topic was later closed. A separate related post mentions another TV with the same board and memory, showing standby LED only and requesting original firmware.
