You're viewing a topic that has been removed.
  • #1 21578616
    evlo2
    So there is one exact combinanion os xenon settings that makes everything work in VCDS
    14-3
    17-2
    25-2
    this way - no cold bulb check (I did not test hot bulb) for low beams and high beams, still high beams turn on, even automatically when lights are set to auto and even the halogen high beams do work in conjuction with bi led shutter
    Deleted from topic: Disable cold bulb control for LED low beam headlights on Skoda Octavia Mk2 PQ35 platform
    by evlo2 on 13 Jun 2025 21:26
