ZigBee TH Sensor ZTH01 - how to upload new firmware and configure under Home Assistant?
Voodoo4 627 0
  • Need firmware and Home Assistant setup guidance
    #1 21814970
    Voodoo4
    Help: 6
    Rate: 42
    ZTH01 (ZigBee T&H Sensor) No WiFi.
    Hello, I bought 10 pieces of such a device on aliexpress and I wanted to connect to the Tuya gateway, but I get an error, as I checked the device is truncated probably from the license and the Tuya gateway does not allow to pair the device, I wanted to connect to the Home Assistant using the SLZB-06-P7 device and there is also a problem, the devices pair but it does not read data from them, i read that there is a problem with the ZTH01 and the device needs to be flashing, apparently on the board there are marked places RX and TX, photo attached, and connecting via RS ttl should not be a problem, but what next, what software to use and what batch to the device and what configuration to work with Home Assistant?
    It is not possible to read the inscriptions from the microcontroller, they are blurred.
    Is there anyone who can suggest how to upload and configure the software so that I don't have to read hundreds of pages and extract crumbs of information?
    Regards.
