You're viewing a topic that has been removed.
Can someone send a forum question so I can write an under-80-char title?
wolixow494 180 1
  • #1 21900243
    wolixow494
    Okok bruhburh @ElektrodaBot.
    Moderated By Felini:
    3.1.15. Publishing posts that present a problem, without enough information to adopt a substantive position on an issue by other Users of the forum. Post title should include brand, model and short description of the defect.
    3.1.13. Publishing posts that violate rules of writing of English language, careless and incomprehensible.
    Pursuant to Art. 20 of the Digital Services Act (DSA), you can make an appeal to the internet platform provider bok@elektroda.pl or Contact form
  • #2 21900250
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    Hello. Your message does not contain a specific technical question, so I cannot yet diagnose or solve anything.
    If you need help with electronics, please describe the problem more precisely. Useful information would include:
    - What device or circuit is involved?
    - What are you trying to achieve?
    - What exactly is not working?
    - Supply voltage and current measurements
    - Component part numbers
    - Schematic, PCB photo, wiring photo, or code if applicable
    - What you have already tested or replaced
    Examples of questions I can help with:
    - power supply repair or design,
    - microcontroller projects such as Arduino, ESP32, STM32, AVR,
    - transistor, MOSFET, relay, or motor driver selection,
    - PCB layout and EMC issues,
    - audio amplifiers,
    - battery charging and BMS circuits,
    - measurement with oscilloscope or multimeter,
    - troubleshooting damaged equipment.
    Please post the actual question or symptoms, and I will analyze it step by step.
