You're viewing a topic that has been removed.
TH02 T1-3S BK7238 ZY-TH02-CB3S_V1.0 Some Units Only Send Heartbeat, No cmd 34
leonardojc 165 0
  • Manual TuyaMCU commands still fail to trigger cmd 34
    #1 21905069
    leonardojc
    i've the same issue,
    {"p":"1ugtmglvvnwlun4a","v":"1.0.0","m":0,"n":1,"sm":0}u
    units send only heartbeats and WiFiState, never cmd 34
    most relevant log:
    Info:TuyaMCU:Received: 55 AA 03 90 00 03 02 17 18 C6
    Info:TuyaMCU:ProcessIncoming[v=3]: cmd 144 (Unknown) len 10
    and i try to send manually commands to TuyaMCU
    send: 55 AA 00 01 00 00 00
    55 AA 03 01 00 37 7B 22 70 22 3A 22 31 75 67 74
                        6D 67 6C 76 76 6E 77 6C 75 6E 34 61 22 2C 22 76
                        22 3A 22 31 2E 30 2E 30 22 2C 22 6D 22 3A 30 2C
                        22 6E 22 3A 31 2C 22 73 6D 22 3A 30 7D 75
    send: 55 AA 00 02 00 01 04 06
    55 AA 03 02 00 00 04
    send: 55 AA 00 03 00 00 02
    55 AA 03 03 00 00 05
    send: 55 AA 00 08 00 00 07
    send: 55 AA 00 0B 00 00 0A
    send: 55 AA 00 09 00 05 03 01 00 01 01 13
    send: 55 AA 00 10 00 04 03 73 72 71 6C
    send: 55 AA 00 0B 00 02 01 50 5D
    web app logs:
    Info:MAIN:Starting TuyaMCU.
    Info:MAIN:Started TuyaMCU.
    Info:GEN:Channel 1 type changed to Temperature_div10
    Info:GEN:Channel 2 type changed to Humidity
    Info:GEN:Channel 3 type changed to ReadOnlyLowMidHigh
    Error:CMD:LFS_ReadFile: lfs is absent
    Info:CMD:CMD_StartScript: failed to get file autoexec.bat
    Info:HTTP:TCP server listening
    Info:MAIN:Time 1, idle 574957/s, free 127352, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:TuyaMCU:Received: 55 AA 03 00 00 01 00 03
    Info:TuyaMCU:ProcessIncoming[v=3]: cmd 0 (Hearbeat) len 8
    Info:MAIN:Time 2, idle 414101/s, free 127352, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:TuyaMCU:Received: 55 AA 03 01 00 37 7B 22 70 22 3A 22 31 75 67 74 6D 67 6C 76 76 6E 77 6C 75 6E 34 61 22 2C 22 76 22 3A 22 31 2E 30 2E 30 22 2C 22 6D 22 3A 30 2C 22 6E 22 3A 31 2C 22 73 6D 22 3A 30 7D 75
    Info:TuyaMCU:ProcessIncoming[v=3]: cmd 1 (QueryProductInformation) len 62
    Info:TuyaMCU:ParseQueryProductInformation: received {"p":"1ugtmglvvnwlun4a","v":"1.0.0","m":0,"n":1,"sm":0}
    Info:MAIN:Time 3, idle 382739/s, free 127352, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:TuyaMCU:Received: 55 AA 03 02 00 00 04
    Info:TuyaMCU:ProcessIncoming[v=3]: cmd 2 (MCUconf) len 7
    Info:TuyaMCU:ProcessIncoming: TUYA_CMD_MCU_CONF, TODO!
    Info:MAIN:Time 4, idle 382512/s, free 127352, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 5, idle 385063/s, free 127352, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Registered for wifi changes
    Info:MAIN:Connecting to SSID [OpenWrt]
    Info:TuyaMCU:Received: 55 AA 03 00 00 01 01 04
    Info:MAIN:Time 6, idle 0/s, free 119792, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 7, idle 329693/s, free 120896, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:TuyaMCU:Received: 55 AA 03 03 00 00 05
    Info:TuyaMCU:ProcessIncoming[v=3]: cmd 3 (WiFiState) len 7
    Info:MAIN:Time 8, idle 412135/s, free 120896, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 9, idle 395802/s, free 112504, MQTT 0(0), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 10, idle 408998/s, free 109416, MQTT 0(0), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:GEN:dhcp=0 ip=192.168.1.38 gate=192.168.1.1 mask=255.255.255.0 mac=c8:47:8c:42:88:48
    Info:GEN:sta:rssi=-30,ssid=OpenWrt,bssid=b0:4e:26:ab:98:1a,channel=6,cipher_type:CCMP
    Info:MQTT:mqtt_userName mqtt_user
    mqtt_pass ********
    mqtt_clientID
    mqtt_host 192.168.1.18:1883
    Info:MAIN:Time 11, idle 409194/s, free 102248, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 3/24
    Info:MQTT:mqtt_subscribed to /+/set
    Info:MQTT:mqtt_subscribed to bekens/+/set
    Info:MQTT:mqtt_subscribed to cmnd//+
    Info:MQTT:mqtt_subscribed to cmnd/bekens/+
    Info:MQTT:mqtt_subscribed to /+/get
    Info:MQTT:mqtt_subscribed to homeassistant/+
    Error:HTTP:http_fn_cmd_tool: len 0
    Info:MQTT:Publishing val obk7F6DDB to /host retain=0
    Info:MAIN:Time 12, idle 383927/s, free 106744, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 58, idle 412494/s, free 115176, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 59, idle 423200/s, free 115176, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 60, idle 419251/s, free 115176, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:GEN:sta:rssi=-35,ssid=OpenWrt,bssid=b0:4e:26:ab:98:1a,channel=6,cipher_type:CCMP
    Info:MAIN:Time 61, idle 410201/s, free 115176, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 62, idle 416812/s, free 115176, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 63, idle 408094/s, free 115176, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 64, idle 417349/s, free 115176, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 65, idle 414528/s, free 115176, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 66, idle 416216/s, free 114552, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/24
    Info:MAIN:Time 67, idle 419699/s, free 115176, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 68, idle 398712/s, free 115176, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/24
    Info:MAIN:Time 69, idle 401914/s, free 115176, MQTT 1(1), bWifi 1, secondsWithNoPing 1, socks 2/24
    Info:MAIN:Time 70, idle 385927/s, free 115176, MQTT 1(1), bWifi 1, secondsWithNoPing 2, socks 2/24
    Info:GEN:sta:rssi=-31,ssid=OpenWrt,bssid=b0:4e:26:ab:98:1a,channel=6,cipher_type:CCMP
    Info:MAIN:Time 71, idle 391921/s, free 115176, MQTT 1(1), bWifi 1, secondsWithNoPing 3, socks 2/24
    Info:MAIN:Time 72, idle 384862/s, free 115176, MQTT 1(1), bWifi 1, secondsWithNoPing 4, socks 2/24
    Info:MAIN:Time 73, idle 382247/s, free 114560, MQTT 1(1), bWifi 1, secondsWithNoPing 5, socks 3/24
    Skasowano z tematu: TH02 T1-3S BK7238 ZY-TH02-CB3S_V1.0 Some Units Only Send Heartbeat, No cmd 34
    przez leonardojc dnia 17 Maj 2026 18:20
