Long-Distance Networking Challenges?
iotservice1 81 0
  • #1 21914097
    iotservice1
    I've been working on an environmental monitoring project for a large industrial park, requiring coverage of over 3 square kilometers with more than 100 nodes — and no single point of failure from a central node.
    After comparing traditional solutions: star networks couldn't cover the area, 4G DTUs were too costly, and LoRa point-to-point required too many repeaters. I finally chose the EBYTE E52-400NW30S, a 1W high-power LoRa MESH module, and the real-world results exceeded expectations.
    Key Highlights:
    1W Transmit Power (30dBm): Measured communication distance of up to 4km in open areas (air data rate 7Kbps, antenna 3.5dBi), with significantly better wall penetration than standard modules.
    Decentralized MESH Networking: No central node required — each device can act as a router to forward data. If any node goes offline, the network automatically reroutes, ensuring the system never goes down.
    Multi-hop Routing: Supports data hopping across multiple nodes, easily covering every corner of the park.
    Differences from the 22S Version:
    30S (current model): 30dBm transmit power, 40.5×25mm size, higher power consumption (instantaneous current 710mA), suitable as backbone repeater.
    22S: 22dBm transmit power, 20×14mm size, low power consumption, suitable as end-node sensors.
    Important Note: The module's transmit current is high — power supply must be stable above 5.0V, otherwise power output drops. Good heat dissipation should be预留 on the PCB design.
    The network has been running stably for a month now. Feel free to discuss implementation details if interested.
