PCB Trace Max Current Calculator (External)
Microstrip Max Current Calculator
Trace Width W
Trace Thickness T
Temperature Rise Trise
Max Current: 0.640
Additional Inputs
Ambient Temperature Tamb
Length L
Additional Output
Trace Temperature:
Resistance:
Voltage Drop:
Power Dissipation:
This tool, based on the formulas and graphs contained in the standard document [1], calculates the maximum allowable current that can flow through a copper printed circuit board external trace (also called as microstrip), keeping the temperature increase of the trace itself below the specified input value. As shown in the picture, the microstrip has width W and thickness T and is separated by an insulating dielectric from a large conductive ground plane.
By providing additional input parameters (ambient temperature and trace length), it is possible to calculate the trace total temperature, resistance, voltage drop and power dissipation (power loss).
Max Current calculation
First, calculate the area according to the following formula:
A = (T · W · 1.378 [mils/oz/ft2])                 (I)
Then, calculate the maximum current:
IMAX = (k · TRISEb) · Ac                                       (II)
Where:
A is the cross-section area [mils2] T is the trace thickness [oz/ft2] W is the trace width [mils] IMAX is the maximum current [A] TRISE is the maximum desired temperature rise [°C] k, b and c are constants. According to IPC-2221A Par. 6.2 (“Conductive Material Requirements”), their values for inner layers are as follows: k = 0.048 b = 0.44 c = 0.725
Equation (II) is based on a curve fit to the charts provided in [1] (par. 6.2, Figure B and Figure C).
Trace temperature calculation
The overall trace temperature can be calculated as follows
TTEMP = TRISE + TAMB
Where:
TTEMP is the trace temperature [°C] TRISE is the maximum desired temperature rise [°C] TAMB is the ambient temperature [°C]
Resistance calculation
First, convert the cross-section area from [mils2] to [cm2]:
A’ = A * 2.54 * 2.54 * 10-6
Then, calculate the resistance:
R = (ρ * L / A’) * (1 + α * (TTEMP – 25 °C))
Where:
T is the trace thickness [oz/ft2] W is the trace width [mils] R is the resistance [Ω] ρ is the resistivity parameter, whose value for copper is 1.7E-6 [Ω · cm] L is the trace length [cm] α is the resistivity temperature coefficient, whose value for copper is 3.9E-3 [1/°C] TTEMP is the trace temperature [°C]
Voltage drop calculation
Voltage drop can be calculated as follows:
VDROP = I * R
Where:
VDROP is the voltage drop [V] I is the maximum current [A] R is the resistance [Ω]
Power dissipation calculation
Power dissipation, or power loss, can be calculated according to the following formula:
PLOSS = R * I2
Where:
PLOSS is the power loss [W] R is the resistance [Ω] I is the maximum current [A]
Example 1
Inputs W = 12 mil T = 5 mil TRISE = 30 °C TAMB = 25 °C L = 12 inch
Output Cross-section Area = 60.00 mils2 IMAX = 4.17 A
Additional output Trace Temperature = 55 °C Resistance = 0.150 Ω Voltage Drop = 0.626 V Power Dissipation = 2.608 W
Example 2
Inputs W = 10 mil T = 3 oz/ft2 TRISE = 20 °C TAMB = 18 °C L = 25 cm
Output Cross-section Area = 41.34 mils2 IMAX = 2.66 A
Additional output Trace Temperature = 38 °C Resistance = 0.167 Ω Voltage Drop = 0.444 V Power Dissipation = 1.182 W
Reference
[1] IPC-2221A “Generic Standard on Printed Board Design”
