PCB Trace Max Current Calculator (Internal)
Stripline Max Current Calculator
Trace Width W
Trace Thickness T
Temperature Rise Trise
Output
Max Current:
Additional Inputs
Ambient Temperature Tamb
Length L
Additional Output
Trace Temperature:
Resistance:
Voltage Drop:
Power Dissipation:
This tool, based on the formulas and graphs contained in the standard document [1], calculates the maximum allowable current that can flow through a copper printed circuit board internal trace (also called as stripline), keeping the temperature increase of the trace itself below the specified input value. As shown in the picture, the stripline has width W and thickness T and is totally inside the dielectric material. For this reason, a stripline structure is less likely to radiate radiofrequency (RF) signals and is therefore widely used in microwave cicuits.
By providing additional input parameters (ambient temperature and trace length), it is possible to calculate the trace total temperature, resistance, voltage drop and power dissipation (power loss).
Max Current calculation
First, calculate the area according to the following formula:
A = (T · W · 1.378 [mils/oz/ft2])                 (I)
Then, calculate the maximum current:
IMAX = (k · TRISEb) · Ac                                       (II)
Where:
A is the cross-section area [mils2] T is the trace thickness [oz/ft2] W is the trace width [mils] IMAX is the maximum current [A] TRISE is the maximum desired temperature rise [°C] k, b and c are constants. According to IPC-2221A Par. 6.2 (“Conductive Material Requirements”), their values for inner layers are as follows: k = 0.024 b = 0.44 c = 0.725
Equation (II) is based on a curve fit to the charts provided in [1] (par. 6.2, Figure B and Figure C).
Trace temperature calculation
TTEMP = TRISE + TAMB
Where:
TTEMP is the trace temperature [°C] TRISE is the maximum desired temperature rise [°C] TAMB is the ambient temperature [°C]
Resistance calculation
First, convert the cross-section area from [mils2] to [cm2]:
A’ = A * 2.54 * 2.54 * 10-6
Then, calculate the resistance:
R = (ρ * L / A’) * (1 + α * (TTEMP – 25 °C))
Where:
T is the trace thickness [oz/ft2] W is the trace width [mils] R is the resistance [Ω] ρ is the resistivity parameter, whose value for copper is 1.7E-6 [Ω · cm] L is the trace length [cm] α is the resistivity temperature coefficient, whose value for copper is 3.9E-3 [1/°C] TTEMP is the trace temperature [°C]
Voltage drop calculation
Voltage drop can be calculated as follows:
VDROP = I * R
Where:
VDROP is the voltage drop [V] I is the maximum current [A] R is the resistance [Ω]
Power dissipation calculation
Power dissipation, or power loss, can be calculated according to the following formula:
PLOSS = R * I2
Where:
PLOSS is the power loss [W] R is the resistance [Ω] I is the maximum current [A]
Example 1
Inputs W = 9 mil T = 2 oz/ft2 TRISE = 10 °C TAMB = 25 °C L = 10 inch
Output Cross-section Area = 24.804 mils2 IMAX = 0.678 A
Additional output Trace Temperature = 35 °C Resistance = 0.280 Ω Voltage Drop = 0.190 V Power Dissipation = 0.129 W
Example 2
Inputs W = 25 mil T = 4 mil TRISE = 20 °C TAMB = 27 °C L = 8 inch
Output Cross-section Area = 100.00 mils2 IMAX = 2.53 A
Additional output Trace Temperature = 47 °C Resistance = 0.0581 Ω Voltage Drop = 0.147 V Power Dissipation = 0.372 W
Reference
[1] IPC-2221A “Generic Standard on Printed Board Design”
