[TYWE3S-ESP8266] SM-AW713 WiFi controlled valve - interior, firmware change
p.kaczmarek2  26 4023 Cool? (+4)
  • Jinvoo SM-AW713, sold as SmartLED 8073, is a WiFi-controlled water/gas valve overlay that mounts on an existing valve and replaces Tuya cloud control with local firmware.
  • Inside, the controller uses an ESP8266 TYWE3S module, a relay board, and a 12V-to-3.3V step-down converter, so Tasmota can run on it.
  • Flashing can start with tuya-convert over WiFi, or with esptool.py and UART after removing the motor for better access to the programming pads.
  • A Blakadder template maps IO5 and IO4 to LEDs, IO12 to the button, and IO13 to the relay, making HA integration straightforward.
  • The valve changes state with a relay toggle and the manufacturer notes about a 10-second delay, but newer batches may switch to BK7231 hardware.
Interior of the Jinvoo SM-AW713 smart valve controller with ESP8266 .
Here I show the inside and the process of changing the firmware of a clever water/gas valve overlay that allows such a valve to be controlled via WiFi. This controller is commercially available under the name Jinvoo SM-AW713, although distributors often also give it their own designations and the version I ordered was signed as SmartLED 8073. There has already been mention on the forum of its version on BK7231, in this post , but here I will show the ESP-based version.
Purchase of Jinvoo SM-AW713 .
"Smart" WiFi valve controllers can be bought for as little as around PLN100. The price depends on where you buy. You can also buy it on our Polish auction portal, in which case you will receive the product quickly, but it is slightly more expensive.
WiFi valve controller for gas/water shown with smartphone app. .
It should be noted at the outset that the kit you buy does not include the valve. This kit is fitted to the valve already fitted to us .
The whole thing then looks like this:
Diagram of an installation with a smart valve controller in a gas pipeline system. .
Installation details:
Valve controller with a smartphone app for valve control. .
The whole thing can be controlled via the Tuya app, but we'll want to change that and get cloud-independent.
After placing the order, we receive a box like this:
Box of Jinvoo SM-AW713 smart WiFi valve. A white box labeled SmartLED 8073, showing a description of the WiFi water/gas valve functions. Close-up of Smart Valve box with technical specifications. .
Kit contents:
Jinvoo SM-AW713 set in packaging Contents of the box with the Jinvoo SM-AW713 smart valve WiFi controller. Box with Jinvoo SM-AW713 valve controller set and accessories. WiFi valve controller kit, packaged in transparent plastic and a cardboard box. .
Even the power supply is included. This is rather a plus, although I would always find one at my place already for this purpose.
Here is the main mechanism, the mounting parts are in the bag:
Mounting components and the smart WiFi valve controller. .
View of the valve overlay with a black housing and mounting mechanism on a wooden surface. .
The case reveals to us the actual model of the device - SM-AW713, this 8073 is just the importer's designation:
Jinvoo SM-AW713 water/gas valve cover .
Instructions (including a description of how to put the device into pairing mode with the Tuya app, but we don't really need that):
WiFi smart valve installation manual Instruction leaflet of the Jinvoo SM-AW713 smart valve controller on a wooden table. .
Interior of Jinvoo SM-AW713 .
Remove the four screws:
Jinvoo SM-AW713 valve cover with mounting components. .
Interior:
Valve control module with visible PCB and wiring.
PCB designation: SM-AW713 LED V4.0 FR-4 RoHs E364546
Here we have two separate LEDs, one presumably for the pairing status, the other for the switching status, a pin from switching and a connector for the second board and for the motor (M+ and M-).
Close-up of the internal components of the SM-AW713 smart valve controller showing the circuit board with buttons and wires. Interior of the Jinvoo SM-AW713 device showing PCB and wiring. .
There is a relay and a WiFi module on the second board:
Interior of Jinvoo SM-AW713 valve controller with visible PCB and wires. View of the interior of the Jinvoo SM-AW713 smart valve overlay with visible ESP module and wiring. .
It turns out that here is a module with ESP, so Tasmota can be uploaded:
Close-up of PCB with TYWE3S WiFi module and relay. Interior view of WiFi module with ESP8266 in valve controller. .
Changing the Jinvoo SM-AW713 batch .
Due to the difficult access to the WiFi module, it is worth trying tuya-convert first, which still supports some older devices. Tuya-convert allows you to change the batch via WiFi, without soldering cables. Newer ones, unfortunately, are no longer susceptible to this solution.
The SC3-01 SmartLife switch and ESP firmware upload via WIFI (tuya-convert/OTA) .
If, on the other hand, this method doesn't work (or we don't have the WiFi card needed to create an access point), the engine can be removed:
and gain slightly better access to the WiFi module:
Jinvoo SM-AW713 PCB with visible TYWE3S WiFi module. .
By the way, here you can see the step-down converter generating 3.3V from the 12V input, this is the operating voltage of the WiFi module. Next to the IC you can also see its coil:
Close-up of the Jinvoo SM-AW713 PCB with visible electronic components. .
You can also see the transistor that controls the relay:
Close-up of the PCB of the Jinvoo SM-AW713 controller with electronic components. .
The WiFi module itself:
TYWE3S module on a PCB. Close-up of the TYWE3S WiFi module on a circuit board with model and serial number markings. .
This is an ESP8266, so esptool.py will do. TYWE3S pinouts are available on the web, by the way, they are compatible with ESP12. You can read about uploading Tasmota here:
SmartLife switch - test, interior and programming a light switch on WiFi .
You can also use the web-based installer:
How to install Tasmota easily - online installer tasmota.github.io/install via web browser .
Once Tasmota has been uploaded, the template needs to be uploaded:
{"NAME":"Jinvoo Valve","GPIO":[0,0,0,0,0,52,0,0,21,17,0,0,0],"FLAG":0,"BASE":18}
The template comes from the Blakadder website, but describing in words here we have:
- LEDs (the first on IO5, the second on IO4)
- button on IO12
- relay on IO13
The operation of this template is really very simple. Simply switching on the relay switches on the valve and vice versa. Of course, everything is done with a certain delay, which, by the way, is stated by the manufacturer itself - about 10 seconds.
Summary .
It turned out that on the firmware side, this gadget is really simple to drive. All you need to do is simply switch on (or off) the relay. The problem, on the other hand, is accessing the programming pads. You have to get there from the UART, unless you get lucky and the tuya-convert works.
An additional plus is the presence of an ESP inside, although I don't know if this too at this distributor won't change in time, as even at our forum there was a post about this device in the BK version . In any case - both versions can be easily flashed and connected to HA.
Do you see any potential practical use for such a gadget? Perhaps it could be paired with a humidity sensor, for example, and turn the water off if a leak is detected, or perhaps you would use it in some other way?
p.kaczmarek2 wrote 14756 posts with rating 12883 , helped 659 times. Been with us since 2014 year.
ro-x 29 Sep 2023 18:20
For five (hehe) years I've been thinking of some way of turning off the water supply in the event of detecting flooding from the water sensors I have under each 'intake', such as the sink, basin, bath,... [Read more]
12robert12 29 Sep 2023 20:10
I've had these Chinese valves paired with flood sensors for 2 years now and it's worked superbly, they've worked more than once when the kids were going crazy in the shower 😜. There is control if there... [Read more]
ro-x 29 Sep 2023 20:33
. Good tip! Indeed a stagnant valve is difficult to move. [Read more]
krzbor 29 Sep 2023 21:21
. How exactly does the motor control work? Are there 'limit' position stops, or is it more based on overload analysis? [Read more]
p.kaczmarek2 30 Sep 2023 10:08
@krzbor I didn't want to deconstruct it more for analysis but in this photo you can see one of the buttons testing the condition of the gearbox: https://obrazki.elektroda.pl/1848545600_1696061062_thumb.jpg... [Read more]
krzbor 30 Sep 2023 10:28
. So as I am guessing this is a "limit switch" based solution. How does the relay work? Does it work by interchanging the "+" and "-" fed to the motor? I understand that the limiters are not controlled... [Read more]
ro-x 30 Sep 2023 10:57
. Just for quick reference, a branded, PZH approved, NC type, 1" diameter solenoid valve, powered by 12V draws about 30-35W. The same valve with a solenoid on 230V consumes about 25-30W. It can be used... [Read more]
Anonymous 30 Sep 2023 14:37
. Valves like this have been around for a good couple of years, they are on supercapacitors so they don't need an external power supply to trigger the closure, and the control is very simple - open... [Read more]
ro-x 30 Sep 2023 14:40
Can you give an example? [Read more]
Anonymous 30 Sep 2023 18:32
. https://hpcontrol.pl/elektrozawor-kulowy-1cal-z-silownikiem-a80-lub-a83.html I have the A83 two-wire 230V version 4 years already in operation https://obrazki.elektroda.pl/4487838000_1696092032_thumb.jpg... [Read more]
ro-x 30 Sep 2023 20:08
Thanks! This is exactly what I need :) I see that the valve draws only 6W. This is as acceptable a value as possible. In many installations you should be able to find a spare 0.5A directly in the alarm... [Read more]
Anonymous 30 Sep 2023 20:33
As I have already written, it has been working for 4 years and there are no problems, it does not do anything to make it move periodically. The only fact is what they write that if you "play" with the... [Read more]
ro-x 30 Sep 2023 21:28
Have you measured its energy consumption when it is at rest, i.e. when it is fully charged and not moving? If it consumes less than 6W 99.9% of the time, it is a killer for me. The loudness of the valve,... [Read more]
Anonymous 30 Sep 2023 22:08
I haven't done measurements, but I suspect it will consume less than 0.2W when idle under power because there is nothing to consume that current there (small inverter and uc). I could do a measurement... [Read more]
ro-x 30 Sep 2023 22:20
I'll buy one for trial + a couple of PP connectors and do a review. The plan - control from the Satel Integra via relay and powered from the APS-412 buffer power supply plus integration with Home Assistant... [Read more]
krzbor 01 Oct 2023 15:40
Let me repeat my question: . Perhaps someone knows the answer? [Read more]
p.kaczmarek2 01 Oct 2023 16:11
@jarzabek666 very good suggestion, as the 25W from @rox would be overkill for me, although maybe I look at it too harshly.... I, against all odds, have not replaced all the devices in the house with such... [Read more]
krzbor 01 Oct 2023 23:46
I understand that only one GPIO controls a relay, and that relay controls the servo circuit? Maybe I'll say why I'm asking this - I'm wondering if the circuit can be reworked to control any opening angle,... [Read more]
pier 02 Oct 2023 07:07
I would like to see such a valve on my DHW pipe. The valve would shut off heating water when the temperature in the tank would be higher than the temperature on the boiler so that the boiler would not... [Read more]
