What is the difference between the miniature circuit breaker B32 and C32
sebaele22 113873 11
What is the difference between a B32 and a C32 miniature circuit breaker?
B32 and C32 differ in their tripping characteristic: a B curve breaker trips at about 3–5 times the rated current, while a C curve breaker trips at about 5–10 times the rated current [#5474264] For a 32 A breaker, that means roughly 96–160 A for B32 and 160–320 A for C32 [#5474264] B is typically used for domestic loads with low inrush current, while C is better for loads with higher start-up current such as motors [#5474264] These are overcurrent circuit breakers, not fuses [#5477400][#5477541]
  • #1 5470508
    sebaele22
    Level 30  
    Rate: 513
    As in the topic, what is the difference between the B32 3-phase circuit breaker and C32?
  • #3 5474264
    michcio
    Electrician specialist
    Help: 145
    Rate: 481
    It differs in actuation current.
    Circuit breaker with B characteristic will be tripped immediately when a current flowing through it is equal to 3-5 times the rated current, that is in this case 96-160A.
    On the other hand, the C characteristic is 5-10 times the rated current, i.e. about 160-320A, i.e. the circuit breaker will work at this current.
    There is also a D (10-20x) characteristic, which is about 320-640 Amps.
    The fuse characteristics are selected according to the type of load, and more precisely to the starting current.
    Thus, B is used for domestic applications, because domestic appliances have low inrush currents.
    But if we want to protect the motor (induction motors consume up to 8 times the rated current at start-up), then you have to use C, because the B motor will knock out at start-up. For example, a motor of about 10 kW, a three-phase motor consumes about 15A from the phase during normal operation, while at the start it consumes even 120A for a while.
    Hope you understand now.
    PS: For pre-meter protection (if that's what you mean when choosing), char is the best. C. Unless you have devices that will consume even more than 320 A at start-up, then D.
  • #4 5475003
    dioda 1988
    A fuse or a selective switch is suitable for the pre-meter. Unless you want to fly to the frame, turn on the pre-meter which will trip in the event of any short circuit (Ski are not selective). nobody teaches you that eSek is not connected in series, even different ch-yk ??
  • #5 5475119
    SQ9MEM
    Help: 119
    Rate: 279
    Buddy Micha - if we want to protect the engine, we use a motor switch.
  • #6 5475752
    michcio
    Help: 145
    Rate: 481
    Yes, it is, and I know it well, but if you want to explain it to anyone, it will choose an ordinary S-ke anyway, because other solutions are too expensive for people ...
    Using a motor circuit breaker can you do without short-circuit protection?
  • #7 5476126
    Jasiek690
    Moderator on vacation ...
    Help: 51
    Rate: 158
    I moved from "General". Johnny690
  • #8 5476813
    SQ9MEM
    Help: 119
    Rate: 279
    Buddy Micha - you wrote "protect the engine" and the motor switch protects the engine. The overcurrent switch protects the electrical installation.
  • #9 5476827
    sebaele22
    Level 30  
    Rate: 513
    Thanks to all of you for the answers, I just wanted to know what's the difference because I have C32 fuses for sale ...
  • #10 5476889
    SQ9MEM
    Help: 119
    Rate: 279
    Except they're not fuses.
  • #11 5477400
    michcio
    Help: 145
    Rate: 481
    ... but circuit breakers.
  • #12 5477541
    SQ9MEM
    Help: 119
    Rate: 279
    Exactly. Specifically, overcurrent or overcurrent circuit breakers (the nomenclature for this is different).
The discussion centers on the differences between B32 and C32 miniature circuit breakers. The B characteristic circuit breaker trips at 3-5 times its rated current (96-160A), making it suitable for domestic applications with low inrush currents. In contrast, the C characteristic trips at 5-10 times its rated current (160-320A), which is ideal for protecting motors that may draw significantly higher currents during startup. The conversation also touches on the use of motor switches and the distinction between circuit breakers and fuses, clarifying that both B32 and C32 refer to circuit breakers, not fuses.
