Understanding the Concept and Characteristics of a Servomotor
eNtymon 28449 8
  • #1 5872605
    eNtymon
    Can someone answer a question I can't find online? What is a "servomotor" and what are its characteristics?
  • #2 5872623
    bslaw
    Help: 16
    Rate: 67
    Search for "servomotor".
  • #4 5873347
    kortyleski
    Help: 957
    Rate: 3860
    A stepper motor is not a servomotor, although it can be a component of a servo ... The explanation from the link is also not complete.
    SERVO, servomotor and other clones of this name describe a "motor with feedback", which is usually an electric motor with a gear, at the output of which there is an axis position sensor (potentiometer, optics, etc.)
    In addition, there is the control electronics, because there is a position sensor, so our servo can be controlled so that it rotates by a certain angle, stays in this position, etc. At the same time, any attempt to mechanically change the position of the controlled servo will cause the motor to maintain its position.
    An example of application is a model aircraft where the rudder repeats exactly the movements of the stick on the desktop, regardless of the load it will always deflect the same angle as the stick
  • #5 5875959
    noplis
    Help: 36
    Rate: 49
    But an ordinary squirrel cage motor with an encoder is not a servo motor. Modern servo motors are permanent magnet synchronous motors. The basic features of such motors are a small moment of inertia of the rotor and high resolution of the motor shaft position feedback system. How such engines are built and what are their parameters can be seen here:
    http://www.boschrexroth-us.com/country_units/...mentation/LegacyProducts/Motors/index.jsp#MKD
  • #6 5878062
    Madrik
    Help: 627
    Rate: 1191
    Not true - a matter of scale. There are big servos and small servos. If you have such a need, you can even build a synchronous servo.
    There are, for example, electrically controlled excavators, where several dozen kilowatt squirrel-cage motors are responsible for the arm movements. With the right tooling - they form a servo.
    In addition to the motor, the servo may also include mechanical systems - e.g. gears and electronics.
    And by the way - in model airplanes, it is not at all said that the servo has to correspond exactly to the movement of the stick ;) Currently, it is easy to set how large the range of motion of the servomotors should be, and many for one channel. It can be proportional to the movement of the stick, but it doesn't have to be.
  • #7 5878260
    patdem
    Help: 7
    Rate: 10
    A servomotor is a device that makes something move.
    And that's it, various devices can be a servomotor, e.g. a pneumatic actuator.
    100%
    :D
  • #8 5878670
    eNtymon
    So, generally speaking, any motor that can work with an encoder can be used to build a servo? so what does a servo with a separately excited motor look like?, does anyone have a diagram of such a system?
    Thanks for the help so far, it cleared things up a bit for me :)
  • #9 5879720
    kortyleski
    Help: 957
    Rate: 3860
    The servo is a combination of a motor, an encoder and an automaton that connects the encoder to the motor. As a colleague wrote above, it does not even have to be an electric motor, but most often they are because they are easy to control ...
    And how to control it, figure it out yourself buddy. Google will give a lot to the question about the separately excited motor, also about the control. now hang an encoder, potentiometer or other shit on the axis of this motor, turn on the appropriate automation between the motor control and the position sensor and you have your servo
    Regards
A servomotor is defined as a motor equipped with feedback mechanisms, typically including a position sensor and control electronics, allowing precise control of angular position. Unlike stepper motors, servomotors can maintain their position against external forces. Modern servomotors often utilize permanent magnet synchronous technology, characterized by low rotor inertia and high-resolution feedback systems. The discussion highlights that servomotors can vary in size and application, from small devices in model aircraft to larger systems in industrial machinery. Additionally, any motor capable of interfacing with an encoder can potentially function as a servomotor, provided it is integrated with appropriate control systems.
