Calculating Power Consumption for 3-Phase Devices with Different Currents: Using U, I & Clamp Meter
Prepond 43838 12
How do I calculate the power consumption of a three-phase device when the current is different on each phase and I only have a clamp meter?
For a three-phase load with different phase currents, you must sum the power of each phase: in star connection use P = Uf × (I1 cosφ1 + I2 cosφ2 + I3 cosφ3) with Uf = 230 V, and in delta connection use P = Um × (I1 cosφ1 + I2 cosφ2 + I3 cosφ3) with Um = 400 V [#6038247] If you measure current on the supply cables with a clamp meter, that is line current; in delta it is not the same as the phase current of each load branch [#6038247] Without the power factor cosφ, you cannot determine active power exactly from current alone, only apparent power; if cosφ = 1 then active power and apparent power are the same [#6042974] Uneven current draw is not normal for many 3-phase rectifiers and may indicate a fault, because in a 6-pulse rectifier the phase currents should be almost equal [#6056392]
  • #1 6036232
    Prepond
    Level 19  
    Help: 18
    Rate: 46
    I know that it is probably trivial, but how to count how much power, how many kW, is consumed by a device on 3 phases, with a different current on each phase (I have a clamp meter).
    Because for one phase it is standard P = U * I. How is it for 3?
    Thanks.
  • #3 6036454
    Prepond
    Level 19  
    Help: 18
    Rate: 46
    How do I have 400V interphase to the formula and I substitute 230? because this is the phase in terms of PE, right?
  • #4 6038247
    Tomisan
    By writing "device" I suppose that my colleague means one unbalanced 3-phase device connected to the power grid, and the question is how?
    In the star connection arrangement:
    P = Uf * Ip1cos?1 + Uf * Ip2cos?2 + Uf * Ip3cos?3
    Uf = 230V (for whistle calls with neutral connected to
    the neutral conductor, disregarding the conductor impedance
    neutral)
    Ip = line current measured with a clamp meter on the lines
    supply.
    In delta connection arrangement:
    P = Um * If1cos?1 + Um * If2cos?2 + Um * If3cos?3
    Um = 400V
    If = phase current - it should be measured with each load separately,
    however, it is not the current flowing in the power cables (Ip), only
    load current connected between two phases.
  • #5 6040274
    zubel
    Conditionally unlocked
    Help: 41
    Rate: 129
    You will do it almost without counting. Turn off all appliances in the apartment and record the meter reading. Plug in your contraption for an hour and write off the meter reading. Subtract what's used up and you've got the result
  • #6 6040767
    Prepond
    Level 19  
    Help: 18
    Rate: 46
    I would subtract but it's a factory :) I found out that the device consumes 133.4kW per hour. The phases were 160,210 and 210 amps respectively.
  • #7 6041753
    Stary1952
    Level 32  
    Help: 164
    Rate: 242
    And what a strange device that draws so unevenly electricity from the network. Often, such uneven consumption may indicate a defect of the device. :?:
    Greetings .
  • #8 6042856
    czesiu
    Help: 454
    Rate: 840
    If you simplify this, then for 3 phases you can take: P = U * (I1 + I2 + I3).
    Then you take 230V as U.
  • #9 6042974
    wola
    Help: 65
    Rate: 184
    Hello A it should not be 133.4kVA; unless the power factor = 1
  • #10 6044994
    Tomisan
    A colleague did not mention anything about the device itself, what kind of device is it? The colleague measured the current with a clamp meter, probably on the power cables. There was 133.4kW of active power. So maybe a colleague here will present us his calculations?
  • #11 6047399
    zubel
    Help: 41
    Rate: 129
    Write what device it is, if it's not a secret
  • #12 6055557
    Prepond
    Level 19  
    Help: 18
    Rate: 46
    This is a rectifier with an output rating of 22-24V DC and a current of 12,000 A. Consumption measured with an output load of 10,000 A.
  • #13 6056392
    Stary1952
    Level 32  
    Help: 164
    Rate: 242
    Uneven current draw indicates that one of the rectifier elements in the bridge is most likely damaged. In 6-pulse rectifiers, the current consumption should be almost the same in each phase.
    Greetings .
The discussion revolves around calculating the power consumption of a 3-phase device with varying currents on each phase. The standard formula for single-phase power (P = U * I) is adapted for three phases, where power can be calculated using either a star or delta connection. In a star connection, the formula is P = Uf * (Ip1cos?1 + Ip2cos?2 + Ip3cos?3), with Uf being the phase voltage (230V). In a delta connection, it is P = Um * (If1cos?1 + If2cos?2 + If3cos?3), where Um is the line voltage (400V). A user reported a device consuming 133.4kW with phase currents of 160A, 210A, and 210A, raising concerns about the uneven current draw, which may indicate a defect in the device. The device in question is identified as a rectifier with an output rating of 22-24V DC and a current of 12,000 A.
