Understanding Capacitor Voltage: Relationship between Capacity, Applied Voltage & Maximum Voltage
bandzior2 15629 7
  • #1 6091309
    bandzior2
    Help: 38
    Rate: 146
    I am interested in what the voltage on the capacitor means. This means that the maximum voltage can be applied to it or it will be charged with a different voltage and it will generate a higher voltage. For example, I have a 100uF 35V capacitor. I will apply a voltage of 12V to it. I will take a meter and measure the voltage on the capacitor and it will be 35V or 12V?
    Kacza82
    Help: 7
    Rate: 9
    The 100u / 35V capacitor can connect max. 35V.
    And when there will be more ...
    And as for applying tension, how much you will have to apply.
  • #3 6091335
    bandzior2
    Help: 38
    Rate: 146
    And if I pass 12V through it (that is, I will connect the current source to the capacitor and the bulb connected in series with each other).
    ololukiXP
    Level 19  
    Help: 34
    Rate: 84
    The voltage across the capacitor is its maximum operating voltage. If, for example, you charge the capacitor with 12V DC, the meter will show 12V. The capacitor does not generate any higher voltage.
    Measured capacitor voltage versus rated voltage
    #5 6091340
    Quarz
    Help: 1646
    Rate: 629
    It is necessary to clearly distinguish the current voltage between the capacitor's facings and resulting from its capacity and the electric charge accumulated in it, from the nominal - allowable - operating voltage for this capacitor.
    Capacitor charges to applied voltage, with brief DC pulse
    #6 6091341
    Macosmail
    Help: 227
    Rate: 862
    It will charge up to the voltage to which you connect it, and the voltage on the housing means the maximum operating voltage, exceeding which may damage it. Regards.
    Added after 7 [minutes]:
    If it is a DC voltage source, the bulb will not light. At the moment of connection, a short current pulse will flow, which, depending on the power of the bulb, may cause it to flash. If you want to know why this is happening, read about capacitors, capacitive reactance and constant charging. Regards.
  • #7 6091691
    bandzior2
    Help: 38
    Rate: 146
    I know because the capacitor is charging and then the bulb will not light up and when it is charged it gives its energy and then the bulb will flash and so on over and over again.
  • #8 6091743
    Macosmail
    Help: 227
    Rate: 862
    Well, not really; P it is during the charging of the capacitor that a current flows, which can cause the light bulb connected to this capacitor to flash in series. When the capacitor is charged, this current drops to zero and nothing else happens. Regards.
The discussion centers on the voltage characteristics of a 100uF 35V capacitor. It clarifies that the maximum voltage rating (35V) indicates the highest voltage the capacitor can safely handle without risk of damage. When a voltage of 12V is applied, the capacitor will charge to that voltage, and a multimeter will read 12V across its terminals. The capacitor does not generate a higher voltage than what is applied. The conversation also touches on the behavior of the capacitor in a circuit with a bulb, explaining that the bulb may flash briefly when the capacitor is charging, but will not light continuously once the capacitor is fully charged, as the current flow ceases.
