What does uf stand for on a 10V 100uf capacitor in electronics?
34330 2
  • #1 5257985
    zdzicho44
    Help: 30
    Rate: 117
    The notation uf stands for microfarads or 0.000001 Farad. This is the designation of the capacitance of the capacitor. Yours is 100uF or 0.0001F
  • #3 5258034
    alio
    Rate: 16
    10V simply means maximum operating voltage. In short, if you exceed the voltage of 10V (volts) on the capacitor terminals, it will simply fail once and for all.
    100uF - it was probably 100µF (one hundred microfrarads) means its capacitance. You will find the definition of a farad in physics books and a microfarad is one millionth of a frard. In practice, there are also millifarads (mF), nanofarads (nF) and picofarads (pF). read in any book on the basics of electronics. Good luck.
