How to find drivers by Hardware ID without knowing the device model?
DriverMSG 1332494 4
  • Searching for drivers on the Internet without knowing the device model.
    1-Connect the device to your computer.
    2-Enter the device manager.
    3-Find the unknown device and enter its properties, tab " Details ".
    4-Please write down the Equipment ID. This can be several lines, depending on the device.
    example: PCI\VEN_168C&DEV_0013&SUBSYS_5A001385 or USB\VID_12FD&PID_1001&REV_0100
    5-The device ID will help us search for drivers on google - so we search for that particular ID.
    6-Often already the first links from google will lead us aptly to the device name or even to its drivers.
    Please pay attention to the screen - the first link says that it is Netgear Atheros AR5002G , and the link leads to the page where you can most often find the driver, i.e.: www.driverguide.com
    Unfortunately this site requires a login, and lately it has been difficult to log in there, but this should not discourage you in your further search.
    7-Go to the aforementioned page by clicking on the link you found, and there on the " File List " tab
    8-This will show us the name of the file - in this case " wg311t_vista_beta.zip "
    9-The one who has an account on the aforementioned website will of course download this file for himself, the others have to search for this file on google.
    10-Seeking this file you may come across many foreign language sites, but they will certainly lead you to your destination:
    How to find drivers by Hardware ID without knowing the device model? How to find drivers by Hardware ID without knowing the device model? How to find drivers by Hardware ID without knowing the device model?
    All that remains is to download and install the driver.
    Keep in mind that many third-party devices are copies of well-known productions, so the drivers may also fit.
    For a long time now, fake driver sites have been springing up, often forcing unadvanced users to download unnecessary malware that will supposedly install the driver for them.
    Sometimes the driver will be correct, but along with it we get junk in the form of new searchbars, toolbars, unnecessary browser add-ons, or changes to the browser's start page.
    To avoid the aforementioned problems, I present below, my way of searching for drivers.
    Search on http://www.downloadwindowsdrivers.info/
    There is no great philosophy here. just select what you are looking for one by one, e.g:
    - We are looking for a driver for a music card with ID
    HDAUDIO FUNC FUNC _01& VEN _10EC& DEV _0888& subsys _103c2a34
    We select
    HDAUDIO
    FUNC_01
    VEN_10EC
    DEV_0888
    A list of drivers should already be available at this stage, but if we have the option and our [subsys] is in the list, select it.
    subsys_103c2a34
    You get a list of drivers with a description of their version, release date and file name by which you can make a selection for your operating system.
    Please note that [subsys] does not always have to match and about 90% of the time is irrelevant to our system.
    However, there are exceptions, often in laptops, that [subsys] must be identical.
    Search at www.driveridentifier.com.
    The website itself does not offer a search for the driver, instead pushing a redundant programme on us by force.
    However, you can use google by typing in the name of the site and our ID.
    Link
    The first link directs us to this page - screen.
    As you can see, there is our ID, the type of operating system the driver is for, as well as the possibility to download it.
    The site requires a login, but the registration itself is not verified.
    So you can register with any data you can think of:
    In the next steps, we double-check that we cannot afford the driver fee:
    A message will appear in which we click on the link:
    And in effect a landing page in which there is a link to the driver:
    • Wyszukiwanie sterowników w internecie bez znajomości modelu.pdf (552.28 KB) You must be logged in to download this attachment.
    DriverMSG
    DriverMSG wrote 44094 posts with rating 4887, helped 3984 times. Live in city DST. Been with us since 2005 year.
  • #2 6151616
    Mery84
    Help: 427
    Rate: 271
    The above screen is from Vista to XP, the properties window is slightly different and we find the identifier like this:
  • #3 6151804
    DriverMSG
    Help: 3984
    Rate: 4887
    Identification of the equipment can also be done in the program EVEREST - tab EQUIPMENT .
    Added after 1 [hour] 17 [minutes]: .
    When looking for drivers, using the hardware identifier, often after typing the whole google does not find anything , in this case you should select only the most important elements of the identifier which are :
    VID / PID , VEN / DEV
    example of google entry :
    VID_3456 PID_4456
    or
    VEN_168C DEV_0013
  • #5 7328313
    jarewa
    Help: 229
    Rate: 529
    Gentlemen, a small thing, as we already know what the identifier is and we will download the drivers, before installing it, it would be good to view the * .inf file in the drivers and check if our identifier is on the list. If so, go ahead and install, if not, do not install. Because it often happens that we download from an uncertain source. And when we install it, something is always left in the system (garbage) and sometimes there are more problems with installing the correct one.
    If the file is in compressed form, it is enough to preview it with the program or extract it. If it is with the * .exe extension and in the form of installation, it unpacks itself during installation to the tmp folder. Then just copy the folder and stop the installation at the extract level.
    And this is what it looks like in the inf file -
