Understanding the Origin of a Mysterious 7-Digit Caller Number 3277458
Citek 18439 3
  • #1 6339191
    Citek
    Help: 13
    Rate: 52
    I would like to know what this number is:
    3277458
    Someone just called my cell phone, unfortunately I didn`t answer it in time.
    I`m asking because this issue is strangely short.
    Every normal number has 9 (601-602-603) or 10 (022-1-234-567) digits, but this one has only 7, which is quite too few.
    Has anyone encountered such a case?
    PS.
    I don`t know if it`s the right section, but somehow this seemed to be the most accurate one, if not, please move it.
  • #2 6339224
    mlassota
    Help: 11
    Rate: 85
    This is the number from area code 32, then 774 58 xx and here is the internal number of the TP headquarters
    There are such systems in companies where the last 2-3 numbers are an extension and sometimes they identify themselves without this extension - so you can`t call back :) (you can try with 00 at the end but not sure what the range of internal numbers is)
    Regards
  • #3 6339238
    Citek
    Help: 13
    Rate: 52
    Oh, well, if you say so, maybe it is.
    Thanks for the help
  • #4 6340184
    eslodowy
    Help: 119
    Rate: 102
    The number is exactly abbreviated, sometimes customer service offices use this number presentation instead of a private/restricted one.
