Connect Car Amplifier: Amplifier Installation Guide, Power Cables, Radio Wiring, Front Panel
rafal9018 85584 5
  • #1 7886313
    rafal9018
    Rate: 26
    Hello :)
    My problem is to connect the amplifier in the car :) the whole installation is done, but .. I don't really know how to connect it. There are three power cables, I understand that one is a plus and the other is a minus. And the third ??? I read various topics and understood that this is a cable that controls turning the amplifier on and off. Please help :) I am attaching some photos for easier presentation of my problem ...
    This is the front panel of the amplifier, a red plus :) blue minus :) and the third ?? The cable indicates how it would be mass, but where to connect it? The fuse is only in the picture, because I just replaced it :)
    This is the back of my radio, where should I connect this green / yellow cable so that the amplifier turns on ?? I am asking you for help :)
    greetings :)
  • #2 7886376
    kamil907
    Help: 66
    Rate: 160
    It is possible that the amplifier is already gone if you have connected it so. The blue (-) should go to the left, and the center should be + 12V, it is best to connect it with a blue or blue-white cable from the radio, usually marked as REM or something with the antenna because it also serves to power the antenna. You can also permanently connect +12 from the right terminal with a short cable, but then the amplifier will be turned on all the time. The red one on the right remains as it is now.
  • #3 7886621
    rafal9018
    Rate: 26
    Oh, it was bad from the beginning :( can you tell me exactly or show me in the picture which cables these can be ??
  • #4 7886916
    kamil907
    Help: 66
    Rate: 160
    From what I can see REM is the blue one that comes out next to the red cube and connect it to the REM connector on the amplifier. Minus from the battery or a short cable from the car body to GND, and + 12V is known from the battery.
  • #5 7889054
    damiw
    Rate: 21
    I noticed that you do not have a fuse on, so take care of it. (20A fuse)
  • #6 7889134
    kamil907
    Help: 66
    Rate: 160
    A colleague wrote in the first post that, in general, the fuse is in place only in the photo it is not.
