Urgent: Understanding Schematic Diagrams - Theory, Purpose, and Applications (Max 90 Characters)
liber18 42179 5
  • #1 992017
    liber18
    I urgently need a schematic diagram theory!
    what is it, what is it for, etc.
    Subject corrected, the next reserve will be a warning.
  • #2 992033
    000andrzej
    Level 37  
    Help: 302
    Rate: 238
    The schematic diagrams are used to let you know what a given device (circuit) consists of. Look for the markings of individual elements in any guide, and then look at any diagram and try to identify them. Letters, such as R, C, should also be. In addition to the diagram, you would need to know the principle of operation so that you can identify what the elements are responsible for.
    This is the beginning of the introduction to the prelude ;)
    I do not know what you need it for, as for a paper, then my speech will not help you. If you want to start your adventure with electronics, treat it as a guide.
    Probably others will say more. If you have specific questions - it will be easier.
  • #3 992102
    liber18
    correct! I need this information for the paper!
    I already have about block diagrams, but I can not find anything about schematic diagrams :( And this paper I have to hand over tomorrow!
  • #4 992142
    Paweł Es.
    Help: 1236
    Rate: 693
    The schematic diagram is a graphic representation of the type of electronic components (electric, hydraulic, pneumatic) used in the system and their interconnection. The diagram also includes the order numbers of the elements (R1, T1 etc.) and their factory types (eg BC 107). Additional information is: voltages, currents or electric waveforms in the system and the states of the system in which they were measured. Schemes can be single-page and multi-page. In the case of the latter, individual diagrams should contain information about the transitions of individual signals between individual diagrams that are parts of the whole, and there should be one main diagram (hierarchical layout) describing the relationships between the individual diagrams and the location of all blocks throughout the project.
    Particular diagrams should contain logical (in the construction sense) blocks of the circuit for the sake of readability. The diagram should, if possible, be drawn in such a way that the direction of the signal flow corresponds to the reading direction (from left to right) and the voltage supply, the higher the potential, the higher on the diagram.
    Schematic information plates provide: project name, scheme name, author, creation date, modification date, scheme sequence number, number of all schemes.
  • #5 7889870
    LukasSandyra
    Hello, I have a problem because I am a beginner, how can I interpret the circuit I circled in red?
    should I power the microprocessor system from it or what?
  • #6 7889912
    Wojtek.zse
    Help: 165
    Rate: 52
    It is a voltage stabilizer integrated circuit, the output of which is stabilized DC voltage of 5V. The current capacity of this system, depending on the type of stabilizer, may be 1A or 1.5A. From the point marked as + 5V and GND, you can power with the appropriate polarity, as you write, e.g. a microprocessor. Next to the picture is Atmega8 - pin 7 of Atmega is the point where you connect + 5V and pin 8 is ground.
