How to Understand Complex Electronic Circuits Beyond Simple Series/Parallel Models?
294 10
How can I understand the behavior of a complex electronic circuit when there is no single linear path that the signal follows?
You do not understand a complex circuit by tracing one marble-like path; its parts interact concurrently, so you analyze the network as a set of simultaneous relationships rather than a sequence [#21670799] In a linear circuit, Kirchhoff’s laws often lead to simultaneous equations or matrices, because current and voltage at one node can affect many others at once [#21670799] The same applies to feedback systems and active filters, where multiple branches influence each other instead of one branch simply being chosen [#21670799] For digital circuits, many operations happen in parallel within the same clock cycle, so a microcontroller emulating them would need many sequential instructions [#21670799] Ground is just the common return/reference point, like a sea that all branches flow into; currents split among branches before reaching it, and with good layout the effect of distant grounded parts on each other is usually small [#21670805][#21670799] To build intuition, start from the basics, use simulation tools like Spice, and do hands-on experiments with simple projects [#21670804]
  • Explaining current flow in complex circuits
    #1 21670796
    Legion Rempel
  • How to infer signal flow from schematic symbols
    #2 21670797
    Ruben Proost
  • Need for a method to determine circuit operation order
    #3 21670798
    Legion Rempel
  • Circuit elements interact through the whole network
    #4 21670799
    Garth Wilson
  • #5 21670800
    Legion Rempel
  • 6502 primer recommended for beginner computer builders
    #6 21670801
    Garth Wilson
  • 6502 computer with RS-232 PC interface
    #7 21670802
    Legion Rempel
  • RS-232 is bidirectional, needing one UART
    #8 21670803
    Garth Wilson
  • Recommend learning electronics through basics and practice
    #9 21670804
    Frank Bushnell
  • #10 21670805
    Frank Bushnell
  • #11 21670806
    Legion Rempel
The discussion addresses the challenge of understanding complex electronic circuits beyond simple series and parallel configurations, especially for those with a programming background accustomed to sequential data flow models. Key difficulties include tracing signal paths in interconnected circuits and grasping concurrent operations within components such as microcontrollers and analog circuits. Explanations highlight the importance of recognizing component functions—transistors, operational amplifiers, microcontrollers—and their interactions, including power supply roles (+12V, GND). The concept of concurrent processing in hardware contrasts with sequential programming logic, complicating mental modeling. Suggested learning approaches emphasize starting with fundamental electronics principles, using mental models like the water pipe analogy, and employing circuit simulation tools such as SPICE. Practical hands-on experimentation with inexpensive components and multimeters is recommended. Resources for beginners include online tutorials and primers, notably a comprehensive 6502 microprocessor primer and an RS-232 communication primer, which support building simple microprocessor-based projects with serial interfaces for programming and debugging. The discussion also references the Z80 and 6502 microprocessors, noting the legacy and educational value of the 6502 architecture for hobbyist computer construction.
