Leaky V-Type Radiator: Repairing H-Type Valve or Screw Connection in Heating System
jamal_gda 57596 10
  • #1 10571053
    jamal_gda
    Rate: 18
    Would someone be able to tell me how to start repairing a leaking radiator? From what I read, it is a V type radiator. It is connected from the bottom with an H-type valve. It leaks either on this valve or on a screw connection. Tightening more resulted in more leakage. Please help me quickly because I am currently sitting without heating :) . ps. How to properly tighten this radiator?
    Mod. ROBSON33
    Regulations 3.1.13. (10.9, 15)
    It is forbidden to publish entries that violate the spelling rules of the Polish language, careless and incomprehensible.
    Please correct the post without deleting the above post.
  • #2 10571057
    1tropek
    Help: 30
    Rate: 152
    Is there a leak between (on your "nose") the valve and the radiator?
  • #3 10571146
    MarudaP
    Help: 24
    Rate: 237
    If you tighten harder and the water flows harder, you will need to install a new O-ring or gasket (what's there). You have to disconnect the heater and replace it.
  • #4 10571367
    markmd
    Help: 49
    Rate: 278
    You can seal with modeling clay quickly and temporarily, and then make a repair that requires unscrewing the radiator.
  • #5 10572308
    jamal_gda
    Rate: 18
    on my nose the situation looks like this. They are from above
    1. Heater
    2. Gold nut (so thin) with thread directly adjacent to the radiator
    3. A thick silver cap between the valve in the shape of the letter H and with the inscription H and the gold cap from point 3.
    4. H-type valve
    The leakage to my eye is between 2 and 3 or between 3 and 4
  • #6 10572372
    1tropek
    Help: 30
    Rate: 152
    1. Heater
    4. H-type valve
    In other words, with a high degree of probability, if you use a wide screwdriver to set the notches on the valve (both) horizontally (closed position), water will only leak from the radiator. The rest of the installation can be used after adding water.
    There should be a vent on the radiator - after closing the valve, check that water is leaking from the vent. If it is leaking from the breather, you have turned it off incorrectly.
    Take photos.
    If you have turned correctly and the water stops leaking after a while, you have time to think carefully what to do next.
    Take pictures of the connector.
  • #7 10575503
    jamal_gda
    Rate: 18
    I took a photo. A little overexposed, but it's from the phone. https://obrazki.elektroda.pl/5375055000_1329776623.jpg. The valve on the right is leaking. Unfortunately, setting the adjustment in the horizontal position does not help. I can turn it freely in any direction. For now, the heating will remain off.
  • #8 10575986
    MarudaP
    Help: 24
    Rate: 237
    After setting the valves to 9-15, you put some water collecting vessels and slowly unscrew the screws. After emptying the radiator of water, unscrew it completely, remove the radiator and replace with both sealants. You put on the radiator and tighten it sensitively. You open one valve completely, and you fill the radiator with the other, with the venting turned on. If water seeps from the valves, tighten the flare nut slightly.
  • #9 10576096
    jamal_gda
    Rate: 18
    are these sealants some o-rings? What to ask for in the store?
  • #10 10576429
    MarudaP
    Help: 24
    Rate: 237
    There may be o-rings, but there may be flat gaskets. Since the heating element does not heat up anyway, close the valves and let the water flow out. After unscrewing it you will see what is there.
  • #11 10585025
    jamal_gda
    Rate: 18
    problem solved. thanks for the help
✨ The discussion revolves around repairing a leaking V-type radiator connected to an H-type valve. The user reports leakage at the valve or screw connection, exacerbated by tightening attempts. Responses suggest checking for leaks between the valve and radiator, replacing O-rings or gaskets, and using temporary sealants like modeling clay. A detailed procedure is provided for draining the radiator, replacing seals, and reassembling it. The user confirms the issue is resolved after following the advice given.
