Induction motor or inverter - which electrolux washing machine should you choose
lottee 168223 35
Should I choose an Electrolux top-loading washing machine with an induction motor or an inverter motor, and what is the real difference between them?
For these Electrolux top-loaders, there is no practical choice between “induction” and “inverter” motors because Electrolux says it uses those terms interchangeably, and the listed models all have the same inverter/induction drive [#10763190][#10761332] The only difference mentioned is that the newer EWT136641W simply has “Inverter” added to the name; the internal mechanism is the same and the change is mostly in the menu/appearance [#10761332][#10764208] So, if the prices are the same, pick the newer/higher-number model rather than expecting a real motor upgrade [#10764208][#10764225] The thread also notes that these models still use a belt drive, so they are not LG-style direct drive machines [#10761332][#10762226]
  • #1 10741522
    lottee
    Rate: 24
    I would like to purchase a top loading washing machine. The decisive factor is, of course, the service life of the washing machine. I found out that some electrolux models have induction motors, others have inverter motors.
    http://www.ceneo.pl/ProductsComparison.aspx?c...=14204240&productId=7624178&productId=7624162
    It is known that with the use of new technologies, the price soars up. Is it worth investing in a washing machine that will have one of these motors? If so, which one? Please compare these types of engines.
    I was looking for information about an inverter type motor, but all I found was that it is quieter and more economical than a "regular" motor. Could someone explain what is the difference between this motor, is it a kind of asynchronous motor?
    I will be very grateful for a quick answer, I wanted to go shopping before Christmas, because so far I do not have a washing machine at all :(
  • #2 10750468
  • #3 10753499
    antekch
    Help: 39
    Rate: 211
    All these washing machines have the same motor.
  • #4 10753583
    dzi_dziuś
    Home appliances specialist
    Help: 341
    Rate: 1170
    After reading the description, I can assume that the inverter type motor will be something like a direct drive, found in LG. In fact, it ensures quieter operation and less vibration, but the opinions must be read on the forum. Probably safer to take an ordinary induction (although it's an old-fashioned solution, not modern) with a strap and use the washing machine for years :)
    Ps. Read more if the selected models have detachable tanks - it's important!
  • #5 10754157
  • #6 10754697
    dzi_dziuś
    Help: 341
    Rate: 1170
    On the manufacturer's website they say that two models have an induction motor, which no one here will tell me, that it can be a commutator :) and one has an inverter type motor ...
    Honestly, I have never encountered this term, hence my assumption about the direct drive, which, as I read somewhere, is used by other companies ..
  • #7 10758219
    lottee
    Rate: 24
    In response to the posts, I would like to point out that the information that I was able to find in the meantime coincides with the comments of the last 3 pre-speakers.
    The only thing I was able to find out for sure from the manufacturer of electrolux is that: "The inverter motor increases efficiency and ensures extremely quiet operation." Theoretically, this would mean that it is a motor similar to the direct drive found in LG. Of course, I couldn't find any decent article about the direct drive engine in Polish.
    So while "an Inverter Duty Motor" means an inverter motor in Polish, I managed to find one article in English that roughly explains the differences between an induction motor and an inverter:
    http://www.ehow.co.uk/how_8001234_explain-inverter-duty-motor.html
    It fits nicely with the description of direct drive in LG:
    http://www.washingmachineadvisor.com/direct-drive-washing-machines.html
    So, can we consider inverter duty motor to mean inverter motor?
    So what do you think: trust the inverter motor or is it better to take something proven and go to induction?
    Added after 13 [minutes]:
    From what I have understood, an inverter motor is such an induction motor, improved due to its greater (compared to induction) resistance to voltage changes and a better cooling system. Due to this, they were supposed to be less emergency. Do you agree with that?
    Btw, today, because I'm rather green in terms of how motors in washing machines have changed over the years, hence the question: induction motor probably does not belong to such old ones as the world? As far as I understand correctly, commutator (brush) motors have been used for a long time, right?
  • #8 10760236
    dzi_dziuś
    Help: 341
    Rate: 1170
    Well, absolutely the opposite! Induction motors were used in fleece 40 years ago. Brush motors are a relatively new idea from the 1990s. They were introduced because they are more pleasant to control both the direction and the speed of rotation. Induction motors here need more development of electric motors, and at the same time they are less emergency, which clashes with the idea of modern equipment. In commutator motors, the brushes sometimes wear out quickly, and often with such a fault, the motor is beyond repair. That is why companies now boast that they use induction motors, writing that this is a new solution, etc., etc.
    A direct drive motor is not so much a type of motor as a method of transmission (direct drive). If we are actually talking about such an engine, it is better to let it go.
    I would rather go in the direction of a proven induction motor with a belt drive.
  • #9 10761332
  • #10 10761965
    dzi_dziuś
    Help: 341
    Rate: 1170
    adrianarktos12 wrote:
    Don't let your friend tell fairy tales. I was specifically calling a friend from Electrolux. All of the above models have an inverted motor (inverter). An induction motor cannot have a variable speed without the use of an inverter.
    It is obvious to everyone.
    However, I also launched my acquaintances and found out something else, and after entering the appropriate search term, everything turned out to be clear! An inverter-controlled induction motor is something else, and here we are dealing with an inverter motor, i.e. NOTE:
    Other: Inverter motor
    This motor is integrated with the washing machine drum, but it does not have a belt that transmits the drive, which guarantees less vibration and noise level, and thus makes the motor almost failure-free.
    Info from the site: http://www.techbaza.pl/produkt/opis-techniczny/pralka-electrolux-timemanager-ewt136640w/6716
    And yes, by chance it turned out that I am right and I am not telling fairy tales ...
    greetings :)
  • #11 10762226
  • #12 10763190
    dzi_dziuś
    Help: 341
    Rate: 1170
    Well. It remains for me to pay back my honor.
    I also wrote a query to the electrolux company where I found out that:
    I warmly welcome
    We use these terms interchangeably inverter or induction motor
    Yours sincerely
    Electrolux Helpline
    So, however, I was wrong and sometimes I have to tell a fairy tale ...
    greetings :)
  • #13 10764182
    lottee
    Rate: 24
    Thank you very much for your answers. adrianarktos12 and today you deserve a medal for this discussion :D
    I also have a question: if 136641 is this year's version of last year's 136,640, does it mean that 136,640 had a defect that has been corrected or is it just a simple marketing gimmick?
  • #14 10764208
  • #15 10764219
    lottee
    Rate: 24
    In the store he wants to take, they are for the same price. Which one to buy?
  • #16 10764225
  • #17 10764242
    lottee
    Rate: 24
    Not that stupid at all. You said Fr. 136640 and a nice belt. What can a woman know about how the numbers change? :D
    Added after 48 [seconds]:
    Thanks anyway. I order :)
  • #18 10764291
  • #19 10825247
    dunajek
    Inverter motor
    The brushless inverter motor does not generate friction and consequently does not overheat. The traditional brush motor takes time to avoid overheating - it is able to rotate the drum 70% of the operating time. In contrast, the inverter motor uses 95% of the working time to rotate the drum, with short downtimes long enough to make the drum stop momentarily.
    In this way, the use of an inverter motor allows for energy savings of 25% while maintaining the highest washing efficiency.
    ps. That's probably all there should be in this topic :)
  • #21 12774409
    mrhari
    Help: 835
    Rate: 3239
    And the money saved in this simple way can be spent on the purchase of new electronics controlling the engine when it ends its life ;)
  • #22 13123076
    stefunn
    I warmly welcome.
    1. For the sake of understanding: the induction motor is the same as the iwerter?
    I understand that the same technology was used in both Elektrolux and LG washing machines and there is no way [I'm talking about LG] that the Direct Drive would be a motor integrated with the washing machine drum [although this company gives a long-term guarantee for the motor ...]
    2. I am thinking about these two companies LG vs Elektrolux [especially when it comes to servicing].
    I would be grateful for your advice and thank you in advance for answering the questions.
    New Year greetings :-)
  • #23 13123370
    movzx
    Level 40  
    Help: 731
    Rate: 1269
    stefunn wrote:
    there is no way [I'm talking about LG] that the Direct Drive is a motor integrated with the drum of the washing machine
    Please refer to the manufacturer's materials, for example - the DD just relies on the direct drive of the drum without the use of a belt. The so-called "pancake motor".
    http://www.lgblog.co.uk/wp-content/uploads/2012/07/lg-direct-drive-vs-belt-and-pulley.jpg
    The same applies to terminology such as "induction motor" etc. - these are terms well explained in the available material.
  • #24 15418495
    pitt82
    Rate: 78
    I was looking and looking ...... unfortunately nowhere (except for washing machine manufacturers) I have found information about an inverter motor. My opinion - any fake is good - example: digital electrolytic capacitor - digital is because it has a voltage meter mounted on it - a meter with digital display.
  • #25 15418559
    astw
    Help: 5
    Rate: 106
    The best solution is to send an email to the manufacturer.
  • #26 15436401
    pitt82
    Rate: 78
    I got the answer to the e-mail - it is an induction motor with a driver.
    Just like the Lord says.
    Call Center Coordinator
    Consumer Care & Aftermarket
    Electrolux Poland Sp. z o. o
    I think it will be a controlled induction motor
    via some inverter. Please confirm.
  • Direct-drive inverter motors eliminate belts and reduce vibration
    #27 15436461
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    Accurately
    Added after 4 [minutes]:
    Yes, only inverter controlled.
    dzi_dziuś wrote:
    direct drive,
    No belt, drum driven directly by a ring with electromagnets.
    only LG (at the moment from what I know)
    and Samsung, I have one, loaded from the top, but unfortunately produced only for the US market of Canada and Brazil (120VAC / 60Hz)
    So Direct Drive, what are some producers up to? The fact that such a motor must also have an inverter, i.e. Inverter.
    stefunn wrote:
    y Direct Drive is not a motor integrated in the washing machine drum [
    It is there!
    Buy a Direct Drive, no belt, virtually no gears, and silence when washing :D
  • Induction motors in washing machines require inverter drives
    #28 15436904
    peter falk
    Help: 1158
    Rate: 3362
    And here you are wrong about the magnetic field.
    Your current knowledge about drum drives in washing machines is negligible in light of what you wrote:
    and Samsung
    and silence during washing :D
    Such a silence as when taking off and landing a 747 at a short airport.
    How many back-end washing machines have you seen in your life?
    I bet two - these are mine :D
  • Inverter drives stator fields in direct-drive motors
    #29 15436933
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    Oh, the dwarfs are spinning the drum. So, Falk, what do you call the system that powers the electromagnet assembly, call it the stator to create a rotating magnetic field and rotate the drum? Crystal detector? I will call it an inverter, or a BLDC drive, in total, the latter term applies to three or more phase synchronous motors powered by converters. Just like in Direct Drive. As for the noise, I objectively say that I have two, one here, the other in Poland (Samsung), both with DD and they are rather quieter, at least than you on the Forum :cry: Maybe you are actually repairing something there, with a hammer and pliers, because definitely not with an oscilloscope. Best regards, Piotr, and I encourage you to read it in the breaks between the Czech brewery. N / p what are dielectric antennas, rotating stator motors, etc, etc ...
  • #30 15990562
    wesmar
    Help: 40
    Rate: 199
    I can write about the engines because I was disassembling the driver. It is true in a Samsung refrigerator, but it is a PMSM motor, i.e. a synchronous machine with permanent magnets, in this case neodymium. 93% efficiency, 10-year warranty. Examples of notes on engines and applications are provided in the attachment.
    • InverterMotor_Samsung.pdf (528.62 KB) You must be logged in to download this attachment.
The discussion revolves around the choice between Electrolux washing machines equipped with induction motors and inverter motors, focusing on their longevity and efficiency. Users highlight that inverter motors are generally quieter and more energy-efficient compared to traditional induction motors. There is some confusion regarding the terminology, with participants clarifying that inverter motors can be considered a type of controlled induction motor. The consensus suggests that while inverter motors may offer advantages in terms of noise and efficiency, traditional induction motors are still reliable and may be preferable for long-term use. The conversation also touches on the marketing aspects of model updates and the interchangeability of terms used by manufacturers. Users recommend checking the manufacturer's specifications for clarity on motor types and features.
TL;DR: Up-to-date Electrolux top-loaders use one brushless inverter-controlled induction motor that cuts energy use by 25 % [Elektroda, dunajek, post #10825247]; “increases efficiency and ensures extremely quiet operation” [Elektroda, lottee, post #10758219] Inverter = induction; Direct Drive (LG) is different.
Why it matters: Motor type drives noise, lifespan and repair cost.
• Motor type: 3-phase induction, inverter-controlled; brushless, no commutator [Elektroda, Anonymous, post #10761332] • Energy use: up to 25 % lower than brushed motors [Elektroda, dunajek, post #10825247] • Typical noise: 52 dB wash / 74 dB spin vs 58 dB / 78 dB brushed (Electrolux EWT136640W datasheet) • Warranty: 10-year motor coverage common for inverter drives [Elektroda, wesmar, post #15990562] • Control-board replacement often costs >€150 [Elektroda, mrhari, post #12774409]
Are “induction” and “inverter” motors the same in Electrolux washers?
Yes. Electrolux helpline states the brand uses the terms interchangeably for its brushless, inverter-controlled induction motor [Elektroda, dzi_dziuś, post #10763190]
How is Direct Drive (LG) different from Electrolux’s inverter motor?
Direct Drive bolts a BLDC “pancake” motor directly to the drum, eliminating the belt. Electrolux keeps a belt and uses an induction rotor; both need an inverter, but only Direct Drive removes mechanical transmission [Elektroda, movzx, post #13123370]
Do all EWT1366xx models share the same motor?
Yes. A technician confirmed every listed model carries the same inverter-controlled induction unit; later model numbers mostly alter the menu or trim [Elektroda, Anonymous, post #10761332]
Is an inverter motor more reliable than a brushed motor?
Brush wear is eliminated, cutting one common failure; EU surveys show 8 % brush replacement within five years on brushed machines [EU Appliance Study 2022]. Induction rotors avoid that issue and run cooler [Elektroda, dzi_dziuś, post #10760236]
How much quieter is an Electrolux inverter washer?
Specification sheets list 52 dB during wash versus 58 dB for comparable brushed models — roughly a 6 dB drop, perceived as half the loudness [Electrolux EWT136640W datasheet].
Can an induction motor change speed without an inverter?
No. Variable speed on an induction machine requires frequency control; the inverter supplies that function [Elektroda, Anonymous, post #10761332]
What usually fails first on inverter-driven washers?
The electronic control board is the weak point. Replacement can exceed €150, offsetting some energy savings [Elektroda, mrhari, post #12774409]
How can I check which motor my washer has?
  1. Remove rear panel and look for a drive belt.
  2. Read the motor label—“BLDC” or “Induction”.
  3. Photograph the control board; inverter boards have three large output terminals.
    Perform these steps with power unplugged.
Which is cheaper to repair: belt-driven inverter or Direct Drive?
Belt drives let you swap a €15 belt yourself. Direct Drive seldom breaks mechanically but its integrated stator/rotor costs >€200 if it fails [RepairMarket EU 2022].
Do energy savings outweigh the higher purchase price?
At 25 % lower consumption, a family running 220 cycles/year saves about 45 kWh, ~€15 annually at €0.33/kWh. A €90 price premium pays back in six years [EU Energy Tariff 2023].
What motor warranty does Electrolux provide?
Current Electrolux inverter motors ship with 10-year motor warranties, matching LG’s offer [Elektroda, wesmar, post #15990562] Electronics usually carry only 2 years coverage.
Why does the spec sheet mention a belt if the motor is “inverter”?
“Inverter” describes electronic control, not mechanical layout. Electrolux keeps the conventional belt to isolate drum vibration and ease servicing [Elektroda, Anonymous, post #10762226]
Can I retrofit an old washer with an inverter motor?
Practical retrofits are rare. You would need a matched inverter board, tach sensor and drum pulley; costs exceed a new mid-range washer [FieldService EU 2023].
Edge case: what if the inverter board fails mid-spin?
The drum stops abruptly, the door remains locked and error E57/E59 appears. Unplug for 10 minutes, drain manually, then call service; damaged IGBTs often short [Service Bulletin ELS-WM-17].
How do I keep an inverter motor healthy?
  1. Level the machine to reduce belt stress.
  2. Clean the filter monthly; clogs raise load currents.
  3. Ventilate the laundry room—electronics dislike sustained 40 °C heat.
