AEG L9FEC49S vs ELECTROLUX EW8F248BP: Comparing Washing Machines for a 4-Person Household
ssawka 19248 13
Which washing machine should I choose for a 4-person household if I want long service life and easy repairability: AEG/Electrolux or another brand?
The forum advice is to avoid the current AEG/Electrolux models and look instead at serviceable LG, Bosch-Siemens, or possibly Amica machines, because modern AEG-Electrolux washers are said to have non-replaceable bearings and frequent control-module failures [#17502477][#17502547][#17506189] LG is the most strongly recommended alternative, since it is described as having replaceable bearings and cheaper servicing/parts than the competition [#17502603][#17506310] Bosch-Siemens is also mentioned as offering several serviceable models [#17502477][#17506189] Amica may be cheaper and serviceable, but it is also described as using electronic drivers or motors that increase risk [#17506189][#17506310] Miele is said to be higher quality and more durable than most brands, but repairs can be very expensive if something does fail [#17507348]
  • #1 17502455
    ssawka
    Rate: 14
    Dear colleagues,
    For over 20 years we have been intensively using the electrolux washing machine, which this year got breathless, and I even had an attempt to repair, but the command of our 4-person unit decided that it wanted a new one that would not turn yellow, and without the risk of time. and the money spent on replacing the engine and its control module will not end up with another failure of another element of such a worn-out device. We are now faced with the decision to choose a washing machine. Due to the positive experience, we believe in the Electrolux brand, but a lot could have changed in 20 years. I would be grateful for advice resulting either from personal experience or from professional experience - e.g. service - which one to choose. Reading the technical data and instructions for use shows that these devices have so many similarities that it can be assumed that the electrolux is "the same, only cheaper", but maybe there are features invisible in the catalog parameters, but worth a significant difference in price. Of course, I notice the difference that the AEG has a salt water softening system, but the previous electrolux did without this function and gave excellent results, so softening is not a key feature for me.
    I am asking for your tips. It may also be an indication of a corresponding third-party device.
  • #2 17502477
    Kenworth 18
    Help: 2442
    Rate: 3749
    Unfortunately, my friend, a lot has changed over the years.
    Today, AEG-Electrolux is not the same reliable brand as it used to be.
    Currently, the washing machines of this manufacturer do not have the possibility of replacing the bearings and the failures of the control modules are very frequent and the repair is rarely successful.
    Currently, fully serviceable washing machines are manufactured by LG, Samsung and Amica.
    Bosch-Siemens also has several washing machines that are serviceable.
    https://www.elektroda.pl/rtvforum/topic3495709.html
  • #3 17502531
    ssawka
    Rate: 14
    Thank you. Cz by
    do you understand access to drum bearings without having to cut open the tank?
    Are there still washing machines with a stainless steel tank produced?
  • #4 17502547
    Kenworth 18
    Help: 2442
    Rate: 3749
    There are no steel tanks anymore, but plastic tanks are twisted or fastened with the center of two halves, i.e. bathtubs, and thus there is access to bearings and sealant.
    Of course, not with every producer, as I wrote earlier.
  • #5 17502603
    PanAGD
    Help: 65
    Rate: 112
    On a budget and with a steam wash function, it can LG F4J8VS2WD ? Replaceable bearings, 9 kg, 1400 rpm
  • #6 17506151
    ssawka
    Rate: 14
    So what is the service life of the washing machines currently produced? Can you expect that any of the currently manufactured washing machines will work for, say, 10 years? They give such a guarantee for the engine, but it does not change the fact that everything else may break after 2-3 years.
  • #7 17506189
    PanAGD
    Help: 65
    Rate: 112
    The average service life is 5-8 years, but if it happens it can be 2 or 15 years.
    Of course, it's best to choose proven producers who offer dismountable tanks, such as Bosch, Lg, Samsung or Amica.
  • #8 17506310
    Kenworth 18
    Help: 2442
    Rate: 3749
    Let a colleague choose something from the LG offer because after the guarantee of the price of parts, they provide servicing cheaper than the competition. Amica would be even cheaper, but this manufacturer often uses electronic drivers or motors, so buying equipment from this manufacturer is subject to a high risk.
  • #9 17506402
    PanAGD
    Help: 65
    Rate: 112
    If we are talking about heaters, pumps, door locks, hydrostats and probably a few other parts, the prices at all manufacturers are similar.
  • #10 17507163
    ssawka
    Rate: 14
    Thanks for the tips.
    What I really care about is the longest possible service life without failures that require service. Currently used brushless motors (probably in most models) eliminate the procedure of replacing brushes, which I had to do, just like replacing the bearings. And is Miele, so famous for its failure-free operation, really so durable? I just read their offer - they have interesting power-wash or twin dos functions. I am less convinced by the connection of the washing machine to the Internet or the telephone, which just improves washing. And failure-free.
  • #11 17507348
    Kenworth 18
    Help: 2442
    Rate: 3749
    Even Miele is not as reliable as it used to be, but the quality of this equipment beats other manufacturers. Unfortunately, if a service is necessary, the repair costs will be exorbitant amounts.
  • #12 17509656
    ssawka
    Rate: 14
    Reading the parameters, I found that the tanks in the ground are made of steel. I wonder what breaks the earliest and most often in them.
  • #13 17509708
    PanAGD
    Help: 65
    Rate: 112
    And you have to look into the glass ball.
  • #14 17509740
    ssawka
    Rate: 14
    Or have access to the manufacturer's website data :)
The discussion centers around the comparison of washing machines AEG L9FEC49S and Electrolux EW8F248BP for a 4-person household. The user, having had a long-term experience with Electrolux, seeks advice on reliability and serviceability of modern washing machines. Responses indicate that AEG-Electrolux has seen a decline in reliability, with frequent control module failures and limited repair options. Recommendations favor brands like LG, Samsung, and Bosch for their serviceable designs and longer lifespans. The average lifespan of washing machines is noted to be between 5-8 years, with some models potentially lasting longer. Miele is mentioned for its quality but is also noted for high repair costs. The conversation highlights the importance of choosing machines with accessible components for easier repairs.
TL;DR: Average service life is 5–8 years; "choose proven producers who offer dismountable tanks" for longevity. For a 4‑person home comparing AEG L9FEC49S vs Electrolux EW8F248BP, prioritize serviceability over extras to reduce lifecycle costs. [Elektroda, PanAGD, post #17506189]
Why it matters: This FAQ helps 4‑person households pick a washer that balances performance with low lifetime repair risk.
Which is better for long‑term reliability: AEG L9FEC49S or Electrolux EW8F248BP?
Focus on serviceability. Reports note current AEG/Electrolux machines often have sealed tubs, so bearings are not replaceable. Control module failures are frequent, and repairs rarely succeed. If you value longevity, pick brands with split tubs that allow bearing and seal replacements. This reduces lifecycle risk and cost. [Elektroda, Kenworth 18, post #17502477]
How long will a modern washing machine last?
Expect about 5–8 years on average. Outliers happen, from 2 to 15 years. To hedge against early failures, choose proven brands that offer dismountable tanks. That design supports practical repairs over replacement. [Elektroda, PanAGD, post #17506189]
Can I get replaceable drum bearings without cutting the tub?
Yes. Look for a plastic split tub assembled from two halves. That design provides access to the bearings and seal. Not every brand uses it, so verify before buying. [Elektroda, Kenworth 18, post #17502547]
Are stainless steel outer tubs still made?
No. Manufacturers no longer use steel tanks. They use plastic tubs formed from two halves. On models with split tubs, this enables bearing access. [Elektroda, Kenworth 18, post #17502547]
Which brands remain serviceable with dismountable tanks?
Bosch, LG, Samsung, and Amica are recommended when you want dismountable tanks. Choose these if you prize long‑term serviceability and repair options. [Elektroda, PanAGD, post #17506189]
Is LG cheaper to maintain after the warranty?
Yes. LG is a sound pick for lower post‑warranty costs. As one expert advises, "choose something from the LG offer...servicing cheaper than the competition." This helps contain parts and service bills. [Elektroda, Kenworth 18, post #17506310]
How do AEG/Electrolux models fare for long‑term maintenance?
Reports warn about today’s AEG/Electrolux reliability. “Failures of the control modules are very frequent.” Many units also block bearing replacement due to sealed tubs. Repairs often fail, increasing lifecycle costs. [Elektroda, Kenworth 18, post #17502477]
Is Miele still worth it for durability?
Miele is not as reliable as before, but its build quality remains superior to most brands. The trade‑off is high repair cost if service is needed. Weigh quality against potential repair expense. [Elektroda, Kenworth 18, post #17507348]
What parts typically fail and need replacement?
Common replacement items include heaters, pumps, door locks, and hydrostats. Prices for these parts are similar across manufacturers. Plan maintenance budgets around these components. [Elektroda, PanAGD, post #17506402]
Which specific model suits a 4‑person home and offers steam cleaning?
Consider LG F4J8VS2WD. It provides steam wash, 9 kg capacity, and 1400 rpm. It also has replaceable bearings for future serviceability. This balances features and repair readiness for family use. [Elektroda, PanAGD, post #17502603]
Do long motor warranties mean the whole washer is covered?
No. Extended warranties commonly cover the motor only. Other parts can still fail within 2–3 years and generate costs. Read warranty terms and budget for non‑motor repairs. [Elektroda, ssawka, post #17506151]
How can I check if a washer allows bearing replacement before buying?
  1. Check literature for “split” or “dismountable” tub language.
  2. Inspect photos or floor models for bolts or clamps around the tub seam.
  3. Ask the retailer or service center whether bearings and seal are replaceable. [Elektroda, Kenworth 18, post #17502547]
Are Bosch‑Siemens models still serviceable?
Yes. Bosch‑Siemens still offers several serviceable machines. Include them in your shortlist if repairability is a priority. [Elektroda, Kenworth 18, post #17502477]
Does AEG’s salt‑based water softening justify paying more?
It depends on your water and experience. One buyer achieved excellent results without softening and does not treat it as essential. If your past results were good, you may not need the softener feature. [Elektroda, ssawka, post #17502455]
