[C++] Create Random Integer Function within Custom Range (Example: 5 to 16)
qmpel 28925 4
  • #1 1165076
    qmpel
    Help: 24
    Hey !!
    I have a request, could someone give me a function written in C / C ++ to generate an integer in the range, for example, from 5 to 16 ??
    Regards !!
    I close. - arnoldziq
    wddf
    Help: 26
    Hi, I don't know what it is like in C, but for example in Pascal it is done like this:
    number: = random (16);
    it gives a random from 0 to 16, you can make a loop that eliminates smaller than 4, I think the toilet is very similar, you only need to find the equivalent of "random", good luck
    Bielsky
    Help: 30
    Rate: 19
    #include
    #include
    int main(int argc, char *argv[])
      int i;
      srand(time(0));
      // %12 bo zakres ma 12 liczb
      //5 bo najniższa to 5
      i = rand()%12 + 5;
      printf("%i\n",i);
      system("PAUSE");
      return 0;
    Paweł Es.
    Help: 1236
    Rate: 692
    int x;
    x=5+(rand() % 12);
    General: generating integers in the range where b> a
    x=a+(rand() % (b-a+1)); // prosta metoda ale korzysta z małej ilości
                                          // bitów i liczby są "średnio" losowe.
    second method (better):
    x = a + int((b-a+1) * rand()/(RAND_MAX+1.0));
  • #5 1165403
    qmpel
    Help: 24
    Hey !!
    Thank you thank you thank you, !!
    Regards !!
