Karcher 520M Pressure Washer: What Oil Type & How Much to Use? (Max 90 Characters)
pawelsiara74 85667 13
What oil should I use in a Kärcher 520M pressure washer, and how much should I pour into the pump?
Use good-quality mineral 15W40 engine oil; for a disc pump, SAE 80W gear oil was also suggested, and 15W40 was confirmed as acceptable [#1359087][#1360999][#1361722] For the amount, do not fill the pump completely—pour only enough so the oil covers the plate [#12267813]
  • #1 1352148
    pawelsiara74
    Help: 51
    Rate: 84
    Hello, as in the topic I wrote, I need information what oil to pour into the Karcher 520M pressure washer and how much of this oil?
    Regards
    ksadowski
    Rate: 25
    should write at the infusion
    if not it goes mineral 15w40 of good quality
    or the sae80w gearbox
  • #3 1359987
    pawelsiara74
    Help: 51
    Rate: 84
    hello thanks wolf
    but from what I know, there is no infusion there and I don't think I write anything yet, I have to see exactly, maybe it is written somewhere, but I doubt it is poured after removing the pump.
    I just need to find out how much to pour there
    Regards
    ksadowski
    Rate: 25
    there you have a disk pump, then it goes sae 80w (you pour the car gear to almost full
  • #5 1361035
    pawelsiara74
    Help: 51
    Rate: 84
    Hello, thanks a lot for your help, you have helped me, I only have one question because just a moment ago I bought shell engine oil 15W40 and now I'm wondering if I can put it in or buy the other one, but I found something like this on the internet http: //www.karcher. ca / CPE / CPE% 20Parts% 20Lists / CPE% 20K% 20520M% 20% 201.069-937.pdf and here it writes engine oli or engine oil and it seems to me that I can pour it, but that's the only way I ask :) because I feel sorry for the oil I bought :)
    Regards
    ksadowski
    Rate: 25
    you can take it easy
  • #7 1362273
    pawelsiara74
    Help: 51
    Rate: 84
    Thanks a lot for your help, I have already put together my spartway tomorrow, because I had such a problem that the pump did not give pressure, but there was a mess in the valves inside the pump and the valves did not get wet, I think that after cleaning it will be all right :)
    This is how you lend such devices to irresponsible people !!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Good habit, don't borrow ... better still, don't give back heheheheheh
    Regards
  • #8 1370138
    pawelsiara74
    Help: 51
    Rate: 84
    I have a problem now: the washer turns on, the pressure already gives as it should be, but it does not turn off after releasing the lever in the gun, i.e. it turns off, but it turns on again and so on and on, I will add that the lance does not release. it turns off literally for a second and turns on again somewhere for a second
    What can it be, is it possible that there is some dirt in this valve that turns on and off the contactor because I did not clean it ??
    if anyone has an idea, please give me a hint
    Regards
    geex
    Rate: 24
    Check this relief valve, if the O-rings are completely clean, lubricate with water silicone and put it back on. If it does not help, there is a nozzle in the middle of the valve from the pressure side of the pump (you have two outlets - this one), unscrew it with a screwdriver and behind it there is a check valve with an O-ring, check the O-ring is complete and if the mushroom is in the shape the cone, i.e. if it is not scratched or deformed, if so, buy a new one and replace it
    If you have any questions, write geex (at) o2.pl in the topic karcher service
  • #10 2028585
    pawelsiara74
    Help: 51
    Rate: 84
    thanks for your interest ... I haven't done it yet because I didn't have too much time to start and I didn't know where to start ... but now, when I find some free time, I'll take it apart and take a look ... I get water into the oil ... that is, I pour new oil and after a short time it is reinserted, only tears after dismantling the oil again, there is already white oil, that is, as if the water got into the oil ... I don't know, but I think it shouldn't be like that be, in total, the condition of the oil does not change slightly, but I do not notice the difference ... and is it possible to get it through the pistons or is there any other option ... the better ones .. :) and what's more, if I find some free time, I'll postpone what you wrote ...
    Best regards and many thanks for your interest
    Paul
  • #11 2038569
    geex
    Rate: 24
    Regarding the oil, if after replacing water (white oil) has appeared again, check whether the pistons are smooth (whether there are any scratches and whether the diameter in the place where the pistons work in the seals does not differ significantly from the places not working on the pistons, if so it is a new one or write to PRV).
    If the pistons are ok, replace the oil seals (preferably all 3) if you don't, you can expect an expense close to the value of the new equipment soon ;)
  • #12 12267813
    mutte
    Rate: 8
    with a disk pump you do not fill the oil almost completely, you only pour it so that the oil covers the plate :D :
  • #13 18974563
    battttek17
    As for the water, I doubt it, unless it actually spilled after opening it.
    The reason for the white oil in this type of pump is simply foaming, any oil, gear or engine oil will be white when first turned on. The only option is oil for shock absorbers, which will probably behave similarly, since the manufacturer's oil foams, it must be so, too high speed and a mixer with gears, springs and pistons.
  • #14 19232287
    bluehill
    Hello. Can anyone tell me what are the dimensions of the body O-ring with valves and oil seals on them in Karcher K 3.150?
The Karcher 520M pressure washer requires specific oil types for optimal performance. Users recommend using either mineral oil 15W40 or SAE 80W gear oil, with the latter being preferred for the disk pump. It is important to fill the oil to a level that covers the plate inside the pump. Concerns about oil contamination with water suggest checking the condition of the pistons and seals, as foaming can occur with any oil type due to high speeds. Users also discuss issues with the pressure washer not turning off properly, indicating potential problems with the relief valve or O-rings.
