Connecting Netgear N150 Router to Multiple Computers via Switch for Neostrada Internet
dobrywujek 21807 12
Can I connect a switch to the router and then run two Ethernet cables from the switch to two computers upstairs, and does it need any special configuration?
Yes, an unmanaged switch will work between the router and the two computers, and you do not need any special configuration [#13746266] Use normal straight RJ45 cables for router → switch and switch → computer; crossover cables are not needed for modern equipment [#13746314] If you use an old router as the “switch” instead of a real switch, it must be configured by assigning it an IP address from the main router’s local network and disabling DHCP [#13747046] The thread also notes that a simple 5- or 8-port switch is enough for this setup [#13746546]
  • #1 13746249
    dobrywujek
    Hello and welcome. I would like to point out right away that I do not know much about computer networks, so if I confuse something in the terminology, I apologize in advance. I am also asking for understanding, because the matter is probably trivial for someone who knows about it.
    I have an internet connection from Neostrada at home. The connection is made via a router located on the ground floor of the building (Netgear N150 router). Two wires go from the router: one to the computer right next to the router, the other to the 1st floor, also to the computer. However, I would like to connect a second computer upstairs. The problem is that I can't route a second cable, and I can't move the router. And the question here is, if I hook this outgoing cable to the switch, and let the switch run two wires: one to one computer and the other to the other, will it work efficiently? How do you have to configure it in some special way, do I connect and work? If that option didn't work, is there any other option to fix the problem? Unfortunately, Wifi does not reach that far, so there is only some combination with the cable.
  • #2 13746263
    bogiebog
    Help: 2569
    Rate: 1530
    dobrywujek wrote:
    And the question here is, if I connect this outgoing cable to the switch, and let the switch run two wires: one to one computer and the other to the other, will it work efficiently?
    will be.
  • #3 13746266
    mbo
    Help: 2333
    Rate: 845
    It will work and you do not need to configure anything (with a simple unmanaged switch).
  • #4 13746268
    bogiebog
    Help: 2569
    Rate: 1530
    It is also possible to play two signals with one cable - there are 4 pairs in the cable, 2 pairs are enough for 100mbs.
    Allegro lan splitter
  • #5 13746282
    dobrywujek
    Thank you for the quick reply. And to connect the router -> switch and switch -> computer, all you need is a regular RJ45 cable or does it have to be some other (cross?)?
  • #6 13746314
    bogiebog
    Help: 2569
    Rate: 1530
    Straight cables are enough. Routers today patch themselves as needed.
  • #7 13746337
    dobrywujek
    Thank you very much for your help. I have cables so today I will buy a switch and connect it. Regards.
  • #8 13746546
    CHACA
    Help: 875
    Rate: 457
    I can recommend a very simple switch - if you haven't already bought - SF-1005 or 1008.
  • #9 13747012
    aymoo
    Rate: 18
    I will connect to the topic because the issue is similar. I want to connect two routers, one of which will act as a switch (at least I don't think so, I have no clue about networks). I will write how I am going to connect it and ask for verification. Thanks!
    (1) LTE router from Plus> (2) wall socket> (3) DSL router> (4) PC
    1. Router to socket - straight cable, standard A
    2. Socket connected / wired as standard A
    3. Plug for the cable that runs from the socket and will be inserted into the DSL router - standard A
    4. Connecting the DSL router to the computer with a standard A straight cable
    I wonder if the plug on the cable coming from the socket should not be standard B? It's a combination of 2 routers, admittedly with a socket on the way, but always. I heard somewhere that to connect devices computer / computer or router / router you need to cross the cable ...
    I will be grateful for your help.
  • #10 13747019
    mbo
    Help: 2333
    Rate: 845
    It used to be necessary - nowadays practically every equipment recognizes it itself.
  • #11 13747046
    aymoo
    Rate: 18
    So I do not have to cross, and the described connection diagram should work. Cool. Thanks.
    Added after 2 [hours] 14 [minutes]:
    However, I will need a little more of your knowledge.
    I made the cables and connections as I wrote above. Everything works, up to the DSL router that is supposed to be a switch. The connection from the LTE router (let's call it the source router) through the socket in the wall and the cable - it's ok. I connected the laptop to the cable to check. However, when I connect the same cable to which I connected my laptop to the DSL router (LAN port), no computer connected to this router has access to the Internet.
    The latter router is TP-LINK TL-WR1043ND. Until now, it has acted as the only router, received a signal through the WAN socket and shared the Internet with computers connected to LAN and WiFi sockets. I suspect that you need to configure it somehow to act as a switch ... but how to do it? Or maybe the cable should be crossed with this router model?
    Added after 1 [hours] 39 [minutes]:
    SOLUTION
    I was able to fix the problem before someone replied.
    The connection was right. It was only necessary to properly configure the router - change the IP address to the address from the local network of the main router and disable the DHCP function. The configuration is described in detail below, it may be useful to someone.
    Link
  • #12 14220712
    fudala1
    My first post. Good morning, friends.
    Sorry for the kick-up.
    I have a situation like the author of the thread.
    Wanem router to cable, from the router to the first Lan PC in the same room and the second cable from the router to the PC in the other room. In the other room, I also want to connect my smartTV and smartBR. I still have two Lan inputs available in the router. Two options;
    1. Switch to the second room and connection from it to PC, TV and BR. The cable is now in place.
    2. Directly cables from router to smartTV and BR. The second option is to hide cables under the skirting boards, sheds with thresholds, etc. etc.
    My question is: is the link quality through the switch the same as the direct connection of cables from the router to PC, TV and BR? Connect the switch or get tired and give the cables directly? I have a 20 mega net. Cable length between rooms 15m.
  • #13 14232636
    CHACA
    Help: 875
    Rate: 457
    Connect the switch, it works transparently, i.e. it passes the same amount of data through as many ports as it has. I provided proven models in an earlier post.
The discussion revolves around connecting a Netgear N150 router to multiple computers using a switch for a Neostrada internet connection. The user seeks guidance on whether connecting a switch to the router and then connecting multiple computers to the switch would work efficiently. Responses confirm that using a simple unmanaged switch will suffice without any special configuration. Straight RJ45 cables are recommended for connections, as modern routers automatically adjust for cable types. Suggestions for specific switch models, such as SF-1005 or SF-1008, are provided. Additional queries about connecting two routers and ensuring proper configurations for internet access are also addressed, emphasizing that switches operate transparently without degrading link quality.
