Motherboard Power Section: Understanding its Role in Overclocking, Identifying Good & Weak Sections
hemisys 30201 5
  • #1 14423836
    hemisys
    Rate: 18
    Hello, this is a general question.
    What is it, how does it matter in overclocking, what parameter determines that a given board has a good power section, and finally, how do I know if my motherboard has a good section or a weak section.
    Supplementary question is this is the power phase :) .
    Regards
    cichyp
    Rate: 28
    What is the CPU power section?
    The power supply section is a system on the motherboard responsible for powering the processor, the better the processor, the more stable it is. The CPU power supply section combines various elements of the motherboard that are responsible for supplying power to the processor (PWM controller, MOSFET driver, traditional MOSFETs (upper and lower ), chokes, capacitors and related circuits).
    What is a MOSFET?
    The MOSFET is one of the most important components of the CPU power zone because it is the first switch that allows or prevents current from flowing to the CPU. The switch is controlled by a MOSFET driver and a PWM controller. The MOSFET is one of the most expensive elements of the power supply design.
    What is the power phase?
    The power phase is a single CPU voltage stabilizer that consists of a MOSFET driver, an upper MOSFET and a lower MOSFET (or sometimes only one MOSFET). Today, power phases are created using many modern technologies, thanks to which they are more and more efficient.
    The number of phases can be determined by counting the coils placed around the processor socket. As far as I know, phases range from 4 to even 32.
    What is a traditional MOSFET (also known as D-Pak MOSFET...) ?
    The traditional MOSFET is a less advanced transistor MOSFET chip that is used in the power section of the CPU where the upper and lower MOSFETs and the MOSFET driver are 3 separate chips. This is less efficient than the one-chip PowIRStage used by GIGABYTE
    The power section is an important element of the motherboard, which is especially important when overclocking. The quality and number of phases determine the stability of the power supply. 3+1 means that three phases are responsible for supplying power to the processor cores and one powers the memory controller.
    The 3+1 section used in budget motherboards will not allow for effective overclocking of power-hungry processors, but it should be enough to OC those from the lower shelf, e.g. Athlon II X2. Often, on boards with 4-phase power supply, the manufacturer does not recommend using processors with a TDP higher than 95W.
    The 4+1 section allows you to mount more power-hungry CPUs and offers good overclocking capabilities. Even better when it is equipped with a heat sink on mosfets.
    Boards with 8+2 (or more) section are designed for performance overclocking cooled by a radiator.
    Information taken from some Gigabyte website and from the PClab forum are not my own statement, they were only slightly edited by me.
  • #3 14424721
    hemisys
    Rate: 18
    Am I 3+1 or 4+1 here?
    Regards
    tzok
    Help: 3177
    Rate: 6558
    4+1 but without cooling (radiators).
  • #5 14426667
    ludek111
    Rate: 54
    I will add from myself that, for example, in the times of Pentium III, the processor had "one phase" power supply, i.e. the so-called. a synchronous converter (two transistors, a coil and several filtering capacitors).
    Motherboards for AMD socket A, i.e. old Durons/Athlons XP/Semprons, had from two to three phases. Some manufacturers used four-phase sections in their totally high-end records.
    The "madness" probably started with socket 775. Already in 2006, motherboards with 8-phase power supply appeared.
    The terminology "+1" etc. appears only in constructions where in the processor, apart from the CPU unit (and FPU, i.e. floating point unit, which has been integrated since the PIII era), there is also a memory controller (and more and more often other systems that could only be integrated :) ). AMD was the first to integrate the DDR1 controller in the processor in the days of socket 939. Here the controller power supply was indeed separate, but the manufacturers did not call it "+1" (usually this one "phase" was enough to power the HT bus voltage and the entire memory controller).
    The whole power supply system is called a converter.
    I don't know if this will interest you, but here you have photos and construction of my converter, made on foot. It is an asynchronous converter (one transistor and it's not even a MOSFET, just a regular NPN bipolar one, instead of the second MOSFET (instead of the bottom one) there is a schottky diode.
    If you want to read more about it, as I wrote the password "converter", the wiki has a well-explained principle of operation.
    Here I focused on the "history" and building elements, we can expand on the topic if you are interested :)
    my friend Cip has a plus from me, good job! :)
    Added after 6 [minutes]:
    I will return to the main topic, which is what determines the OC of the disc. Often it is also the chipset. Using the example of Intel and a processor with a locked multiplier:
    on a board with an old and weak 945PL chipset you can do about 350 MHz fsb, which in combination with a processor that defaults to 333 MHz x 9 is a small increase in performance
    on a board with a newer chipset from a better series (more expensive), e.g. P35, P45, X38, etc., you can safely exceed 400-450 MHz, of course, if the specific processor allows it under specific conditions (voltage, temperature).
    What else? We are often limited by the lack of certain voltage settings. Equally often, or even more often, we are limited by our memories.
    End off top, this is not the answer to the main question, rather as a curiosity and an attempt to encourage overclocking :)
  • #6 14438948
    iron64
    Help: 648
    Rate: 313
    I think that the value for the P35 colleague can easily raise it. On the screen there is a 24/h max setting, I got a stable 510, but otherwise I know that there are better P35 copies.
    PS I was forced to go back to my old PC.
