Full Apartment Power Outage Despite Untripped Fuses - Possible Causes?
Bety12 38844 8
  • #1 14674996
    Bety12
    Rate: 8
    About 2 years ago, I replaced all the electrics in the apartment, no cans, only the circuits to the box in the apartment.
    And today I suddenly don't have electricity everywhere (the whole apartment). And all the fuses in the box in the mixing are on ...
    The one in the stairwell is my main one it was turned on too, nothing turned off . (sorry I'm not at home at the moment and I don't remember the markings on these fuses, that's why I am so vague)
    Neighbors on the cage have normal current.
    I have this fuse in the box in the mixing box, which with higher voltage should turn off the rest, but it did not turn off, nothing worked.
    Need help where to find the cause, main fuse or what? Anyone met with a similar case?
  • #2 14675016
    slawekx
    Help: 53
    Rate: 198
    Magic mary hocus pocus - maybe it will help. Seriously, call a professional.
  • #3 14675050
    Bety12
    Rate: 8
    very useful...
    The main fuse is C-25 from Eti, maybe it failed?
  • #4 14675053
    KMY
    Help: 25
    Rate: 97
    Bety12 wrote:
    ... that's why so vague ...
    Neighbors in the cage have normal current.
    Also generally, many times, when the recipient did not pay the electricity bills.
  • #5 14675055
    slawekx
    Help: 53
    Rate: 198
    Bety12 wrote:
    I need help Has anyone come across a similar case?
    Not where it works for others for years, always very well, only for you something does not work. you spoil the forum with such questions. It is not a question, it is an encouragement to divination.
  • #6 14675072
    Bety12
    Rate: 8
    I am up to date with my bills. So I understand that the problem is beyond my circulation? Only in the power supply, e.g. a cable that goes to the main fuse?
  • #7 14675087
    KMY
    Help: 25
    Rate: 97
    No, it could also be your fuses. Sometimes it happens that the fuse disconnects the contacts, and the lever remains in the "on" position
    But that's not really the point, do you really think that from your description, without being able to verify from a distance, there is anyone who will tell you the reason?
    You have to turn off all fuses, take the meter and turn on from the staircase and check if there is voltage.
  • #8 14675113
    Bety12
    Rate: 8
    Thanks for the info. At least I know where to start. Ultimately, when it turns out that there is no voltage in the electric cable, I will call them.
  • #9 14675158
    Bety12
    Rate: 8
    Checked, there is no voltage in the fuse - C -25 on the cage. I will go home and check if there is electricity at all. If I do not call Energetyka. Thanks for the info. End of discussion.
The discussion revolves around a full apartment power outage despite all fuses appearing to be operational. The user recently replaced the apartment's electrical system and is experiencing a total loss of electricity, while neighbors have normal power. Suggestions include checking the main fuse (C-25 from Eti), verifying if the fuse contacts are disconnected while the lever remains "on," and ensuring that electricity bills are paid. The user is advised to test for voltage at the main fuse and consider contacting an electrician if no voltage is detected.
