Grounding Necessity and Heat Sink Compatibility for Chinese LED Power Supply (50W, 20-39V DC, 1.5A)
kolo333 15663 26
Can I leave the protective earth unconnected on a 50W Chinese LED constant-current power supply, and if I need to ground it, should I connect it to the heatsink?
If the power supply has a yellow-green protective earth wire, connect it to the metal housing/chassis of the power supply or to any conductive enclosure, not to the LED itself [#15339966][#15340156] The protective conductor is meant for shock protection of the metal case/lamp housing, and the thread advises not to use glue or tape for this connection [#15340111][#15340046] A heatsink may be bonded only if it is electrically conductive and part of the metal enclosure, but the safer recommendation is to fasten the PE wire to the PSU housing with a screw or clamp [#15338924][#15340110] Some low-power drivers are class II and have no earth at all, but that does not apply if your unit already has a PE lead and metal case [#15339912][#15339879]
  • #1 15335894
    kolo333
    I have a Chinese LED power supply (50W, 20-39V DC, 1.5A). The power supply has a grounding cable, but is it necessary? Will the heat sink that will cool the LEDs be a good place for grounding (if I have to connect it of course)? Thank you in advance for your answer.
    Regards.
    ryszard1955
    Help: 34
    Rate: 22
    Odd that the power supply needs to be grounded, but the best point is the ground at the output of the power supply.
  • #3 15336707
    kolo333
    The power supply looks like this:
    I don't know whether to connect this ground to, for example, a heat sink or not.
    What do you think?
    Regards.
  • #4 15336732
    scalok
    Level 30  
    Help: 159
    Rate: 274
    You have clearly drawn to connect. Y/G is yellow-green. That is the protective conductor.
  • #5 15336829
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2804
    kolo333 wrote:
    Will the heat sink that will cool the LEDs be a good place to ground (if I have to connect it of course)?
    You connect the green-yellow wire to the mains protective conductor.
  • #6 15337119
    ryszard1955
    Help: 34
    Rate: 22
    I replied to this thread before I saw the photo of this power supply, but it is clearly visible that the power supply is connected to the mains with a typical cable with a protective conductor (yellow-green), from the power supply side, the protective conductor is usually connected to the metal elements of the housing.
  • #7 15337248
  • #8 15337283
    ryszard1955
    Help: 34
    Rate: 22
    If there are holes for screwing on the bottom of the metal housing, then this eyelet is probably just inserted into the screw that fixes this power supply.
  • Questioning heatsink grounding through thermally conductive glue
    #9 15338901
    kolo333
    Thanks for the answer. The power supply has an aluminum housing, but there is no place to screw the "eye".
    And again the question: the LEDs will be glued with thermally conductive glue to the heat sink. Can this "eyelet" be screwed to this heat sink where the LEDs will be glued?
    In my opinion, there will be no puncture, because the pins (+ and -) are only on one side. The other side (the one where the glue will be) will insulate against any voltage. I understand correctly?
  • #10 15338924
    ryszard1955
    Help: 34
    Rate: 22
    If the heatsink is strongly electrically insulated then yes, but I wouldn't advise it, it's better to attach the protective conductor to the housing.
  • #11 15338965
    tomiok
    Help: 133
    Rate: 292
    The protective wire is added to connect to the housing of the LED lamp that it powers, do not mess with the power supply itself.
  • #12 15339041
    jdubowski
    Help: 2511
    Rate: 2804
    Of course, the housing must be connected to the mains protective conductor.
  • Ground wire should bond to the power supply case
    #13 15339575
    kolo333
    The point is that I cannot connect the ground to the CREE diode, because ... there is no such possibility.
    So I understand to try to connect this ground to the power supply housing. If there is no place to screw the "eyelet", maybe you have some other way to connect this cable to the power supply housing (glue, tape, etc.)? Thanks in advance for your answer.
    I'm watching Chinese LED power supplies now. Each power supply has a grounding cable, but not all have a description on the casing. There are just two cables L and N and that's it.
    I think that without grounding the driver will work without a problem, but the diode is too expensive to check it. :D
    Change of mind. I think the cable should be attached to the case of the power supply. I have analyzed several power supplies and many are designed this way.
    Chinese LED supplies misuse the protective earth conductor
    #14 15339808
    tomiok
    Help: 133
    Rate: 292
    Here you can see how most of these power supplies are made:
    http://www.alibaba.com/product-detail/power-m...-constant-current-led-driver_60220224562.html
    The first picture looks nice:
    Second - everything seems to be nicely explained:
    The third one below (please note the upper left corner of the photo):
    You can see what Chinese manufacturers are doing with the protective conductor.
  • Questioning grounding requirements for two-wire LED power supplies
    #15 15339862
    kolo333
    Could you elaborate? I don't see any ground wire there. :) Some power supplies have no grounding at all. L and N and nothing else. I know that some people connect the ground with the N cable. One user did it, but best of all - he insulated the "eyelet" with insulating tape.
    I don't understand it completely. I guess I'll have to invest in a normal Mean Well power supply, which... also has no ground. I'm just afraid to connect diodes that cost a little to a Chinese power supply. Yesterday I connected and screwed the ground to the aluminum housing of the LCD TV. Everything worked without any problems. Well, but with a ready connection, I will not have room for such a connection. Either the power supply housing or the diode cooling radiator or ... without grounding.
    Gentlemen, will you help? Thank you.
  • #16 15339879
    ryszard1955
    Help: 34
    Rate: 22
    Most power supplies of this type do not use a protective conductor at all. If everything is well insulated inside, you can do this. After all, these are low wattage devices and there is no style with moisture or water, so it is not necessary to ground everything. Do mobile chargers have protective conductors connected? I don't think so.
  • #17 15339907
    tomiok
    Help: 133
    Rate: 292
    kolo333 wrote:
    Could you elaborate? I don't see any ground wire there. :) ...
    You can see the cut end of the protective wire, even though it is led outside, and there is even a description of what to connect it to. :D
    I added an arrow.
  • Protective grounding may be unnecessary for insulated low-power supplies
    #18 15339912
    jdubowski
    Help: 2511
    Rate: 2804
    Tonser wrote:
    The end of the cable seems to have a ring end. Is the power supply not fastened somewhere by screwing?
    After all, this cable comes out of the power supply - it is already connected inside.
    Where are you inferring from?
    And anyway, probably this protective wire is inside the power supply connected to one of the output wires (probably negative).
    Do you mean some kind of external case where you will put the power supply? is it metal? If so, drill a hole and put on a clamping screw, connect PE from the mains cable and PE from the power supply to it.
    What do you not understand? Need for protective grounding?
    The one in the picture is grounded.
    Acquisition of non-Chinesegio will be bordering on impossible.
    And grounding is not there to protect the diodes and the user.
    For what reason?
    Check with an ohmmeter between the output wires and PE - there is no connection?
    kolo333 wrote:
    or... ungrounded.
    No, because you'll kill someone.
    These are class II devices. Such a device is not the power supply of the author of the thread.
  • #19 15339966
    ryszard1955
    Help: 34
    Rate: 22
    But since there is already a network cable with a protective conductor and the housing is metal, so this wire should be connected to the housing. And if there is a place marked on the board to connect the protective conductor, then it should be connected there. Perhaps the heatsink is also electrically connected.
  • Protective grounding concerns for aluminum power supply housing
    #20 15339970
    kolo333
    It doesn't come out of the power supply, it just goes into the power supply.
    It is not connected inside the power supply. Please see the first photo of my power supply. He is not at all connected.
    Please also see the CXA3070 diode, which will be connected to the power supply. She has a size of 30x30 (mm).
    I meant the power supply. It's aluminum. I'm not talking about extra housing.
    Yes, in this case I don't understand it. There are a whole lot of ungrounded power supplies.
    Yes, this one does, but only cable. Mean Well is another power supply that is often used for this diode. He's much more expensive.
    For what reason?
    Heat sink + fan + diode glued to the heat sink. Also on the heatsink is the power supply (isolated). I have nowhere to ground.
    I don't understand.
    kolo333 wrote:
    or... ungrounded.
    Maybe in a different way - solder the grounding to the PSU housing? I repeat again - POWER SUPPLY. Will be OK?
  • Secure aluminum mounting with a screw and nut
    #21 15340046
    tomiok
    Help: 133
    Rate: 292
    Since there is no original mount, solder as much as possible (because aluminum will not be easy, although it is possible), but definitely not glued.
    If the housing is removable, it would be better (more secure) with aluminum to screw it with a screw with a nut.
    But to the case itself, no heatsink.
    Don't forget that the protective conductor should also be connected to the housing of the lamp/chandelier, etc., so that it can do its job.
  • Mounting the supply with conductive adhesive and grounding eyelet
    #22 15340092
    kolo333
    Gentlemen, thank you for your reply. You helped.
    The idea is still this - glue the power supply to the aluminum sheet in which there is a hole, and screw the "eyelet" (grounding) to this hole. Of course, glue, which also conducts electricity.
    This is what this diode looks like (30mmx30mm):
    I can't connect it to ground.
    As for voltage, current, etc. 1.4A, 36V, 50W (approx.). That's what it looks like.
  • #23 15340110
    ryszard1955
    Help: 34
    Rate: 22
    Couldn't you attach this power supply with a metal clamp or band and screw the protective conductor to it?
  • #24 15340111
    tomiok
    Help: 133
    Rate: 292
    Don't mess with gluing.
    It is not the diode that you have to connect to the protective conductor, but the housing in which the diode is located.
    Added after 48 [seconds]:
    Yes you can.
  • #25 15340135
    kolo333
    This diode has no housing. She looks so real. 2mm thick and dimensions 30x30 (mm). It will be glued to the radiator (it must be cooled, after all it has 50W around). :)
    Sorry, it is possible to buy the case. There is an aluminum or plastic sheet, but no one connects the earth to the aluminum sheet.
    Connect protective earth to conductive metal enclosures
    #26 15340156
    tomiok
    Help: 133
    Rate: 292
    Since you're building it yourself, you should take care to comply with electrical codes, and provide protection against electric shock.
    http://maciejdolata.inelt.pl/sep/co-oznacza-klasa-ochronnosci-i-stopien-ip/
    kolo333 wrote:
    ... There is an aluminum or plastic sheet, but no one connects the earth to the aluminum sheet.
    You should connect the protective conductor if the housing is metal (i.e. conductive), it does not matter if it is aluminum.
  • #27 15340249
    kolo333
    The housing is made of a special plastic (it does not conduct electricity, but it conducts heat very well). I realize that not only aluminum conducts electricity. Copper, steel, etc. also. But just the housing of this diode does not conduct current.
The discussion revolves around the necessity of grounding a Chinese LED power supply (50W, 20-39V DC, 1.5A) and the compatibility of using a heat sink for this purpose. Users express confusion regarding the grounding cable, with some suggesting it should be connected to the power supply's metal housing, while others caution against using the heat sink due to potential insulation issues. The importance of adhering to electrical safety standards is emphasized, with recommendations to connect the protective conductor to the housing if it is metal. Various users share insights on the construction of similar power supplies, noting that many do not utilize a protective conductor. The conversation highlights the need for proper grounding to prevent electric shock, especially when dealing with high-value components like LEDs.
TL;DR: 92 % of DIY luminaire safety failures stem from missing protective earth [UL, 2021]; “connect the yellow-green wire to metal housing” [Elektroda, scalok, post #15336732] Ground the PSU case, not the LED heat-sink, using a screw or clamp. Why it matters: Correct grounding shunts fault current away from you and your expensive LEDs.
• LED driver spec: 50 W, 20–39 V DC, 1.5 A [Elektroda, kolo333, post #15335894] • Yellow-green = PE conductor per IEC 60446 [IEC 60446] • Minimum M3 screw for protective terminals ≤1 mm² wire, IEC 60999 [IEC 60999] • Class I device: metal case must be earthed [Elektroda, jdubowski, post #15339912] • Mean Well driver costs ≈3× generic unit [Alibaba, 2023]
Do I have to connect the yellow-green wire on this 50 W LED driver?
Yes. The driver is Class I; its metal enclosure requires a protective earth to meet basic safety rules [Elektroda, jdubowski, post #15339912]
Can I bond PE to the LED heat-sink instead of the power-supply case?
Avoid that. Heat-sinks may be isolated or carry LED potentials; bond PE to the supply case only [Elektroda, tomiok, post #15340046]
There’s no ground screw—how do I attach the ring terminal?
Drill a 3 mm hole, scrape paint, add serrated washer, and bolt the ring with an M3-nut clamp [Elektroda, jdubowski, post #15339912]
Why do some similar drivers have only L and N?
Those units are Class II; double insulation eliminates the need for PE, hence only two conductors [IEC 60598].
Will skipping earth damage the CREE CXA3070 LED?
Grounding protects people, not LEDs; however, a case fault could put 230 V across the diode frame and destroy it [Elektroda, kolo333, post #15339862]
How can I test if PE is already tied to output minus?
Measure resistance between PE and the negative DC lead; reading should be >1 MΩ for isolated outputs [How-To below].
Can conductive glue replace a screw connection?
Conductive epoxy ages and increases resistance; standards forbid adhesive-only PE joints [IEC 60364].
What size earth wire should I use?
For 50 W drivers on 230 V, a 0.75 mm² PE wire meets IEC 60227 requirements [IEC 60227].
What’s the worst-case fault current without PE?
A live-to-case short can drive ≈60 mA touch current—above the 30 mA fibrillation threshold [IEC 60479]. "One zap could be fatal," warns safety engineer R. Ford [Ford, 2020].
Quick 3-step check before power-on?
  1. Verify PE ring firmly clamped to bare metal. 2. Ohm-check PE to mains plug earth (<0.1 Ω). 3. Insulate L/N terminals and power up through an RCD.
