Adding Time Constant to Electronics Class Graph - Basics of Electronics Assignment
mateusz2812 13239 7
  • #1 15378366
    mateusz2812
    I would like help on the following matter. For the basics of electronics class, I had the following assignment to do. Adding Time Constant to Electronics Class Graph - Basics of Electronics Assignment
    However, I need to add a time constant to this graph :) It's hard to find anything meaningful online. Anyone help?
    kemot55
    Help: 184
    Rate: 147
    With such a small number of points, graphically determining the time constant is a mockery, ... but you can (by force). You set a point of tangency on the graph (on these "edges" it will be a bit difficult to do it exactly). You draw a tangent to the graph at that point and a steady state line. The time from the point of tangency to the intersection of the tangent with the steady level is a time constant.
    Only you know the value of the time constant so you can "fit in" :-)
  • #3 15378402
    mateusz2812
    I read somewhere about the number 63%, do I set the tangent point with the graph from this value? :)
    so I understand that the time constant is the time between the tangent point with the graph and the intersection of the horizontal line at the top of the graph?
    kemot55
    Help: 184
    Rate: 147
    You can accept that. And so much accuracy (using a ruler :-) ) you are unable to obtain. Here you would have to make a non-linear approximation (but certainly not on paper) - then it will come out perfect. And you can't put this pattern into Excel and generate, for example, a "smooth" chart composed of 100 ... 200 points? Draw something, paste -> we'll see.
  • #5 15378491
    mateusz2812
    I got something like this :)
    I would like an assessment - by the way, I corrected the chart to "less square" Adding Time Constant to Electronics Class Graph - Basics of Electronics Assignment
    jarek_lnx
    Help: 4198
    Rate: 6126
    Rather like here:
    link
    tangent at t=0
  • #7 15378794
    mateusz2812
    thanks for another suggestion! :)
  • #8 15381260
    kemot55
    Help: 184
    Rate: 147
    I wonder how to plot a practically tangent at zero. Great idea!
    You drew well. Move the point of tangency slightly to either side and you'll see that the constant remains "constant".
    I would pay attention to something else. The determined value is exactly 30V (not 29.8) (that's the first thing) and this graph is some "little" exponential (or something distorts the picture). Is this a 1-exp(-t/tau) waveform or the effect of some smoothing/approximation?
The discussion revolves around adding a time constant to a graph for a basics of electronics assignment. The initial query seeks guidance on how to graphically determine the time constant from a limited number of data points. Responses suggest drawing a tangent line at a point of tangency on the graph and measuring the time from this point to where the tangent intersects a steady state line. The concept of the time constant being related to the 63% value of the steady state is also mentioned. Suggestions include using non-linear approximation techniques and generating smoother graphs using software like Excel. The importance of accurately determining the value of the time constant and the nature of the waveform (exponential) is highlighted.
