VW - Determining the VW engine code from VIN
nie_lubie_samochodow 76782 4
  • #1 15460492
    Rate: 28
    Hello, I need to determine the engine type from VIN VW:
    VWVZZZ1KZ5B015870
    Thank you in advance
  • #2 15460594
    robokop
    Help: 1763
    Rate: 6372
    There is no such information encoded in ViN. They can only be obtained at a VW Dealership.
  • #3 15460739
    szymon198312
    Level 30  
    Help: 126
    Rate: 890
    There is a number on the timing cover, on the sticker with the vin number, on the engine block
  • #4 15460775
    bula17
    Help: 52
    Rate: 295
    If it is not on the timing housing, you have a spare wheel in the boot under the carpet.
    If not, give the year, the model and the amount of KW from the proof, there is a chance that it will come this way, unless this power has 3 engine codes :)
  • #5 15484995
    Rate: 28
    Engine model determined from the sticker. Thank you and I'm closing
